I get a pair of in smudges on the left side of each printed paper. The pairs of smudges are equally spaced (usually 3 pairs per page). I received a replacement unit today and after putting in my cartridge (old one) it was still doing the same. Is this a problem with the cartridge or the printer itself? I am planning on returning the replacement unit since that it makes sounds louder than a washing machine. I have been using the printer for 2 years now and only for printing/scanning documents for school.
    Problem Solver:
  • 6 Answers
It is either the toner cartrige or the fuser.
Posted on Sep 09, 2010
How to hook up a pioneer 7 band gr 470 equalizer to a Kenwood kr-v6030 receiver
Connect one pair of RCA cables between the receiver and equalizer. Connect one pair of cables to the pre-amp output channels on the receiver and the other end of the cable to the left and right channel inputs on the equalizer. You will usually find these channels on the rear of the equalizer.
May 09, 2016 | Pioneer Audio Players & Recorders
Toner marks
Your Drum Cylinder has a scratch or clot of toner stuck to it. Every time it rotates along the page (usually 4 rotations per A4) it leaves a copy of the defect on the page. If you take the toner cartidge out of the drum unit, you will be able to turn the drum cylinder until you find the fault. Either replace the drum unit or CAREFULLY clean it with alcohol on a cotton ball (meths or iso propoyl will do) in the case of a toner clot. If the fault recurs quickly after cleaning, then you have a damaged drum and it should be replaced.
Best of luck.
Mar 20, 2014 | Brother HL 2140 Laser Printer
My dcp165c printer print quality prints black & yellow colour. i clean print head through maintance 76 but problem cannot be solved
How is the printer printing black and yellow color? Is it a smudge?
When I print, the pages are smudged with ink. What should I do?
Description:
- If smudged stains appear at the top center of the printed page:
  • Make sure the paper is not too thick or curled.
    Also, verify that the appropriate paper is being used and that the paper type set in the machine matches the media used.
  • Make sure the paper is not curled when you print on the back side of the paper with the Print Odd Pages and Print Even Pages settings.
- If smudged stains appear at the right or left corner of the printed page:
- If smudged stains appear on the reverse side or at the bottom of the page:
NOTE: Illustrations shown below are from the representative product and may differ from your Brother machine.
  • Make sure the printer platen is not dirty with ink.
    How to clean the machine's printer platen
    1. Unplug the machine from the AC power outlet.
    2. Lift the scanner cover until it locks securely in the open position.
    3. Clean the machine's printer platen(1) and the area around it, wiping off any scattered ink with a soft, dry, lint-free cloth.
    4. Close the scanner cover.
  • Make sure you are using Genuine Brother Innobella™ Ink.
    > Brother Genuine Supplies information
  • Make sure you are using the paper support flap.
    To use the paper support flap, pull out the paper support (1) until it clicks and unfold the paper support flap(2).
Aug 03, 2010 | Brother Computers & Internet
Toner smudges on paper after printing usually on
check the two levers with an envelope on each, to the left and right of the fusing unit, should be pressed down and not rise up.
Jun 30, 2009 | Konica Minolta magicolor 2400 Laser...
Brother MFC 7820N Smudging Concern
  • Make sure the paper is not curled when you print on the back side of the paper with the Print Odd Pages and Print Even Pagessettings.
  • Make sure you are using Genuine Brother Innobellaâ„¢ Ink.
Sep 11, 2017 | Brother MFC-7820N All-In-One Laser Printer
4 - black ink smudges (1/32" wide x 1/16" high) in right margin
Very nice trouble shooting. The image defect you describe point to the OPC or drum unit this is essentially the toner cart. In your case black. Measureing the distance between repetitive defects is a sure way of diagnosing problems such as yours. Again nice work.
Google repetitive defect ruler for your model to help in the future.
Hope this helps
Apr 07, 2009 | HP Color LaserJet 2600n Printer
Smudge on left side of paper
It seems like your PCU's are dirty and are picking up extra toner. Take them out and look at the green rollers, any extra finger prints or dirt on them? Clean them with a clean paper towel.
Also, check your transfer unit below the PCU's, that may need cleaning or replacing. You can pull that out after removing both PCUs, turn the little screww and look at it. That can also be cleaned with a cleaning wipe or a damp paper towel. There's a little tab that you can turn to free the rollers (they'll still be a little tight) bu then you can turn the rollers to expose more surface area.
Good luck. Be sure to rate the post if it works for you.
Feb 04, 2009 | Ricoh Aficio CL3500N Laser Printer
HP LASERJET 4250n
This problem is with the fuser. It needs to be replaced. They tend to burn out right in the center leaving a rolling smudge across the page as the unfused toner left on the roller gets printed on the next roll-over.
Jan 06, 2009 | HP LaserJet 4250n Printer
Smudges down left side of paper
Maybe something attached (corrector fluid or adhesive)on drum (green cylinder - don't touch it!) or more probably the fixing film on the fusing unit is damaged (probably some paper clip left over input bin, or trying to remove a paper jam with some sharp-pointed thing) If you have some other printer like this around, try with another print cartridge, if error persist , the fuser film is damaged...
Sep 07, 2007 | HP LaserJet 2420 Printer
64 people viewed this question
jasbo
jasbo
