Question about Pc Ware M741LMRT Motherboard
Jumper or motherboard setting - Pc Ware M741LMRT Motherboard
My motherboard (intel DG41WV) is starting but not giving output to screen. I have cheked cables sokets. Even i have cheked to other screen. but problem is still. all peripherals (fan, cd-rom...etc) are...
Jumpers:
Motherboard installed in computer case;
A) Keyboard Jumper Block
3-pin jumper block, Top of motherboard/ left side. Near the mounting hole, and 4-pin ATX +12 Volt power cable connector,
GENERAL example of a 4-pin ATX +12 Volt power cable, and it's respective connector on the motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
[ This power cable MUST be plugged into the motherboard.
It is power for the Intel processor ]
3-pin jumper block.
Starting at the TOP coming down;
Pins 3, 2 and 1.
Jumper cap should be on Pins 2 and 3.
(Enables the Keyboard wake-up feature. Factory default setting is Enabled. Pins 2 and 3)
B) Clear CMOS Jumper Block.
BOTTOM right corner of motherboard. 3-pin jumper block.
It is to the Left of the bottom/left SATA connector.
It is immediately to the Right of the motherboard mounting hole.
Starting at the Top, and going down towards the bottom edge of the motherboard;
Pins 3, 2, and 1.
Jumper cap should be on Pins 1 and 2.
When you changed the SMPS, do you KNOW for a fact it is a good one?
Did you plug the 4-pin ATX +12 Volt power cable, into the motherboard?
What COMS setting/s did you change?
I would go back into BIOS Setup, and set that menu screen back to the factory default settings.
[ Load Optimal Defaults ]
BIOS Settings Glossary,
http://download.intel.com/support/motherboards/desktop/sb/biosglossary_v18.pdf
Regards,
joecoolvette
[Motherboard manual - http://www.intel.com/support/motherboards/desktop/dg41wv/sb/CS-031417.htm
Nov 11, 2012 | INTEL - MOTHERBOARDS Computers & Internet
Mk40vn no beep no powerled some hdd led some cd led after reset cmos jumper in right position no other jumpers are set on board i have no manual for jumper settings please help me susanne
in some motherboard when you change the c mos jumper the motherboard doesn't switch on change the pin to 1 and 2 normally which is c mos normal and 2 and 3 is to clear c mos you will see marking of all the jumpers in the motherboard set the pin correct to normal and also remove the power connector from the motherboard and short the green and the black wire and see whether the smps works if not working change them
Oct 01, 2011 | Shuttle MK40VN Motherboard
Do you have to set the motherboard jumper settings? or are they preset
Jumper settings can usually be left alone. All jumper settings can be found in the motherboard manual found here:
Super Micro Computer Inc Products Motherboards Xeon Boards X8DA6
Oct 13, 2010 | SuperMicro X8DA6 DP LGA1366 MAX96GB EATX...
What is the purpose of the diagram of jumper setting?
The jumper settings (if this is the one you are speaking about) are for clearing the BIOS (times, dates, hardware etc...). The diagram is probably showing the settings on which pins to jump when clearing.
Hope this helps.
Nov 09, 2009 | Intel D865GBF Motherboard
Does the MA2 M360 motherboard has jumpers that
Most modern motherboards have no jumpers that need to be set.
Oct 06, 2009 | Gateway DA0MA2MB6D8 6000 and M360 Series...
ECS P4IBMS Motherboard CPU Voltage Jumper Settings
I don't believe that there is a P4 motherboard that needs jumper setting to specify the CPU voltage. This used to be common for Pentium & Pentium II motherboards, & some Pentium III motherboards. But I have never seen a Pentium 4 motherboard that require this kind of setting.
Besides, I checked the motherboard's manual & I saw that there is a sub-menu in BIOS labelled "Frequency/Voltage Control". This should be the place where the CPU voltage should be set, & on most motherboards, CPU voltage & frequency are automatically detected.
Jun 20, 2009 | EliteGroup ECS P4IBMS Socket 478pins...
Award BootBlock Bios V 1.0 copisight (c) 2000, Award software, Inc Detecting floppy drive A media Scanning Bios image in Hard Drive..... What is this? please help me.
Hi how are u, it is simple problem friend
Your motherboard jumper setting has been changed.
please read manual of your motherboard jumper setting if u not have manual. open ur pc cover and see the motherboard jumper.
remove your bios battery and change your jumpers 2-3 by defualt.
i hope u are understand u will change your motherboard jumper settings bye.......from mukesh_ibm@yahoo.com
May 13, 2009 | Gigabyte Computers & Internet
Motherboard not starting!
try to set the jumper setting of the cmos battery in *********** board.you set the jumper setting 1 and 2 with in 3 mins.then try to set back the original setting the jumper seting in 2 and 3.
kira_ryuk99@yahoo.com
Jan 11, 2009 | ASUS K8V-MX Motherboard
MSI 845GE MAX L MOTHERBOARD JUMPER SETTINGS
Hello!
If the motherboard is new or you never set any jumper setting or you did not interfere any connection seeting their then you yo did not need jumper setting to seat the CPU.
The CPU you are going to use is very compatible in your mainboard so do not worry about the setting.
more about your setting click here for the usermanual of your board.
hope this help, melnavz
Feb 25, 2008 | MSI 845GE Max-L (MS-6580-060) Motherboard
Pc Ware M741LMRT Motherboard Logo
99 people viewed this question
Top Pc Ware Computers & Internet Experts
David Payne
David Payne
Are you a Pc Ware Computer and Internet Expert? Answer questions, earn points and help others
