Question about RCA L32WD22 32 in. LCD HDTV
My TV keeps changing the input selection. How do I stop this? I could be playing a game on my PS3, then the TV will change to analog channels, go to a black screen, then back to my HDMI input.
JSPCEXPRESS
  • 178 Answers
SOURCE: no input signal hdmi
Are you on the correct video source on the TV
Posted on Feb 10, 2008
SOURCE: RCA Scenium HDLP61W151
RedRacer guy, you are awesome! I had the same problem as the 2 other people with this issue. I did the reset on the "reset all" on the ethernet connection not expecting this to do anything and as I exited this, the TV came on!
Thank you, Thank you, Thank you!
Posted on Mar 21, 2008
  • 1030 Answers
SOURCE: No sound and analog channels
THis is been an issue with these sets. Rca has issued a bullteen on these sets.. There is a problem with the digital board. you cant get them... but the fix is to replace a small(very very small ) suface mounted fuse on the board... most qualifed tech can do this repair. so if you can solder surface mounted componets ussally takes twezzers and a big lighted magnifer.. and if you can get the special surface mounted fuse(seems to be a shortage of them) Replacement fuse #275819. u might can fix this. repair is possible
Posted on Jun 10, 2008
mistersony
  • 320 Answers
SOURCE: Bravia KLV-S40A10 HDMI input
I agree with your solution and you are correct in that you lose very little quality by using component instead of HDMI. there are A/V receivers that transcode HDMI inputs to component; as far as I know that's the only other option
Posted on Oct 19, 2008
ccmg60
SOURCE: Sharp Aquos LC-37D64U Skips HDMI
The problem was caused by ME not setting up my Harmony Remote correctly after buying the new TV. The remote was programmed to turn on SA8300>turn on Receiver>Turn on TV>Select channel 3.
Simple change from select channel 3 to select Input 4.
Posted on Mar 26, 2009
How do i get my Panasonic ct1388yd to register it's picture and its sound of my game console
The modulator is outputting channel 3 or 4 analog not digital. Channel 3 digital is not channel 3 analog. You have the opposite problem of those trying to receive TV on an older Analog TV. You need to rescan your channels to add the analog input. Assuming you TV still scan for those like mine does.
P.S. - BNC!!! Really?? I only see those on security systems these days.
Apr 16, 2015 | Sega Video Game Consoles & Games
To play videogames on an old tv PLEASE HELP
You'll need to switch the TV into Video mode. Most TV sets will have a button on the front panel labelled "input" or "tv/video," and pressing this button will cycle through the various inputs your TV has.
Alternatively, this button may be located on your remote control.
Rarely, no button exists, and video input is selected by changing the channel below channel 2; as if you were trying to select channel 1. This will select the video input on sets without a separate input selector button.
Dec 20, 2012 | Televison & Video
How do we scan/program in local tv channels. We bought an external antenna, but get no picture. Typically, there is a protocol for scanning channels into the set. Model is Sansui TVS2746B, and the set was...
Okay, does this tv have a built in DIGITAL tuner? Most tv's only have an analog tuner. You can tell the difference while you are changing the channels. If the channel indicates 2.1 or 2.2 and so forth, it is on a digital channel mode. If you change the channel and it indicated 2, 3, 4, etc. it is analog. If it has digital capability change the input until you see 2.1, 3.4 etc. If you cycle through all the inputs on the tv like, input 1 (TV) input 2(DVD) input 3(HDMI) and so forth and you never see the digital channel you most likely do not have a digital tuner. You will need to purchase a digital converter which will convert it to analog and you can watch it by placing you tv on analog channel 3 just like the old vcr's. Hope this helps and please don't forget to rate this solution.
Jan 22, 2011 | Samsung TSL2793HF 27" TV
Hooked up ps3 using hmdi cable worked not working now using the
mpc heesman1 might be right...
However. I´m inclined to think that you did change the input on your TV. So your problem is another, this is what you have to to to reset:
1. Unplug the HDMI cable from both the TV and PS3.
2. Plug in the AV MULTI OUT cable (the red, white, yellow one provided along with the system) to both your PS3 and TV.
3. Set the TV input to the correct one and turn it on.
4. turn on the PS3 with the front button but DON´T release it, keep your finger on it, until you hear a second beep, thats when you release the button, the PS3 will start to identify what it´s connected to and will display it on your TV.
Hope it helps.
Jan 12, 2010 | Sony Playstation 3 (PS3) Console
When i plug my hdmi cable into the back of my PS3, it says no input on my TV ?
you need to connect both the yellow red white cable and the hdmi cable into your ps3 and go the yellow red white av channel
go to the ps3 settings and change the video settings (ithink) to hdmi and also change the sound to hdmi
the screen will go blank and then the tv should change to the hdmi av channel if not change to it and accept the changes
Dec 13, 2009 | Sony Playstation 3 (PS3) Console
I had a hdmi but my tv broke and im using difrent hook ups but nothing shows up how do i fix this so i can play agen
Make sure the system is turned off.
Then, hold down the power button for 5-6 seconds, until you hear a second beep.
The video settings will then be reset!
Aug 01, 2009 | Sony Playstation 3 (PS3) Console
Av connections not giving signal to tv
you have to manually change the output in the settings menu back to ANALOG Using an HDMI TV or monitor 1st, when you select RCA, or AV output and restart, it will work, but when you switch back, you have to change it (back to HDMI output) on the analog monitor, or use analog TV inputs, then reboot PS3 and connect HDMI.
I do not know why Sony did not make this switch automatic and self scanning on boot, but alas I have had the same issue, so I know this is your problem, not the AV cables.
Please give a fixya rating if you find this solves your problem, Thanks for the question
Apr 12, 2009 | Sony Playstation 3 (PS3) Console
PS3 connection
If I remember correctly the Playstation 3 is set to display through the analog output as default.
Plug in your HDMI cable, and plug in the analog SCART cable that came with the box, put your TV on the analog channel that matches the SCART input and start the Playstation. Once you complete the initial Playstation setup you can go to system settings and change the video output from analog SCART to digital HDMI.
Good luck.
Jan 31, 2009 | Video Game Consoles & Games
Unusable signal prompt on video input
be sure to cycle thru the input selections-- either w/Remote (input button), or channel +/- on the panel. my truflat 26" hd set has side/front/video1 video2 inputs, yours may have more or less. also, be sure you've plugged into an INPUT set, not an OUTPUT set. Does sound work otherwise on this set? If not, maybe interal speakers (menu setting) is set to off/not checked.
And on your PS3--goto the settings menu, sound outputs, make sure you select A/V connector and analog sound. The ps3 cable can become sloppy too, wiggle/check/reseat or try another cabe (usually video is touchy more than the sound though)
If you KNOW you've got the right input selected and the PS3 is setup properly, do you have another device with audio output to test on the TV? a notebook computer, walkman, cd player--anything that has rca outputs for sound--quick swap the cables to the new 'test' device-- if sound is OK with test device, either PS3 setting or cable is bad/wrong. if no sound from test device on TV either the tv is not using proper inputs, or is damaged, or the test device is not properly configured. If you have another input receiving device to test the ps3 output sound, like the LINE INPUT on a notebook computer, or a boombox with Aux inputs, test the PS3 sound output too.
Jun 08, 2008 | RCA TruFlat 27F520T 27" TV
RCA L32WD22 32 in. LCD HDTV Logo
195 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
