Question about Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
What is the AF display code indicating? - Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
  • 347 Answers
AF Is letting you know there is an AIR FLOW issue most of the time this is from a vent system that is restricted in the wall or a kinked duct between the unit and the wall,or in some rare cases a blower fan/motor concern .Best thing to do is just make sure the exhaust system is clear from the unit to the outside vent
Posted on Sep 09, 2010
My Nikon Nikkor 18-135mm f/3.5-5.6G ED-IF AF-S for Digital SLR lens does not seem to auto focus well. Sometimes the lens will focus and unfocus and refocus constinely. Is this normal??
You did not say which camera body you are using, but you probably have three different auto-focus modes on you camera. You might be using the wrong one.
The modes are as follows:
AF-A Mode: Camera automatically selects single-servo autofocus when AF-A subject is stationary, continuous-servo autofocus when subject is moving. Shutter can only be released if camera is able to focus. AF-S Mode: For stationary subjects. Focus locks when shutter-release button AF-S is pressed halfway. Shutter can only be released when in-focus indicator is displayed.
AF-C Mode: For moving subjects. Camera focuses continuously while AF-C shutter-release button is pressed halfway. Photographs can be taken even when in-focus indicator is not displayed.
Dec 19, 2012 | Nikon Nikkor 18-135mm f/3.5-5.6G ED-IF...
It will not dry it say the lettrs af
The airflow is restricted as indicated by the AF code. Check for clog lint filter and/or restricted vent system as lint build up in these areas cause airflow restriction and hence the AF code. Another possible reason is a faulty exhaust thermistor located on the blower housing. It is likely a thermistor fault if the lint filter including the vent system are all clear from lint built up but the AF code persists.
Disconnect power then remove the rear access panel and locate the thermistor on the blower housing. Disconnecting the thermistor and running the dryer will cause E1 to appear on the display to indicate an open circuit thermistor and E2 if the thermistor wires are connected together. Replace the thermistor if this is the case. Click on the links below for additional troubleshooting information.
Error Code E1
Error Code E2
Error Code AF
Jun 18, 2011 | Whirlpool Dryers
Ac shuts off E1 error message
E1 Error Code -->> Clean Filter
Owners of Sharp air conditioner models AF-S60FX, AF-S80FX, AF-S85FX, and AF-R80FX may experience the following (highly annoying) issue. After 720 hours of fan operation, the error code E1 will appear on the seven segment LED temperature display. This error code is intended as a reminder for the user to clean the air filter. However, because the procedure outlined in the user manual does not clear this error code as indicated, and the appliance has a nonvolatile memory that cannot be reset by simply unplugging it, the user of the appliance will become mightily frustrated, standing in potentially sweltering heat watching the appliance repeatedly shut down in the midst of operation with the "E1" display flashing.
Believe it or not, that is what it does: if you unplug it to remove the "E1" code from the display, and plug it back in and re-start it, it will simply run for anywhere from a few minutes to a few hours, and then merrily shut down again with the same flashing "E1" code.
Many people at this point, having put the manual under the canary or some such, will simply return the unit and never buy another Sharp air conditioner. But for the tech-savvy and search-adept, I offer the following procedure to clear the nefarious E1 indication, and obtain another 720 hours of cooling bliss:
1. Power down the air conditioner using the "power" button on the front panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air conditioner in. Continue to hold the power button down as the machine goes through a brief test sequence (fan & compressor each come on briefly, etc). There is a "beep" sound at the end of the test sequence, and the machine will be off. At this point, you can release the power button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air conditioner normally for another 720 hours, but only if you followed the instructions above exactly.
If you doubt the veracity of this information, or it does not work as expected, you can get it directly from the source at: 1-800-237-4277 (Sharp customer service line). You'll need to call between 7 AM and 7 PM US Central time, and have your model number and serial number ready.
May 28, 2011 | Sharp AF-S120FX Air Conditioner
E1 ERRORE COMES IN M Y AC WHICH REASONS
So you will come home to a hot bedroom, living room, etc. unexpectedly,
and you will NOT be amused, as I was not.
panel.
button.
the instructions above EXACTLY.
  • Date: 5 Aug 2005 06:33:46 -0700
How To Clear Sharp Air Conditioner E1 "Clean Filter" Error Code
http://sci.tech-archive.net/Archive/sci.electronics.repair/2005-08/msg00472.html
Mar 01, 2011 | Heating & Cooling
AF error will not go away after cleaning vent and lint filters
Thank you for contacting Fixya.com.
AF is an error that will flash if a restricted air flow is sensed by the dryer control. If three consecutive cycles have low airflow the control will flash the AF error.
The AF error code can be cleared by pressing the Drying Temp pad for 5 seconds while in stand-by mode. AF will flash in the display for 1 second then "on" will appear in the display. If you press Drying Temp again and "of" will appear in the display indicating the AF error display has been turned off. Try this procedure and see if the "of" error goes away. If the "of" came up in the display by itself then the keypad may be stuck. However After cleaning the dryer's lint screen, ensure that the exterior exhaust hood connected to the dryer is unblocked, ensure that the vent connecting the dryer to the wall is clear and see that the vent is cleaned professionally.
Please get back to us if you have any further query.
Nov 29, 2010 | Kenmore 67062 Dryer
My cannon rebel eos DS6041 displays error 99 when
'Error 99' indicates some problem with the AF contacts. This is a common error in Canon lenses. It could indicate a very simple problem like dirty contacts or a much serious one like the breakage of USM cable.
As a first step, you can try cleaning the lens and body contacts (the metal contacts between the lens and body) using a pencil eraser. Be careful to hold the body facing down so that no dust falls inside. After cleaning both the lens and the body contacts, re-attach the lens and try shooting. If the AF does not work still, you need to take the lens to an authorized service center.
Jun 01, 2010 | Canon Digital Rebel / EOS-300D Digital...
How to retrieve current radio code for my 2004 chevy aveo?
Here's an easier way. Purchase a 9 volt battery powered radio / computer MEMORY RETAINER. Plug into your cigarette lighter/power socket SECURELY. AFTER replaceing the battery, remove 9 volt poer feed, and BINGO. Radio stations memory, clock will all RETAIN. their memory. Hope this helps
Apr 19, 2009 | 2006 Chevrolet Aveo
Dryer is displaying AF
i got this from the other site.
The code AF indicates that the control senses a restricted air flow. To clear the code, press STOP once and the estimated time remaining countdown will return to the display. The AF code will continue to appear with each cycle until the low airflow condition is resolved.
Try the following troubleshooting to resolve the air flow problem:
  • Clean the lint screen.
  • Check at the outside of the home to make sure that the vent exhaust hood is not blocked.
  • Check the flexible vent connection behind your dryer. Make sure that it is not kinked or clogged.
  • You can disconnect the flexible vent and start a cycle with the dryer venting directly into your laundry room. If the AF code does not appear, this will verify an exhaust vent duct problem. Otherwise you may have a component failure.
  • Have your home dryer venting run cleaned professionally.
hope i was able to fix your problem,
tnx 4 using fixya,
drcool
Oct 04, 2008 | Kenmore 67082 Electric Dryer
Brother Mfc 420cn says machine error AF
Open the small cover that hides the scanner flat cable. It has to be reconnected to the main pcb.
Oct 23, 2007 | Brother MFC 420CN All-In-One InkJet...
Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
168 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
