Question about Sharp AR-5316 Advanced Digital Imager Copier
I have sharp AR 5316 when i power on toner blink was come machine button was not work i also toner was full in catridge i replace the toner chip with new one installed again same problem pls give some urgent tips sir pls
  • 360 Answers
Check your developer unit wheel set .i think it was broken.that 's why didn't add toner
Posted on Sep 09, 2010
Catridge of Sharp mf420u
When the toner supply not attached the properly than comes this problem.
Better way you open the toner and check all toner supply gear ,if gear is jam than you should replace the toner.I think your toner chip version problem or destination problem.
May 29, 2014 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR 5316 Maching Toner LED Light 3 Min. Blinking, and them start. Please Toner Curm reseting code.
Have you tried to replace the toner???? Are you sure the light that is blinking for the toner?????
Jan 13, 2013 | Sharp AR-5316 Advanced Digital Imager...
My sharp ar5316e is showing a red triangle blinking light and no key is responding nether the start button
That indication is Toner Indication.You should change the toner,Now May be the toner chip also damaged. whether the machine worked after changing the toner then no need to change the toner chip,other wise the same indication still, then you change that one also.
Jul 08, 2011 | Sharp AR-5316 Advanced Digital Imager...
I installed the Sharp ar-5220 and received an error message. CH keeps blinking and does not allow me to press any buttons.
Make sure your toner catridge is installed properly then open the side door and front door , and close it properly the code CH means your machine door interlock is open. Vote for this rate this
May 27, 2011 | Sharp AR-5316 Advanced Digital Imager...
AFTER REPLACEMENT OF TONER CARTRIDGE LED IS BLINKING MODEL AR-5316
hi,
blinking led after replacement of toner cartridge is normal , you have to wait till it gone .
how ever if you feel it take along time then you must check the toner cartridge and reinstall it properly if the machine still blinking you may have to change the developer.
thank you for using fixya
Feb 01, 2011 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316
The toner cartridge comes with on-chip sensor that counts the toner life. If you allow it to go empty completely that is it gives red triangle which is steady to warn that toner is near empty. You should replenish toner at this time but if you allow it to blink red triangle, that means its completely over and can't be refilled. REPLACE A NEW TONER CARTRIDGE.
May 06, 2010 | Sharp AR-5316 Advanced Digital Imager...
Ar-5316 showing error ch
CH steady means cover is open. Close either front or right cover well.
CH blinking means developer unit or toner cartridge not installed. Remove and return well and firmly.
Nov 22, 2009 | Sharp AR-5316 Advanced Digital Imager...
SHARP AR-5316 MAINTENACE RESET
To reset maintenance codes requires going into service mode. This should only be done by an authorized trained technician as changing or adjusting something in this mode could create all sorts of problems you dont want to deal with.
Mar 17, 2009 | Sharp AR-5316 Advanced Digital Imager...
Add toner still blinking of sharp AR-5316
the best you can do is to replace the toner cartridge itself. It won't work if you just refill it.
Oct 31, 2008 | Sharp AR-5316 Advanced Digital Imager...
Ar-5316
I'm not to clear on the request. Please resubmit.
Jun 04, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
145 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
