Question about Vacuums
The tray full light stays on even though the tray is empty.this prevent the foodsaver from operating.I have tried unplugging,recleaning the tray but nothing works
  • 3 more comments
  • Darlene Hines
    Darlene Hines Oct 23, 2012
    Tried the tape, did not work. Did what alex recommended and viola, no more tray full light and I always check the tray every time I use the Foodsaver. Tthank you all so much
  • J Eriksen
    J Eriksen Oct 20, 2013
    wash very well took pairing knife tip scraped along wires in bottom and on side working well now. best solution keep it clean
  • Tom H
    Tom H Nov 30, 2013
    Blow dryer on HIGH HEAT worked for me in seconds. I'm up and running with no screwing needed.
  • Jmetch
    Jmetch Sep 11, 2015
    disconnected the wires from the board it works great and does not stop when it gets a little wet inside the tray.
  • Keith Scott
    Keith Scott Jan 22, 2017
    Thanks, worked great. The wires in my machine were red, white and black but easy enough to trace back to the tray sensor.
I had the save problem with my 3400 series.
The first time i was able to let it dry and it worked alright (48 hours).
The second time even this did not work.
If you remove the screws on the bottom of the unit. There are about 10 and pull it down, you will see the sealer assembly and a small circuit board in the middle.
Trace the wires from the drip tray, there are three of them, red white and brown, to the small white plastic JST connector on the small circuit board. Pull said connector gently to disconnect it.
The unit will function perfectly now, although it will no longer have a drip tray sensor of any sort it will function every time all the time.
All in all this took me about 10 minutes.
Thanks!
Posted on Dec 13, 2011
  • 15 more comments
  • squishedbeet
    squishedbeet Jan 17, 2012
    I followed the red,black and white wires from the drip tray of my v3840 FoodSaver and disconnected it. Thanks!
  • kurtfetherolf Jan 27, 2013
    That worked for me.
  • brenda e Aug 11, 2013
    worked for me, too!
  • Liz Russell Oct 05, 2013
    Well.......I only see one white plastic connector & it won't come off! HELP!
  • Lutz Nutz
    Lutz Nutz May 04, 2014
    Perfect! no more phantom Tray Full lights!
  • Lynn w
    Lynn w Sep 01, 2014
    I have a 3880 model and the solution Alex suggested worked after everything else failled. slight differences on the V3880 were that my wires were red, white and black ( and very hard to reach behind tubes and other wires) and we only had 8 screws on the bottom of the unit. If u have my model, you'll need a long needle nose pliers to get at the JST connector. Thanks, Alex!
  • Sheri Johnson
    Sheri Johnson Oct 12, 2014
    I tried it and it did not work. It made it keep running like it was sealing. It wouldn't stop and still not functional.
  • Sheri Johnson
    I looked at it again and the wrong wire was pulled. So, yes, it did work. Thank you.
  • julie hall
    julie hall Feb 10, 2015
    omg!!! i was so upset as i really cannot afford to buy a replacement and i could not get that tray full light to go off - thank you!!! it worked!!! you have no idea how happy i am!!!!
  • james dickerson
    james dickerson Jan 07, 2016
    I love the way you think, thanks a lot easy fix.
  • alison hall
    alison hall Jan 20, 2016
    Thank you. It worked, you saved my day.
  • Dene
    Dene May 04, 2016
    It worked! You saved me the cost of replacement. Thanks for sharing!
  • JoAnne Lederer
    JoAnne Lederer May 16, 2016
    I have 4 wires red, white, brown and black. Should I be removing all of them? I did pull the red,white and brown one and the light went off but the sealing not runs continuously
  • Brad Anderson
    Brad Anderson Jun 01, 2016
    Thanks Alex! Worked great
  • Chad Nygard
    Chad Nygard Feb 10, 2017
    This worked for me. Use a Flashlight so you can trace the wires too the board correctly. The connection will pop right off the board with a sharp tug. LOL put your 7 screws back. boom boom done.
  • Debra Johnson
    Debra Johnson Apr 30, 2017
    Thanks Alex. Worked perfect! You da man! BTW ours is model 3825
  • Rebecca Guralnick
    Rebecca Guralnick Aug 09, 2017
    worked for me too:) Thanks!
See the little metal contacts on the left end of the tray. Lift tray out, cut a strip of cellophane tape and wrap it around the end of the tray covering the contacts and put the tray back in. You will have to push a little harder to get the tray in due to the tape. The contacts turn that light on and the tape insulates the tray contacts from the contacts down in the Foodsaver. Did it last night, works like a charm. Remove tape if you want to.
Posted on Aug 09, 2011
  • 6 more comments
  • Mary Suchopar Mar 29, 2013
    Thank you, Thank you, Thank you! It worked beautifully.
  • Victoria Attanasio
    Victoria Attanasio Apr 18, 2014
    OMG! Thank you, this worked like a charm...I feel like McGyver!
  • Sheri Johnson
    I tried it and it was a different colored wire. But it worked. Thanks
  • elaine
    elaine Dec 24, 2014
    OMG... You are amazing..... I have taken every screw out and tried to disengage the tray.... This was so easy.. Thank you for this... saved me so much money...
  • Marty
    Marty Jan 03, 2015
    Didnt work for me
  • Melanie Flahr
    Melanie Flahr Apr 24, 2016
    This worked for me. Thanks for your suggestion.
  • Darlene Hayes
    Darlene Hayes Jan 01, 2017
    I love the internet - thank you :)
  • statewide1 Sep 24, 2017
    Dude it worked great. But on mine the wires were red white and black. If I would have heeded your instructions and traced the wires I would have solved it in no time. Thanks.
Thank you Alex! I have a model V3825 and the 3 wires going to the JST connector are red, white and black, not brown.
Posted on Aug 31, 2013
Well my food saver is brand new so I'll just return it and try my luck with another one. Something this expensive should work without tape or disconnecting wires.
Posted on Nov 22, 2012
Clean the contact area in the drip tray with compressed air. works fine after that and you wont wreck your warranty
Posted on Jul 27, 2012
  • steve122885
    steve122885 Jul 27, 2012
    clean the contact area in the drip tray with compressed air. works fine after that and you wont wreck your warrenty
Tried the tape, did not work. Did what alex recommended and viola, no more tray full light and I always check the tray every time I use the Foodsaver. Thank you all so much
Posted on Oct 23, 2012
  • Lynn w
    Lynn w Sep 01, 2014
    Me too. Also tried cleaning the connectors, drying them etc. unplugging the connection from the circuit board was the only thing that worked.
Blow dryer worked for me!!! YEAH!!!!
Posted on Nov 30, 2013
Hair dryer - remove both tray inserts and dry both trays throroughly, paying special attention to the sensor area in the center of the upper tray.
Posted on Sep 26, 2013
  • Dick Sommers
    Dick Sommers Jun 30, 2014
    Thanks hair dryer worked with my 3800
Fixed my Food Saver V3440 doing exactly what Alex said to do! Disconnected the wires that run from the drip tray sensor and it worked like a charm!
Posted on Dec 26, 2013
I also unscrewed the screws from the bottom and cut the white wire that leads to the underside of the tray sensor - about midway on this wire so it could be easily reconnected someday...? But that solved the light on problem. Now it works great., but indeed - I must certainly check before I use the sealer each time that the tray is clean and dry.
Posted on Oct 08, 2013
Went with Alex's solution, eight screws around the outside base and two screws on the cord winder. Traced wires back to board, medical forceps used to pull white plug from board, ten screws later I'm up and running. Thanks Alex....
Posted on Aug 04, 2013
I pulled out the cellophane tape so I could try this method after cleaning and drying didn't work. I noticed when I looked at the contacts that they were slightly corroded so I used the car battery cleaning method. I poured club soda on the contacts and scrubbed them with a clean cloth. Left it to dry for about 10 minutes and it worked!
Posted on Sep 20, 2016
Just used the hair dryer that was suggested. Work like a charm!
Posted on Aug 05, 2016
Did what steve 122885 suggested.. Used compressed air in every hole I could find. Works again. V3420. Thanks
Posted on Aug 02, 2016
Mine is a 3840. Tried cleaning, drying with a hairdryer, leaving for a few days, insulating the contacts. Nothing worked so went with Alex's suggestion to disconnect the Tray Full Sensor on the circuit board. It worked immediately! I am not at all handy but after I traced the wires (which were black, red and white in my case) to the connector in the middle of the circuit board it was fairly easy to unplug the connector by giving a sharp tug on the wire. The longest part was dealing with the screws. Do not be afraid to try this!
Posted on Jan 20, 2016
As db255 said, but used black electrical tape to cover all 3 contacts under lower tray. Worked immediately and just fine. Thanks db255.
Posted on Jun 21, 2015
Hair dryer worked perfectly. Just blew the removable tray then the inside of where it sits and the upper tray and bam, it worked just fine. Thanks, saved me a big headache, as I was making sous vide chicken.
Posted on Oct 17, 2014
I have a v3825 and it has four wires not three. I disconnected it and the light turned off but the machine ran continuously. Any suggestions?
Posted on Nov 25, 2013
  • JoAnne Lederer
    I also have the 4 wires and removed white, red and brown and mine also continues to constantly run
When excess liquid fills the Drip Tray, the unit will turn off and the Tray Full Indicator light will activate. To resume normal operation, open Appliance Door, press two release buttons, rotate appliance away from you, and allow appliance to rest on the counter. Then empty Drip Tray, clean it and place it back in the appliance.
Posted on Feb 24, 2015
Bag shows full when it's empty. No clog in the hose, but when I start to vacuum, the bag-full indicates FULL, even though it's a new bag.
See if there are any sponge filters that might be clogged. They're usually between the bag and the air flow going to the motor.
Jan 29, 2017 | Vacuums
MY FOOD SAVER HAS BEGUN NOT VACUUMING. IT SEALS BUT DOES NOT GET THE AIR OUT LIKE IT USE TO
Does it hum as though it's vacuuming? If not, it's probably broken - the vacuum pump is out. It's cheaper to get a new one than attempt to get the old one fixed. If it hums, then replace any hoses you find or the foam around the drip tray.
Dec 06, 2014 | FoodSaver V3230
FoodSaver V3240: Lights flash,,,won't operate...what's wrong?
Pull out the long rubber piece on the top, clean any debris, replace firmly.
Aug 10, 2014 | FoodSaver V3240 Vertical Vacuum Sealer
Foodsaver vacuum sealer tray full light
Clean the two little contacts on the tray. Make absolutely sure there isn't anything across the two wires that run the length of the tray. It doesn't take much to trigger the light.
Jun 03, 2014 | FoodSaver V3880 Vacuum Sealer - The Master...
V3250 sealer , no operation
check the power cable and the swich.
May 12, 2014 | FoodSaver V3250 Vacuum Sealer Kit
V3835 tray full light won't go out after both trays have been emptied and cleaned.
Hair dryer. Remove both tray inserts and dry thoroughly, paying special attention to the sensor area in the center of the upper tray.
Sep 26, 2013 | FoodSaver V3835 Vacuum Food Sealer with...
Why there say tray full red light
The tape trick didn't work for me. Had to cut the wires. Works for now.
Sep 27, 2012 | FoodSaver Smart Seal Vacuum Sealer V3825
My vacuum does not start after switching bag, if the little switch is pressed in the light goes on to signal full bag even though it is empty
check your pipes.. if the can be removed clean what you can with cold water little bit of washing up liquid. ONLY.
it really sound like to me its your pipes.
Oct 29, 2009 | Electrolux Epic 6500 Vacuum
I am using a hoover ultra steam cleaner but the red ball keeps coming to the top . I assume this indicates it is full and ready to empty however it is still empty . The red ball will not stay down in order...
Thankyou,
The redball indicates that it is full, that is due to the high resistence its suction system is inducing, because it is empty and it still stays up, I would try to turn the power settings a little lower, or it is experiencing high pressure from operation. Also, if you could adjust the bristles, or losen around the air vents. This should do the trick.
Thankyou, :)
Jun 24, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Vacuums Logo
24,145 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
