Question about Mtd 22" Yard Machine Push Mower
I have a talon am3050 . how to re wind the starter cord,either way it just comes out wont go back. the cord is a bit shorter than usual does it matter
3 Suggested Answers
huffman49
  • 235 Answers
SOURCE: Hi, I have a Talon 135 Surefire, Model AM3050 and
got to this website http://search-manual-online.com/talon-am3050-manual.html you can find all the parts you need for your mower even the covers for the filters. I already checked it out ..good luck
Posted on Apr 05, 2010
BElectric
  • 1140 Answers
SOURCE: how much oil does the sump require in a talon
It's very difficult to find information for this specific mower, however, most petrol mowers have a reservoir size of 1 pint / 0.5 litre. You should have a dipstick for checking the oil level anyway.
Basically, I suggest you drain the sump and add 0.5 litres of oil to ensure that the machine is neither low on oil or overfilled. Then call/email the manufacturer on Monday for clarification and/or a new manual.
Talon Tools contact:
tel: 1300 804 213
customerservice@husqvarna.com.au
Regards,
BElectric
Posted on Nov 06, 2010
How to string a talon garden hawk trimmer
https://www.youtube.com/watch?v=tXUrdUoS_PU
Mar 18, 2015 | Garden
Talon am3050
Does in lift off the post?
Nov 19, 2013 | Garden
How to replace starter cord stihl 35
i do not show Stihl as having a 35. usually on the trimmers there are 3 screws on the starter housing that come out and the cover comes off. after that you need to remove the old rope put in a new rope on the rotor, wind it up, put the cord through the grommetted hole, let it slowly rewind itself to a point that is almost in then put the handle on put the cover back on insert 3 screws and you should be done
Feb 13, 2013 | Stihl Garden
How much oil does the sump require in a talon AM3050 lawn mower? Can't find my manual
tel: 1300 804 213
Regards,
BElectric
Nov 06, 2010 | Mtd 22" Yard Machine Push Mower
How do I disassemble the housing to get to replace the starter rope?
Hi.
Disassembly procedure depends on the make and model. Please provide model info for the unit.
Thanks.
Sep 04, 2010 | Garden
The pull string broke how. how do i put the new one on?
Go to a hardware store and ask them if they have ant bulk pull starter rope. Buy about 3 feet or so of the small stuff (it is only 30 or 40 cents a foot, cheaper that the kits) Remove the motor cover with the pull start and turn it so you can see the wheel inside. Remove the knot that held the old rope in the handle and then cut the knot on the starter wheel and pull out the tag left in there.
Now the fun part. The wheel is spring loaded and the spring has no tension on it after the rope broke. Wind it up like a clock spring until it is tight then back off until the holes where the cord goes line up. Stick a small screw driver, nail, ect in the slot to keep it from unwinding . Do not tie the handle to the cord yet. Slide the new cord through the hole in the cover and wheel and then tie a knot in the cord and pull it snug in the wheel. Hold the rope and remove the pin and let the cord slowly wind itself up. Run the cord through the hole in the handle, Adjust to the length of pull you want and tie another knot.
Reinstall the motor cover (if it binds and wont go on, pull the rope just a little bit to line up the crank with starter wheel and it will slide down.)
It sounds a bit windy but it really is a simple fix.
Jun 09, 2010 | Troy Bilt Tiller/Edger 26cc, Model No....
How come my 91 talon tsi awd 5spd wont start
Possible bad starter , low voltage in battery meaning dead battery or just bad and corroded connections at battery post and starter. Try cleaning connections and recharge battery if needed.
Nov 08, 2009 | 1991 Eagle Talon
Cord snaped
I am assuming you are refering to the Starter cord. All the plastic pieces must be removed. Then the blower housing . Inside you will see the starter wheel that winds the cord. You must wind the wheel until it is not possible to wind anymore,dont force it.Secure the wheel by passing a screwdriver thru the wheel and thru the housing. Position the hole in the wheel with the hole in the blower housing where the cord comes in.Pass the cord thru both holes and knot the end inside the wheel. Use a lighter to melt the cord just a little so it will not come unknoted. Pull the screwdriver from the housing and slowley let the spring re-wind the cord.If its a 5 or 6 hp briggs it take about 88 inches of new cord.Hope this helps.
Jun 30, 2009 | Garden
How to repair the pull starter for the WEED EATER Power edge PE5 50 - 22 cc engine the rope pulled out"
NOT SURE IF YOUR STARTER IS PART OF THE COVER BUT IF IT IS IT CAN BE A BIT TRICKY AS SOME MACHINES YOU HAVE TO REMOVE THE STARTER WHEEL TO GAIN ACCESS TO REMOVE WHAT IS LEFT OF THE OLD CORD AND THEN FEED ANOTHER CORD THROUGH THE HOLE. UNDER THE STARTER WHEEL YOU SHOULD HAVE A LARGE COILED SPRING WITH A CIRCULAR HOOK POSSIBLY ON THE END WHICH HAS TO ENGAGE TOO THE UNDERSIDE OF THE WHEEL, ONCE THAT IS DONE YOU HAVE TO PULL THE ROPE INTO A NOTCH ON THE WHEEL BEFORE YOU WIND IT AROUND THE WHEEL, TURN THE WHEEL IN THE DIRECTION THAT THE COILED SPRING END WAS POINTING UNTIL IT STOPS, BACK IT OFF 1 TURN FEED THE END OF THE CORD THROUGH THE HOLE IN THE BODY OF THE COVER AND PUT A LOOP IN THE CORD NEAR THE HOLE TO STOP THE CORD FROM WINDING IN, THEN PUT THE RUBBER PULL END ON THE CORD AND TIE A KNOT IN THE CORD BEHIND THE RUBBER PULLER TO STOP THE CORD FROM PULLING BACK THROUGH THE HOLE.
rELEASE THE LOOP IN THE CORD NEAR THE COVER HOLE THAT YOU PUT IN AND LET THE SPRING WIND THE CORD BACK IN TO THE STARTER WHEEL
May 09, 2009 | Garden
Mtd 22" Yard Machine Push Mower Logo
165 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
