Question about Sony Playstation 3 (PS3) Console
I have problems with the memory - Sony Playstation 3 (PS3) Console
  • 1,472 Answers
Publimart
If you are getting the corupted drive message on your PS3 this means you have corrupted data on your hard drive. The link below will help you address this.
http://www.fixya.com/support/r4853494-fix_playstation_3_corrupted_hard_drive
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Posted on Sep 09, 2010
I have kingston memory card but i have one problem with this memory card space is automatic decrese
yes because every memory card need some space for it self its not a problem
Jun 02, 2013 | Electronics - Others
Mobile unable to read memory card and giving information that "memory card not formatted"and then sain"operation failed" pc is also unable to detect
Initially check whether the memory card is working fine.To ensure it use it in other mobiles.If the memory card is working fine means remove any password set in memory and check in your mobile.Then check the memory card in your mobile if the problem persists Memory card IC is the problem.
Most probably the problem is the memory card .
Jun 29, 2010 | Cell Phones
There is a proplem in my software . when i use my camera it say no ( memory card ) every time .
There's a possibility that your phone cannot detect the memory card. You need to do some troubleshooting to isolate the problem.
1. Remove the memory card from your problem phone and insert it into another phone so that you could see if the memory card is the problem.
2. Try another memory card to the problem phone.
If same problem occur though you're using a known working memory card, then it could be the memory card slot is bad or the program could be corrupted that's why you are getting that error message.
You may need to contact the manufacturer for repair if the memory card is NOT the problem.
Thank you!
Nov 11, 2009 | Samsung Cell Phones
What do I do if i have a memory problem?
If you have a RAM or memory problem with your computer, the best thing that you can do is to unplug and replug the memory and check the problem will be fix but if not the next thing that you can do is to replace the memory
Sep 17, 2009 | Dell Inspiron 1525 Notebook
My sandisk m2 does not get regognised on my mobile phone.
You need to isolate the problem. Try connecting the Sandisk M2 into another phone or computer (using an adapter). If this memory card is detected by other phone or computer, then you may want to insert another memory card into the problem phone to test it.
If the problem phone works using another memory card, but the problem memory card also works using another phone, then you may want to format first your Sandisk M2 before using it.
Have a great day!
Aug 16, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
Error message: Reinsert the Memory Stick"
The problem is with the memory card. It probably just shorted internally and is no longer useful. The amount of memory is not the problem, as I used a 4GB card for a long time and my card finally went bad. You will just have to get another memory card and MAYBE find someone to be able to retrieve your data.
Aug 09, 2009 | Sony Cybershot DSC-S950 Digital Camera
Continuous beep
This is most likely a memory error. You didn't say if you've done any work inside the computer but if you have double check that the ram is seated correctly.
You bios is award and these are the beep codes:
Beep code brief:
1 Long Beep: Memory problem
1 Long Beep and 2 Short Beeps: Video error
Continuous Beeping: Memory or video problem
Any other beep pattern: Most likely Memory problem
1 long Beep: Memory problem
Something is wrong with the memory installed. Check out the troubleshooting memory problems FAQ for details. Note that there could also be something wrong with just accessing the memory (ie the motherboard has a problem).
1 long beep, then 2 Short Beeps: Video error
The motherboard is not able to access the video card for some reason. Either the video card is not working, it's memory is not accessable, or it's BIOS may be corrupt. This error code could also mean something is wrong with the motherboard.
This is a tricky situation... likely the problem is either memory or the video. This can also be found when the motherboard is faulty.
Apr 30, 2009 | AOpen MX3L (91.88110.251) Motherboard
Nokia 6630.Changing Memory problem and phone memory low errors
try again format ur phone,but b4 that,put out ur memory card.after format ur phone,format ur memory card on pc by using card reader.after both format complete,put ur memory in phone,format ur memory card again in phone.ok.try this 1st.send feedback to me.
Jun 21, 2008 | Nokia 6630 Cellular Phone
PC will not reboot.
Check
Click on underlined items for further information
1 Beep
If the PC boots properly, then this beep is normal. It is an audio cue that the PC has passed the POST and started to boot.
  • (AMI) Memory problem
  • (AWARD) Memory problem
2 Beeps
3 Beeps
  • (AMI) Memory or motherboard problem
  • (AWARD) Video problem
  • (IBM) Keyboard problem
4 Beeps
  • (AMI) System timer failure
  • (AWARD) Video Problem
5 Beeps
  • (AMI) CPU or motherboard problem
6 Beeps
  • (AMI) Keyboard or motherboard problem
7 Beeps
8 Beeps
  • (AMI) Video card or video memory problem
9 Beeps
  • (AMI) Motherboard problem
10 Beeps
11 Beeps
  • (AMI) Cache memory error
Continuous Beeping
  • (AMI) Memory or Video Problem
  • (AWARD) Memory or Video Problem
  • (IBM) Power problem or loose card
Oct 28, 2007 | Gateway GX7022E (RBGX7022E) PC Desktop
My serial and password will not register my dvdxcopy
Check
1 Beep
2 Beeps
3 Beeps
4 Beeps
5 Beeps
6 Beeps
7 Beeps
8 Beeps
9 Beeps
10 Beeps
11 Beeps
Continuous Beeping
Oct 28, 2007 | 321studios DVD X Copy Platinum (200000)...
Sony Playstation 3 (PS3) Console Logo
20 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
