Question about Singer Sewing Machines
The thread under fabric gets loose or a bunch of rolls, , once i saw it pretty good for two or three inches long and then next thing it was loose again. Machine is new to me and book is not clear on how to adjust tension or put it apart for cleaning. Model is 500a
    Genius:
  • 1,788 Answers
Study your manual and watch the threading diagram closely, if all else fails take it back to where you bought it and have them show you. I think you should leave the tension alone because you can really mess it up if you do not know what you are doing. You also can call Singer at 1-800-4singer and talk to customer service.
Posted on Sep 09, 2010
Top stitch is fine bottom is loose. Have tried adjusting tension but not working. If I get tension too tight breaks thread so I gradually change tension to no avail. Please help
Check your stitch sample. The loose stitches under the fabric--are they actually top thread???? Usually,stitch problems under the fabric is a result of a top thread problem. In this case, it could be bird nesting.
Remove the top thread from the machine.
Install a brand new needle.
ALWAYS RAISE the presser foot.
Rethread from the beginning.
Sewing Machine Thread Bunching Up Here Why
Birds nest under the fabric big loops of thread top side looks good...
Dec 21, 2017 | Sewing Machines
Have lots of thread on the under side of fabric
Thread nesting or bird nesting resulting usually from: mis-threading, upper thread not seated completely in the tension disk, upper thread tension too loose. HINT: ALWAYS raise the presser foot when threading the upper thread.
What causes Bird Nests Superior Threads
Jan 05, 2017 | Sewing Machines
Bobbin issues the bobbin thread is bunching up
Check whether it is bobbin thread or the top thread accumulating under the fabric. Generally, if thread problems exist "under" the fabric, it is a top thread issue. If the problems exist "above" the fabric, it is a bobbin issue.
Sounds like a thread nesting (bird nesting) problem where the top thread is globbing under the fabric. Usually, this is caused by misthreading (confirm the thread path), the thread not seated in the tension disk (ALWAYS RAISE the presser foot when threading!), or very loose top thread tension.
Remove the thread. Raise the presser foot and rethread from the beginning. Check that the thread path is correct. Set the upper tension at the midway point between high & low numbers (this is the beginning point for tension and will most likely need to be tweaked for your particular machine).
Dec 11, 2016 | Sewing Machines
Phaff 1472 stitches are bunching up underneath
That is thread nesting or bird nesting. Could be the result of several things, but main reasons are upper tension too loose and the thread not being completely seated in the tension disk.
Nov 17, 2016 | PfaFF Sewing Machines
Thread is getting bunched up in machine
First thing: install a brand new needle.
Second: remove upper thread. RAISE the presser foot and rethread from the beginning. Set upper tension to the midway point between high & low numbers.
These links may be helpful:
5 Common Causes of Birdnests
Why Do Get Bunched Up Thread Under My Fabric
WHY IS THREAD BUNCHING UNDERNEATH MY FABRIC
Feb 04, 2016 | Sewing Machines
Cotton is loose/looping under material?
Sounds like bird nesting.
The #1 thing is to install a brand new needle (old, worn, nicked, or bent needles can create a lot of havoc).
Remove all the thread from the machine. RAISE the presser foot and rethread from the beginning verifying that it is threaded correctly. Make sure the bobbin is loaded and threaded in the bobbin case properly.
8 Tips to Fix Birdnesting in Embroidery
Jan 28, 2016 | Sewing Machines
TENSION IS NOT RIGHT IT IS LEAVING A BUNCH OF THREAD ON THE UNDERSIDE
Hi there.
When ever you have bunching thread like that it can be a few things.
1. Not properly drawing the threads back under the foot when beginning a seam (grasp both and gently draw them to the back of the machine when starting.)
2. Your feed dogs could be down or not adjusted well.
3. Your top tension is too loose for the fabric or top thread is not threaded properly. (this is usually the problem)
4. bad or wrong needle for the fabric.
Thread can be an issue as well, it does age and get frayed causing problems.
First make sure you test on a scrap of the same fabric. Tighten your upper tension to see if that helps. If not RAISE your pressure foot and read thread the top thread making sure the thread sits in the uptake lever. Try again on your scrap.
Good luck.
Mar 13, 2011 | Janome Sewing Machines
The thread bunches up under the material when i sew. thread then clogs up under the plate.
first start with the needle & see if it's bent-roll the needle on a flat surface & see if it roll correctly
when a needle is blunt it makes a popping sound when it goes thru the fabric
check the bobbin to see if it's warped-I have had some that were
check to see if there is lint or loose thread in the bobbin case area
rethread the machine to make sure the upper thread is not catching on anything
sometimes the thread can come off the thread take up lever
& sometimes it can get caught on the spool pin & also on the notch that's on the thread spool it's self---I've had this happen before
if you sew alot-good maintenance practice is to clean the bobbin case area at least once a week-if you don't sew alot-once a month & also under the needle plate
when cleaning under the needle plate-make sure you do not damage the top of the screws when you remove them to clean under the needle plate & because if the top of screws get damaged they can pull the fabric when the fabric goes over them
check also to make sure your top tension is correct
Sep 02, 2010 | Brother LS-2125 Mechanical Sewing Machine
Top thread bunching under fabric when sewing
tension could be too loose. start with bobbin tension- should allow thread to pass with SLIGHT resistance. then adjust top tension at about 2-3 to start.
Jun 01, 2010 | Singer 8280 Mechanical Sewing Machine
THREAD GET BUNCHED UP UNDERNEATH THE FABRIC, THE STICHES SEEM TO BE INCOMPLETE THE TOP LOOKS GOOD THAN I TURN IT OVER AND THE THEAD IS BUNCHED AND LONG LOOPS OF THREAD ARE LEFT. THANKS LOU
Hi Lou! This sounds like a tension problem--the tension on the top thread is too loose. Try using different color threads on the top and bobbin, then carefully rethread everything. Stitch a couple of inches and check the underside. If the top stitches look fine and the bottom ones are loose and loopy, and with the pressure foot down, tighten the tension. Move the knob or dial (whichever you have) just a little bit. Sew a couple of inches more, and recheck. Continue to sew and recheck, gradually tightening the tension, until you see little if any bobbin thread on the top or top thread on the underside of the fabric.
Let me know if this helps, ok?
Robbie
Jan 27, 2010 | Singer Sewing Machines
Sewing Machines Logo
178 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
