Question about Microwave Ovens
Have a gaggenau AHc 250 / 190 rangehood and require a circut diagram for the electrics so the electrician can repare damage
Am I able to fit a charcoal filter to a viali undermount rangehood model VPP90s and what kind
There is a picture that supposedly shows you how at this site: http://vialiproducts.com.au/wp-content/uploads/2015/10/VPP52S-60cm-Undermount-Rangehood.pdf
I am not too impressed with it, but hope it helps you!
Feb 12, 2017 | Microwave Ovens
Baumatic rangehood bah9005 the switch pushes in and the lights dont work , motor works when electrical switch at wall is on
Thank you for using FixYa. It sounds like there is obviously power getting to the rangehood ( the motor works) and I would suspect that it is just the bulbs that have blown.
Mar 16, 2011 | Microwave Ovens
Where can i get the Dishlex ranghood filters that more than 20 years old ?
The following Australian site carries Dishlex parts. You will need to know the model number of your rangehood or the size of the filter. If you know the model number simply do a more specific search to narrow your choices.
http://spares.alliedappliance.com.au/search.php?match=&keyword_list=Dishlex+rangehood+filter
Feb 15, 2011 | Microwave Ovens
I have a creda europa solar plus double oven and want to replace it with a BOSCH HBM56B550B will the power supply I have be enough for the Bosch?
What you must do is calculate the total power required by the Bosch cooker. Convert it into Amperes and copper cable is roughly 10 Amperes per 1.50mm cable. What size cable feeds you cooker at present? Or
Is the maximum power calculated for the old cooker the same or more than the new cooker. If it is and the old cooker was installed by a qualified electrician observing local electricity codes, no problem get it fitted, if not consult a qualified electrician.
Jan 01, 2011 | Microwave Ovens
I am looking for user manuals for the Gaggenau VG330-811 and Gaggenau VG352-812 cooktops
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, and a list of Dealers for spare parts, as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Dec 31, 2010 | Microwave Ovens
I had the electricity go out in the litchen last nite, and usually, I just go to the basement and reset the breaker. It didn't work last nite. Also, now when I turn on the electric range, a light in the...
It's not a ground problem, but more likely a weak or open neutral connection somewhere. This can cause damage to other connected devices because of excessive voltage, and should be taken care of quickly. You should have a licensed electrician check and repair this, both because it may be difficult to locate exactly where the problem is, and because your insurance policy will probably require repairs be done by qualified personnel.
Dec 30, 2010 | Microwave Ovens
Reattaching wires to rangehood westinghouse wrj900us
usually have wiring diagram posted somewere on unit
Oct 12, 2010 | Westinghouse Microwave Ovens
Wiring diagram for ballast, fluro & starter
you can also try www.firstlightdirect.com we thought they did everything as well
Dec 10, 2009 | Sharp Microwave Ovens
KBMS1454RSS 1000 watts it just quit no warning
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
Accessing some components (especially the oven cavity thermostat) for testing and possible replacement will require you to remove the oven from the wall and take off the outer cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Kithcenaid/Whirlpool owner's manuals and installation instructions here.
Aug 18, 2009 | KitchenAid Microwave Ovens
Sparks!
your oven have been damaged don't on it again and again.....
it need reparing of heeted wires inside the oven
plz. do not use it, its may be harmfull to you because sparks shutdown your all home light or chances of electric shock
Oct 17, 2008 | Daewoo KOC-925T Microwave Oven
Microwave Ovens Logo
73 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
