Question about Apple Epson PowerLite 50c Multimedia Projector
Image is pink/purple from the projector. What is the problem?
3M MP8725 - Purple screen image only
the lcd panels are fault,you need a new ones
USD200
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Lampdeng Limited
Jerry
May 24, 2014 | 3M Office Equipment & Supplies
My epson projector is displaying purple,pink and other colors. i changed the chord but still the same problem
means that the lcd panel is fault or the polarizer is burned
Jul 26, 2011 | Epson (DHV13H010L18) Projector Lamp for...
Screen is turning a pink/purple colour
You should firstly test the projector using some alternative input sources, and using different cables to establish that the pink/purple tinge is consistent across all inputs.
If it is, then your projector is in need of professional repair. You should be able to contact 3m here who can advise who their local repair agent is.
Best of Luck
Feb 15, 2011 | 3M S20 Multimedia Projector
Duplicate image in pink displays on the screen.
From your description, it sounds like an alignment problem. There are 3 LCD panels in the projector. Each one displays an exact duplicate image of the others except it's either red, green, or blue. Under normal conditions, the images precisely overlay one another so you get a sharp image. Due to age, heat, or vibration/shock(impact) it would appear that the red LCD panel has shifted a little, giving the "ghosting" effect. You'll have to have the unit repaired by a qualified tech. He'll have the special electronic equipment needed to align the panels properly. Before sending the unit in, try a reset in the menu. Sometimes, the projectors can shift the image electronically, using math algorithms which will try to auto-sharpen the display. Hope I was able to help!---Rick
Aug 11, 2009 | Sanyo PLC XU35 Multimedia Projector
My NEC MT850 projects with a pink picture you can still see image but it is a very bright pink.
A pink image normally means a loss of green signal.If you are using Computer input you should try replacing your input cable to see if this is the problem. If it is pink with video also then the projector most likley has a internal problem.
Mar 05, 2009 | NEC MT850, MT1050, MT1055, MT1056...
CTX Data Projector - Projects strange star image
GO ON LINE AND TRY TYPING
CTX ULTRAVISION PS-5140 PURPLE STAR IMAGE
I RECIEVE 3 HITS AND THAN A CORRECTION ON THE SPELLING AND TERMNOLOGY AND RECIEVED 180+ MORE HITS
TRY MANY TYPING DIFFERENT QUESTIONGS AND STATEMENTS TO FIND WHAT YOU ARE LOOKING FOR AND ANSWERS YOUR QUESTIONS
ROD
Feb 06, 2009 | CTX UltraVision PS-5140 Multimedia...
Discolored image and lines...
I also am having the same problem. at first it only showed up after the projector was on for about 15 minutes. Now I get a purple vertical bar on the right of the screen. I also get vertical green bars spread across the screen.
Does anyone have a diagram of how this machine is assembled?
greg
Dec 17, 2007 | ASK Proxima DP6860 Plus Multimedia...
Permanent Coloured tint
When the image turns pink, we find that replacing the cable between the projector and the lap top fixes the problem.
Sep 10, 2007 | Sanyo PLC-XU47 Multimedia Projector
Device Name
Laptops with a VGA output on the back shouldn?t need any type of ?device? for the projector to work. If its displaying an image with odd colors I would suspect a problem with the projector or the cable that connects them. The easiest way to determine if it?s the projector/cable or the laptop is try connecting it to another PC or laptop.
Jul 22, 2007 | IBM ThinkPad G40 Notebook
Apple Epson PowerLite 50c Multimedia Projector Logo
91 people viewed this question
Top Apple Office Equipment & Supplies Experts
jasbo
jasbo
Don  Farrell
Don Farrell
Abdul Mannan
Abdul Mannan
Are you an Apple Office Equipment and Supply Expert? Answer questions, earn points and help others
