Question about Toshiba Satellite A105 Notebook
The toshiba wont turn at all, i got to turn on once but after that it wont turn on, every on the the laptop works but i can get it running
  • 2,567 Answers
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced.
Posted on Sep 19, 2010
I hhave a toshiba sat and it wont get out of the boot screen. Windows wont load. I dont have a windows cd
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on the hard drive then follow these steps to restore your Toshiba to the Out of the Box condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power button once to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the system recovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running. Follow the prompts that appear on the screen to set up the laptop's date, time and language settings.
Jan 29, 2013 | Toshiba Satellite Computers & Internet
Older Toshiba laptop runs on battery, but not AC cord.
on some older laptops the battery has to be installed for it to turn on.
if the battery don't hold a charge it's no good.. but you need it to get power from plug.
Jan 04, 2013 | Toshiba Computers & Internet
Im having problems with my Toshiba Satellite L455DS5976 it wont start up. it will go to the normal toshiba screen when you turn it on but after that the screen goes blank and theres a white line what...
I had the same problem. Let it run that way for about 5-10 minutes, it should show a menu, choose START WINDOWS NORMALLY.
It will take some more time to boot, be patient. Once you start it, do the clean up, virus check and delete everything you don't it. That worked for me.
If this helps, please rate. Thank you
Jan 15, 2011 | Toshiba Satellite L455DS5976 Notebook
Laptop wont turn on, lights flashing, fans running
Sounds like your power circuit on the motherbard is cooked...really cheapr to buy a new one than to have that one repaired.
Mar 31, 2010 | Toshiba Satellite A305D-S6835 Notebook
My toshiba wont charge or turn
check properly your adaptor connector and try to use temporary battery, if might be work or on your laptop... go to computer center now...
Jun 18, 2009 | Toshiba Satellite A60 Notebook
Toshiba Satelite M100 PC notebook wont start up windows XP
This sounds like a memory problem. Download and run memtest 86, it is a small iso file that you create a bootable cd from. Run this for at least one pass.
If the memory passes boot from your xp disk and choose R to get into the repair console. Once there type the following commands
fixboot
fixmbr
then try the install again. Hope this helps
Apr 29, 2009 | Toshiba Satellite M100 Notebook
Turn on/off the ''red keys'' on my Toshiba Satellite 350L laptop?
Hey guys i had the same problem with my toshiba laptop where i couldn't get it to stop inputting the red keys. i fooled around with my keys a little and found out if you press ctrl+shift either once or twice, it will revert back to the normal keys. At least it worked for me, best of luck to you guys.
Apr 15, 2009 | Computers & Internet
Toshiba quosimo f45. laptop wont boot at all ,fixed once by them
hi there,
dont panic brother,
try theses things.
--> take out battery
--> connect the power cable
--> wait for a minute
--> turn it on
--> it will work
if not
--> take care power cable out
--> put the battery in
--> turn it on
--> and it will work (try to move the lid up and down)
if not
--> charge the battery dont turn it on
--> when its full take of the power cable
--> wait for 30 sec
--> turn it on
--> it will work ((try to move the lid up and down)
if not
--> keep the power cable
--> turn it on
--> it will work (try to move the lid up and down)
best of luck
Mar 23, 2009 | Toshiba Qosmio F45-AV410 Notebook
Battery discharges, and will not charge, computer wont run on AC
how long have you had your laptop? the toshiba laptop battery can be normal used in 400-500 cycles, that means normal in 2 years. if the age is over 2 years, the battery declines day by day. get a new one if it is unnormal
Dec 04, 2008 | Toshiba Satellite P35-S609 Notebook
Toshiba Satellite A105 Notebook Logo
76 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
