Question about Seagate Momentus 5400.3 ST9120822A - 120GB - 5400rpm - Ultra ATA/100 (ATA-6) - IDE/EIDE -... 120 GB Hard Drive
My hdd is creating noise & is not dectectable
  • Seagate Master
  • 27,725 Answers
If you hear a clicking noise thats the reader arm sfipping across platters on you hard drive
a dirty hard first clean all of the dust from your computer using a fine air blower from an air compressor making sure there is no moisture in the air line then give the hard drive a firm tap on one side to free up the read arm
then replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
good luck
Posted on Sep 09, 2010
My Toshiba hard disk is not functioning well
Hi,Dear Customer,
1> Please check you HDD cable connector.
2> Where from connect HDD cable in mother board, this port change and be care fully connect.
3> Check HDD bad sector. If you hard disk create a bad sector then not well run any hard disk.
4> Check jumper setting, first boot & sec Boot option. you hard disk where connect first boot & sec Boot option.
I think solve you problem.
Sep 12, 2012 | Toshiba Computers & Internet
My laptop is saying that their is no operating system not found what do i do to fix this problem i have a sylvania 8.9 lcd m 512mb and a 160gb hdd
check the bios whether the HDD is dectected (you can the get the bios by tapping F1 in XP and F10-in Vista and windows 7) if the hdd is dectected perform a smart short test (click on ur harddrive-smart support-smart short test )-----If the harddrive passes the test
-then try hitting ESC while boot up select the hdd to boot check if that works
if that doesnt work then you need to run the the operating system disc
Apr 25, 2011 | Intel Computers & Internet
I have a dell 1525 inspiron, it keeps telling me that windows has dectected a hard disk problem back up files now..do you have any help ideas or repair ideas
Basically there is no perfect product for this task, these errors are usually divided intotwo: physical and Badura Badura software, not physical ones of what to do than tochange the HDD and the HDD format is software. if you have warranty for your laptop go to dell warranty to change your hdd, if you not you must buy one new.
Jan 21, 2011 | Dell Inspiron 1525 Notebook
Hi, I have a Toshiba 80GB MK8037GSX 2.5" SATA in
1) have checked bios cannot see hdd mounted.
That is BAD -- the disk-drive could have "died".
2) tried a seagate hdd works fine so connections in laptop seem to be working
That shows that your motherboard is GOOD, but that your disk-drive is BAD.
3) can hear hardrive trying to do something as can hear harddrive usual noise, continous noise for about 5 sec before getting the error message
That is BAD -- the disk-drive is "dying".
4) no rattling or crackling noise from drive apart from the above
That is BAD -- none of the files can be read from your disk.
i have created a ubuntu boot up disk which allows me to access laptop but does shows error when locating hdd,
That is BAD.
once in ubuntu i can access internet but it does not show the windows partition of the harddrive, only shows ubuntu as opearing system, confused.
That is BAD. Only the CD/DVD disk has been mounted -- Ubuntu could not mount the disk-drive.
In regards to ubuntu working does this mean the hdd is ok?
No, it means that your motherboard is working.
and is there anyhting i can try via ubuntu to locate the files?
No. The disk-drive is "dead".
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 13, 2010 | Toshiba 80GB MK8037GSX 2.5" SATA II SATA...
Than you in advance for any and all help pertaing to my issue. Problem: 3-4yr old HP laptop. Did have Win XPsp2 on it. HDD went bad. Used Barts PE to create bootable cd-rom with half working Win XP, but...
Why do it the hard way? If your HDD is bad, most probably the system files are corrupted too and getting/making a bootable CD from the HDD files is just wasting your effort. If you laptop CD/DVD drive is still good, then use the options below: -
1. Go to any torrents site download "hp oem xp" disc from the site & burn the bootable image to a CDR.
2. Go the the Hp support Site & download the XP drivers for your Laptop model.
3. Then you can do a new installations on your Laptop.
Hope it helps.
Nov 15, 2010 | Microsoft Windows XP Professional
HDD is not detect & some sound coming from HDD.
I f ur hearing a whirling and clicking noise in ur HDD, that means it is already BUSTED and needs to replace! The internal LENS can't read the disk anymore! Taah!
Nov 13, 2010 | Samsung (MP0804H) 80 GB Hard Drive
Hard disk not dectecting
Is your Hard disk running at all ?
Can you hear some spinning noise and vibrations when it starts running?
Check the jumper settings (Master/Slave/Single).
If you have another device connected on the same cable (HDD/CD), check jumper settings on that device too.
You may first try to disconnect other device (if connected).
It is a very old PC, try replacing the data cable of your HDD, and pay attention of the correct connection of cable to the motherboard and HDD, too !
Check BIOS settings if both IDE channels are enabled.
Regards.
Mar 28, 2009 | Intel Motherboard
Seagate Momentus 5400.3 ST9120822A - 120GB - 5400rpm - Ultra ATA/100 (ATA-6) - IDE/EIDE -... 120 GB Hard Drive Logo
167 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
terminalcon
John Anderson
John Anderson
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
