Question about Canon F-502 Calculator
I cannot fix the 0.000000 I WANT SINGLE DIGITS NOT DECIMALS T.T
How do you order decimals
We can use this method to see which decimals are bigger:
  1. Set up a table with the decimal point in the same place for each number.
  2. Put in each number.
  3. Fill in the empty squares with zeros.
  4. Compare using the first column on the left.
  5. If the digits are equal move to the next column to the right until one number wins.
Ordering Decimals - Math is Fun
www.mathsisfun.com/ordering_decimals.html https://www.google.co.uk/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=How+do+you+order+decimals
Nov 24, 2016 | Office Equipment & Supplies
How to get the ti89 to show more decimals
In the home screen press the MODE button. On the line display digits choose the number of decimals you want. Here is screen capture from a TI Voyage 200 PLT.
Jan 29, 2013 | Texas Instruments TI-89 Calculator
How do I round off?
Press MODE. Use down arrow to move highlight to the line FLOAT. Then use the right arrow to select the number of decimal digits to display. If you choose 0, there will not be any decimals (integer result), and if you choose 9 you will have 9 decimals. Choose the number of digits according to your rounding needs.
Oct 09, 2011 | Texas Instruments TI-83 Plus Calculator
How do i configure this calcualtor to round to multiple decimals and not the 2 decimal places it defaults to?
Use the middle slide switch of the three between the display and the keyboard.
The far left position sets it to two decimals, the far right position displays all effective digits up to twelve, the inner positions allow you to specify the number of decimal digits.
If you need a manual, you can download one from the manufacturer's web site at
http://www.usa.canon.com/app/pdf/calculator/HS-1200TS.pdf
Jul 26, 2011 | Canon HS-1200TS Calculator
Fix decimals with HP 38G
Press SHIFT MODES, down-arrow to the "Number Format" line and press [CHOOSE], down-arrow to "Fixed," press ENTER, then press right-arrow and enter the desired number of digits to the right of the decimal point.
Jan 01, 2011 | HP 38G Calculator
I am trying to multiply two different decimals (1.5x.005) i get 7.5x10x help i need the out put to be .0075
try to use fix function to reduce the number of decimals to 4 digits then you will get what you want. i hope so.
Oct 07, 2010 | Casio FX-115ES Scientific Calculator
Show more decimals
Press 2nd [FORMAT], type a digit representing the number of digits you want after the decimal point (or 9 for floating), then press ENTER 2nd [QUIT] to get back to calculating.
May 20, 2010 | Texas Instruments BA-II Plus Calculator
I need to fix the calculator to float 5 decimals,apparently it's not floating.
If you want your calculator to display the results with 5 decimal digits:
  1. Open the [MODE] configuration screen.
  2. On first line highlight [NORMAL], if it is not already highlighted and press [ENTER] to validate.
  3. Use Down arrow key once to reach the line Float 0 1 2 3 4 5 6 7 8 9
  4. Use right or left arrow key to highlight the number 5 in the foregoing list (Float 0 1 2 3 4 5 6 7 8 9).
  5. Press ENTER to validate your choice
  6. Press [2nd][Quit] to exit the [MODE] configuration screen.
Mar 14, 2010 | Texas Instruments TI-84 Plus Calculator
Decimals wont show
You need to change the display format.
Press the [MODE] key a certain number of times until the screen displays Fix, Sci, Norm on one line, and 1 2 3 on the next line, with 1 under Fix, 2 under Sci and 3 under Norm.
Press 1 (Fix) followed by a number (1,2,3, etc.) This second number will set the number of decimal digits. In other words, if you press 1 (Fix) 3 all your results will have 3 decimal digits. If you choose 0, your results will not show decimals.
Hope it helps.
Thank you for rating the solution.
Dec 04, 2009 | Casio FX-300MS Calculator
I have a texas instrument TI-36X calculator
Use the [a b/c] key.
7 [a b/c] 11 displays 7u11. Numerator can have up to 6 digits. Denominator can have up to 3 digits
7[1 b/c] 11 [a b/c] 19 displays 7u11u19 meaning 7 and 11/19. The vaiois numbers can have up to three digits each, but the total number of digits must be less than or equal to 8.
The key combination [2nd][d/c] toggles display between mixed numbers and improper fractions.
The key combination [3rd][F<=>D] switches between fraction and decimals. (Not all decimals can beconverted to fractions: see limitations above).
Hoe it helps.
Apr 14, 2009 | Texas Instruments TI-36X Scientific...
Canon F-502 Calculator Logo
57 people viewed this question
old marine
old marine
