I have an inexpensive Colby DVD player. When I put in a dvd it says on the tv screen. Wrong Disc. I've tried several different one's and I've reset it to default.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 89 Answers
Power supply problem
Posted on Sep 09, 2010
Trying to record on a DVD-R , after several minutes trying to load i get a msg saying it can neither read nor play this disc , check disc,,please help
I've had this problem with trying to record on CD-Rs also. DVD and CD recorders can be very fussy. You just have to get a piece of dust or a fingerprint on the CD or DVD that's being recorded onto and it gets kicked back as a check disc or blank disc..
Another problem is some recorders will only accept certain brands. I've had problems recording onto a SONY CD-R with a SONY recorder! So, in summing up, try a different brand or make sure the disc is clean. Sometimes just taking the disc out and putting it back in in a different position will make the recorder think it's an OK disc. Hope this helps.
Jul 22, 2012 | Samsung DVDR120 DVD Recorder
Luxor tv with dvd player was bought for me from Asda I've had problems with playback of dvds pretty much since I've had it it has a tendency to freeze and not play and on very several occasions it...
Hi Danny.
this could be a couple off things wrong here.
1,could be a faulty dvd player.
2,could do with having a lens cleaning disc put through it.
3,could be a faulty lens reader.
if i was you before i do anything big to it i would run a lens cleaning disc through it and see if it cleans the lens that reads the discs.
if this does not work i would take it back,or get someone to have a look at it for you.
Nov 04, 2017 | Televison & Video
Portable dvd player when you put disc in machine it comes up with wrong disc display on screen is it the settings
It would more likely be the types of discs used. They are either of a region code not compatible with the player, contain foreign/unknown data, or they are unsupported formats. For example, if the player supports DVD-R playback, and you put a DVD-RW in, the player will generate 'wrong disc' message if the player cannot recognise the disc or the contents on it.
The disc formats/types that can be played should be outlined either on the unit itself or in the instruction manual (if you still have it). If the player shows that message even with genuine shop-bought DVDs then there is a defect within the unit, workshop attention may be required to fix it, but it could be costly.
'WRONG DISC' usually means the disc inserted is of a different region code to the player, or the wrong format (DVD-RW instead of DVD-R as exampled above). Try using different discs before going any further.
May 04, 2011 | Televison & Video
Says loading disk and then says wrong disk everytime. tried several different dvds. always the same answer!
The DVD portable player and the DVD disc came from the same countries?Ur DVD portable player and DVD disc u are using might have the wrong region DVD disc format frequencies.Like PAL frequencies only play Euroupean,Asia,Middle East,Austriala and Africa products.NTSC frequencise play only USA,Canada and Mexico DVD Disc products.
Dec 13, 2010 | Coby 7" Widescreen TFT Portable DVD Player...
Recording Error, Can not record on this disc, E 4 54040990 Just trying to record from TV on a Memorex DVD+RW. Keep getting this error. Any ideas?
Recently started getting the same error message. I thought it was because I was getting to close to full or something that was trying to over fill the discs. Have tried EP and LP and this just started when I had a disc set to record to the end. I can't even open that one or finalize it. The rest do the same. They are working fine and when the error comes up, ZAP the disc is dead, no access.
I also tried putting the same disc into another Magnavox DVD recorder, still no access. These are both the most reliable recorders I've ever owned and I've had a number.
magnavox error message dvd "e 6 2a031000 can not record on this disc."
I suspect at this point, a batch of cheap Nexxtech DVDs. Also it's possible that it's a heat problem with the recorder? Once the disc goes into error mode, it's unreadable and all recordings that haven't been written to the TOC become invisible, but that time is forever lost on the DVD.
DVD is visibly (looking at recording surface) FULL but the supposed record time isn't used up. Data error. Discs reporting wrong size. Try a different brand of DVD.
Mar 28, 2010 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Put a DVD in Colby DVD-537 DVD player but wont't
I work for COBY tech support. Our number is 800-727-3592.
Unfortunately, your player will have to be replaced. The problem you're having cannot be fixed with troubleshooting of any kind. The player has a 90 day warranty from the date of purchase. We can also replace it out of warranty for a flat fee of $31. Please call the above number if you wish to take advantage of either option.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Jul 10, 2009 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
TV screen says wrong disc
I am try to play a movie and it says wrong disc
Jun 30, 2009 | Memorex MVD2042 DVD Player
Disc error
when i press play on my dvd/cd player it says error
May 24, 2008 | Zenith DVB412 DVD Player
Bad disk
Trata poniendo un disco limpiador de laser.
Mar 25, 2008 | Cyberhome CH-DVD 300 DVD Player
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
Electro Med Services...
