Question about Frigidaire FMV145K Microwave Oven
Our Frigidaire microwave makes HORRIBLE sound when trying to pop microwave popcorn. It sounds like when a microwave "arcs" when metal is place inside, only much louder! It seems to only do this with popcorn, although I might have heard it do this very quietly on other occasions. When the noise occurs, I can also see lights flashing above/behind the ceiling of the microwave oven!!! It is kind of scary!
  • 579 Answers
SOURCE: Frigidaire Microwave will not heat and is a little louder than usual.
High voltage parts are suspect. Need to put a voltmeter on the input (primary) side to the high-voltage transformer (big heavy iron thing in there) Should be getting 120Vac when it goes to cook cycle. Don't touch the other (high voltage) side of this transformer. If the power is there, you are looking at replacing either the magnatron or the high-voltage capacitor and diode. Its affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Hope ya fix it!
Posted on Jan 11, 2008
Richie_asg1
  • 1036 Answers
SOURCE: I was boiling water on
I would say the transformer for the power supply has probably shorted, or another major component in the power supply has shorted - This may be repairable if easily spotted, but most likely will not be cost efective.
Posted on Sep 04, 2008
  • 548 Answers
SOURCE: sparks pops odd burned smell
I would certainly take it to a repair shop if you want to try and salvage it. Until then keep it off and unplugged.
Posted on Feb 14, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: My Microwave oven makes a loud buzzing noise and
Quite often this is due to grease or food particles stuck somewhere in the cavity of the oven or stuck on or behind the waveguide cover.
The waveguide cover (also called a spatter shield) is usually on the right side of the cavity and is about the size of a playing card and often held in place by a plastic rivet.
In some models it is a larger stirrer cover type made of thicker plastic in the ceiling of the oven.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If your waveguide cover is burned, it will need to be replaced.
It provides critical protection for the magnetron.
Your owner's manual may show you how to remove the cover.
You can download owner's manuals and installation instructions for Electrolux and Frigidaire here.
Otherwise, you can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Posted on Jan 31, 2010
costelturcus
  • 43 Answers
SOURCE: Have a built in Microwave
VERIFIC? DAC? NU SA EXFOLIAT TEFLONUL DE LA DISCUL îNVâRTITOR, SAU IZOLATORUL DE MIC? DIN LATERAL DE LA TUNUL DE UNDE ?I D? LA MAS?....
BAFT? !!!
Posted on Jan 18, 2011
Microwave make loud buzz sound occasionaly, mainly if I try to do popcorn but it does it with other food too
Check your waveguide cover / spatter shield for grease or food particles. It may be arcing.
To help you further (with free advice), I would need to full model number and FCC ID number from the label on / in your microwave.
Contact me directly here.*
* FixYa doesn't always notify us Experts when you follow up online
Jan 28, 2018 | Microwave Ovens
Kitchen aid microwave Kcms185j is arcing on the inside ceiling when popping popcorn, but normal when frying bacon?
It may be the oil in the popcorn---do you own one of the covers that go inside to cover so food does not splatter?
Dec 22, 2012 | KitchenAid KCMS185J Microwave Oven
Microwave popping sounds and flashing lights
The magnetron may be arcing, get warm soapy water and remove all food particals from inside of microwave oven until spotless, and check the hood for bare metal.
Mar 18, 2012 | Hamilton Beach Microwave Ovens
Microwave made loud pop when started
It does sound like it may be arcing causing snapping sounds, if bare metal is exposed it will arc and eventually cause the maghetron to fail. It is possible the magnetron is breaking down, but for safety issues it should be checked.
Mar 04, 2012 | Sharp R-1871 Convection Microwave Oven
Cooking with metal probe not fully inserted into ham Frigidaaire Gallery Series Micro....noises occurred ...popping sound....and microwave shuts off....no visual evidence on buttons or surface ...can it be...
Unfortunately when the metal probe was inserted in the ham it caused the magnetron to arc to the probe causing it to short out, but usually the thermal fuse will open and shut the system down preventing damage. It usually takes 30 to 60 minutes for the fuse to reset and allow the microwave to run, try heating water! if you are lucky the oven is unharmed. But if there no change the magnetron will need to be replaced which probably would not be cost effective, cheaper to buy new unit.
Mar 07, 2011 | Frigidaire Microwave Ovens
Microwave turntable guide
it could cause the magtron to arc...becaus the exsposed metal...you can purchase the paint for the inside color of microwave...sand around area..wipe out,,,unplug microwave first....leave door open ,spray it ,let stand couple of hours or 1 day...hope this helps...michael doctorr airr appl.repair 843-384-8474..call if need assistance..good luck
Mar 26, 2010 | GE JES1851 Microwave Oven
Sparks pops odd burned smell
Feb 14, 2009 | Frigidaire PLMV168 Microwave Oven
Dacor Microwave/Conv Oven DCM24S
Placing the bag on an inverted glass bowl or pyrex casserole dish worked!!!!!  For 2 years, I have cursed my Dacor microwave for its inability to make popcorn (burns a hole in the bag, bag stays flat, almost no kernels pop, etc...)  I read the last suggestion to use the glass plate and I am now sitting with a bowl full of perfectly popped popcorn - with only 1 kernel unpopped.  The metal tray in the microwave conducts too many waves through the bag I guess.
Thanks for the solution!
Apr 15, 2008 | Dacor DMT2420 1200 Watts Microwave Oven
GE xl1800 spacesaver microwave
It sounds like you could have one or two problems. Using the oven with metal in it could cause the magnatron to go bad at its tip causing it to arc and making a popping sound. It could be that there is bare metal exposed somewhere causing the popping sound. Take it in for service!!
Feb 23, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
SENSOR ERROR
Did it perhaps sound like someone gargling or growling into a coffee cup?
That's the kind of sound a magnetron often makes when it goes bad.
If you see flashing or arcing (sometimes more visible in a dark room) then there may be grease or food debris on or behind the plastic waveguide cover. It would need to be cleaned or replaced if it were burned.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Please write back with more details if you need further help.
We appreciate your thoughtful rating of our answer.
Nov 07, 2007 | GE JVM1870 Microwave Oven
Frigidaire FMV145K Microwave Oven Logo
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
