Question about KitchenAid KSSP42QKS Side by Side Refrigerator
I have a KSSP42QJS that stop working. Is there a way to rest the fridge other than turning it on and off?
  • KitchenAid Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
No, there is no reset...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Sep 11, 2010
In my fridge, I have a water and ice dispenser -the ice is not working,the water is. The ice compartment is turned on.What else do I need to look for?
just check if the fridge is cool enough. When the rest is cold enough, check the thermostat form the ice compartment.
Feb 16, 2015 | Refrigerators
Freezer keeps building up ice on the condenser i think, and after a few day sitting the bottom part of the freezer freezes and the rest dont
I'm not sure what system you have but typically there is a defrost timer on the back of the fridge. Often you can barely detect where it is, as only the stem sticks out.
What worries me is the amount of moisture in your fridge. You did not indicate how long to make the build up, check your seals carefully with a dollar bill.
Sep 02, 2013 | Refrigerators
Galaxy mini fridge stopped working
The thermostat, which is also an ON_OFF switch has failed (@ 99% probability).
No, the little fridge doesn't have a pressure switch to turn the compressor off when freon is low. And no, auto freon is the wrong kind and it wont work in the little fridge. The freon that your little fridge uses is the stuff that all the fuss has been about (with the ozone layer), so it is not sold to appliance owners but only to licensed techs.
If this is helpful I hope you'll take a sec to rate me. Thanks!
Don
Mar 24, 2012 | Koolatron Mini Fridge Compact Refrigerator
Freezer was working but there was no cooling in the rest of the Fridge.Technicians refilled Gas and also replaced Thermostat.While compressor on,there was a thick ice deposition on the return pipe of the...
You got suckered by the sounds of it.... if your freezer is working your fridge is fine as far as gas charge goes.... thermostat MAY have been faulty but I doubt it.... Your problem probably started a couple weeks ago when the drain that allows defrosted ice (water) to drain into the drain pan at the base of your fridge became plugged for some reason. Then everytime the fridge went on defrost more water melted but did not drain which in turn froze. Now ice has built up and caused the air that flows into the fridge to be blocked, causing a warm fridge.... my advice is to leave fridge unplugged for 48 hrs to thaw it and find the cause of the water not to drain... could be a corn niblet or pea from the freezer... the tube should be visible from the inside or the back
Jul 21, 2011 | Electrolux Refrigerators
Hi, I have an LG refrigerator, the top freezer works fine but the fridge section has stopped cooling, I turned the unit off and next morning there was a large puddle of water on the floor, when I turned it...
When the fridge is not cooling that means the fan are not working or not working properly, need to replace or check if their is an ice bothering the fan to turn. ok
Feb 15, 2010 | Refrigerators
The seperator between my Hot Point side-by-side, the piece of metal that is inside the refrigerator that seperates the fridg. and freezer is very hot, where the doors close on...why???
this is usually an indication that the condensor an has stopped working and is unable to cool the condensor lines and this heat is being transfered to the rest of the fridge .
Feb 02, 2010 | Refrigerators
Bottom of fridge section freezing, rest fine.
maybe fridge fan not working when door is closed could also be iced up air ducts between fridge and freezer
Oct 09, 2009 | Fisher Refrigerators
My ge fridge model # gss20iemcc is only keeping crisper area cool
If you changed the defroster. you know how to take the top apart. Take the fan cover off there is a lover on the cover should be factory set but sometimes they come loose and stop the air from going to the bottom. while you there look to see if it has ice in it. If it dose. the drain may be stopped up.
Ken
Sep 23, 2009 | GE Refrigerators
Candy CPC 290 FF
Hello
Well the sheet of ice was caused by the thermostat failing and causing the fridge to continously run therefore causing the over freezing..
Like a car engine if you leave it running for weeks on end without stopping it probably will burn out...
Or like a horse is you have it working day in day out with out rest it will die..
you compressor on your fridge is no more... it ran and ran and now its all worn out .....
The clicking noise at the back of the fridge is the compressor trying to swtich on but it can't
only a professional can legally change over the compressor
as it is a techincal process recharging the fridge with gas
if you need any other help let us know...
you need a new fridge by the way
Jan 10, 2008 | Candy CPCA270FFK Bottom Freezer...
Icemaker won't freeze - Samsung RS2578SH
Did you ever get any advice for this problem? Please repost if not.
Oct 07, 2006 | Samsung RS2578BB Side by Side Refrigerator
KitchenAid KSSP42QKS Side by Side Refrigerator Logo
57 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
