Question about Sakar (M01517) 5-Port USB Hub
I have a model m01517 5 port usb hub. It has 2 usb cables to the computer, do I use the blue or black connector? I can only get one port to recognize a device plugged in the other four seem to be dead, am I doing something wrong? Maybe I am hooking it up wrong, I don't know because I have no documentation for this equipment. Thanks in advance.
Not sure I understand this hub either. Looks like only one port is a USB 2.0 port, but here is a snippet from the manual......
This iConcepts USB Hub provides the electronic interface between USB devices and the host, It allows up to five USB devices or Hubs to connect an upstream USB Hub or Host port.
Features
• One USB 2.0 port
• 4 Port USB 1.1 and support high speed (480 mbps) and 4 port full speed (12 mbps) operations.
• The USB 2.0 port can operate both USB 2.0 & 1.1 Devices
• USB 2.0 port supports self powered mode and bus - powered mode, indicated by a powered LED .
• Over current detection and protection
Manual is provided here: http://www.sakar.com/p-1124.aspx?categoryid=182
Posted on Nov 13, 2012
What usb connector/data cables are compatible with a Phillips Go GEar HDD 1630/17. The usb connector for my Sansa Fuze seemed to fit but when I plugged it into my pc or mac I got a warning message about...
INSUFFICIENT POWER - USB PORT
If you get an error message "Insufficient power to operate USB device" when you plug a USB device into the computer's USB port or the un-powered USB hub that is attached to the computer's USB port, then this device is drawing excessive current that the USB port cannot supply. The maximum output from an USB port is 500mA. In case such as this, you need to purchased a powered USB hub and connect this hub into the computer's USB port and then connect the USB device into this powered USB hub.
Apr 10, 2013 | Audio Players & Recorders
HP LaserJet 2430 Printer Will Not Print since USB Power Surge Error
Feb 19, 2013 | HP LaserJet Office Equipment & Supplies
We bought my son an RCA mp3 player yesterday (TH1814-A). We inserted the battery and are trying to plug it into my desktop using the usb connector so that we can upload some music. however, when i plug...
There are different types of USB port. For instance my computer has two types. One with a blue connector and one with a black connector. It might be that your USB ports are not suitable for that device. You need to check the specifications of the USB ports on your computer and the specifications of the MP3 player. Continuing to use the device might cause damage to the computer.
Mar 19, 2017 | RCA Audio Players & Recorders
The cable that came with my hub has a pigtail for connecting to the computer. TWO USB plugs. I have long since lost the packaging so I don't know what they are for. One is blue while the other is the...
It could be to supply extra power to the hub. Basically the USB can only supply 500mA of power so by using 2 ports one can supply 1000mA double what one port could power.
Feb 26, 2011 | Sakar (M01517) 5-Port USB Hub
How do I set up a d-link dub-h4 to my laptop I have a power connection, a connection on the rear of the hub-4 going to an adapter connecting to the ps/2 connector on the laptop. Do I need one of the...
The connection on the rear of the hub should go to a USB connection on the laptop, not a PS/2 connection. A PS/2 to USB adapter is used to connect a PS/2 keyboard or mouse to a USB connection.
Feb 23, 2010 | D-Link (DUB-H4) 4-Port USB Hub
Broken black piece inside usb port
This is usually going to be a part replacement problem. the black piece is part of the connectors. and backs up or guides the connectors. you can go to your local computer parts store such as frys, or an electronics parts house. and buy the connectors unless it is one that is attached to the motherboard in the back of the computer. if this is the case and you do not have enough usb ports, then you have to get an external usb hub. usually a powered hub is best.
Nov 12, 2009 | Computers & Internet
My USB Port stopped recognizing my Smart Disk
on my computer right click and select properties, then go to the device manager. Under the USB device locate this device and delete and unplug the cable from the computer. Let the computer reboot, and plug the cable into another port if ava. and see what happens.
Oct 10, 2009 | Targus PA050U 4-Port USB Hub
The light on my Seagate freeagent go flashes quickly when it is connected to my computer, indicating an error. What should i do?
I had similar problem recently. I noticed that I had forgotten to connect the power supply cable to the USB hub, to which my FreeAgent Go was connected to, after I had connected all my USB devices to my computer's USB ports (after I had disconnected everything from my computer in order to isolate another issue). Reconnecting the power supply cable immediately stopped the flashing light and windows recognized the drive.
Don't know how you are connecting yours to the computer i.e. via a USB hub or directly to the computer's USB port. Note that my FreeAgent Go drive requires both USB connectors connected to the computer (or to USB hub). Two USB connectors are on one end and the other end of the cable is connected to the drive/docking station.
Hope this helps.
Jul 10, 2009 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
How do you hook in the front usb plugs into a asus motherboard?
You need a separate cable, called a USB header. It plugs to the connector in the case and onto your motherboard. A lot harder to find that you would think too, my top ports still are not hooked up after several years.
Jan 18, 2009 | XION _ Solaris XON-407 ATX Mid-Tower Case
Sakar (M01517) 5-Port USB Hub Logo
1,116 people viewed this question
Top Sakar Computers & Internet Experts
micky dee
Ravi
Are you a Sakar Computer and Internet Expert? Answer questions, earn points and help others
