Question about Mitsubishi VS-50703 50" Rear Projection Television
Sound and PIP OK, but no image, screen is blue or gray
    President:
  • 1,284 Answers
Ironically your PIP module is most likely the culprit as they were very common to cause issues on those years of Mitsubishi TV's. The problem is they are NLA and hard to get
Posted on Sep 09, 2010
Picture goes black with gray fuzzy lines ~ 1/2" apart horizontal.
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Take it to a repair shop.
Apr 05, 2014 | Sanyo DP50749 50 in. Plasma TV
Vizio screen problem. Please help!
The screen is ok Your T-Con board quit. You can get a new one from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Aug 03, 2017 | Vizio VO320E LCD TV
Eonon e0858 blue screen problems sound is ok just no image just blue screen help
hi have you managed to solve the problem, if not connect your pink wire from the stereo to the ground wire or terminal
May 28, 2010 | Car Audio & Video
How to reset tv. Have sound but black screen
LCD's use a colorful crystal see through display which only visible when light is shining through it. if you have sound and no picture it's always a faulty PSU. Very easy to change out actually.
Mar 27, 2010 | Vizio GV42L 42 in. LCD Television
Mitsubishi CS-35X7 CRT TV (vintage 1993) no picture
THE PIP MODULES GO BAD IN THESE SETS. THEY PLUG IN AND ARE EASY TO CHANGE AND EVEN CHEAPER IS THE PIP BYPASS MODULE. IT ELIMINATES PIP AND PLUGS INTO THE SAME SPOT
Dec 21, 2009 | Televison & Video
PIP is causing problems
You are lucky in that this is problem you can solve yourself with a little diligence. The set has defaulted to the 'Theater Mode'. It happens frequently with this model. It is merely a setting in the customer menu. Go into either SETUP or ADVANCED SETTINGS and look for something refering to 'Thearter Mode' and turn it off. An owners manual would help locate it.
Sep 01, 2008 | Mitsubishi VS-50604 50" Rear Projection...
Pip screen and tv screen wont produce a picture at the same time
Order a new TV....thats what I have to do. I have the Protron 42", and I cant get any sound, and I cant get the remote to work. Figures, too.....the TV JUST passed its warranty period by 4 days! I havent seen any positive things said about this company, either.
Nov 04, 2007 | Protron PLTV-32 Television
Blue screen
check the agc circuit it is becomming defected.good luck.
May 16, 2007 | Mitsubishi VS-60703 60" Rear Projection...
Blue screen and sound but no picture, except in PIP mode
The lighting possibly damage the tuner of the set,for now you can swap the pip with the main picture and change the channels with the vcr,you need the assitance of a service to diagnose how much damage is there but.Let us know what you find or if you nned more information.
Oct 06, 2006 | Mitsubishi VS-45603 45" Rear Projection...
Televison & Video Logo
168 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
