Question about Sport & Outdoor - Others
Tiga speed sailboard manual - Sport & Outdoor - Others
What kind of transmission ssangyong musso 2001
2.3 Gasoline: All wheel drive, manual 5 speed
3.2V6 gasoline, AWD, automatic 4 speed
2.3 TD All wheel drive, manual 5 speed
2.9 TD All wheel drive, manual 5 speed
Mar 17, 2017 | SsangYong Cars & Trucks
Tip
General Motors gear ratios hide] 1 GM Rear Wheel Drive...
hide]
GM Rear Wheel Drive Transmissions
PTU = Power Transfer Unit (Crossover SUV AWD/4WD)
6 Speed Automatic Transmissions
RPO Trans Name 1st 2nd 3rd
MNK Allison 1000
MNZ Allison 1000
MW7 Allison 1000
MYB
MYC
5 Speed Automatic Transmissions
M74 Allison 1000
M22 5L50-E
M82 5L40-E
MTW Allison 2400
MX4 Allison 2000
MX5 5L40-E with PTU*
MV3 5L50-E with PTU*
4 Speed Automatic Transmissions
M30 4L60-E
M32 4L60-E HD
M32 4L65-E
M33 4L60-E Hybrid
M41 4L30-E
M70 4L70-E Super Duty
M99 2ML70 2-mode Hybrid*
MD8
ML4 4L30-E
MN8 4L80-E HD
MN8 4L85-E
MT1 4L80-E
MW9 HM 200-4R
  • EVT Mode 1 The 2ML70 can operate in electric mode or non-electric mode in first gear with a gear ratio of infinity to 1.70:1.
  • EVT Mode 2 The 2ML70 operates in non-electric mode with a gear ratio of 1.70 - 0.738:1
3 Speed Automatic Transmissions
M40
M41
M65
MD2
MD3 HM-180
HM-200C
HM-350
HM-400
GM Front Wheel Drive Transaxles
6 Speed Automatic Transaxles
MH2
MH4
MH6 6T75 (AWD)
MH7
MH8
MY9 6T75 (AWD)
5 Speed Automatic Transaxles
Aisin-AW 55-51LE
M09 Aisin-AW AF33-5
M43 Aisin-AW AF23-5
M45 Aisin-AW AF33-5
M98 AF33-5
MJ7 Honda 5AT
MJ8 Honda 5AT w/PTU*
MLS Aisin 50-40E
MU3 Saab 76.5mm
4 Speed Automatic Transaxles
MLQ Aisin 81-40LE
Aisin ZF 4HP 16
HM 325-4L
Jatco JF405-E
M10 Jatco JF403-E
M13 4T60-E HD
M13 4T60-E
M15 4T65E
M45 Aisin-AW AF33
M57 A245-E
M76 4T65E with PTU*
MD7 4T65E
ME7 4T45-E BAS Hybrid
ME8
ME9
MH1 4T80-E
MN3 4T65E
MN4 4T40/45-E
MN5 4T45-E
MN7 4T65E HD
MS7 A240-E
MU4 A246-E
MU5 U341-F
3 Speed Automatic Transaxles
M60 GEO Metro
MB3 A131L
MD9
MX1 A131L
GEO Storm
HM-425
GM Manual Transmissions
6 Speed Manual Transmissions
M10 Tremec 85mm
M12 Tremec T56
ML6 ZF S6-650
ML9 ZF S6-40
MM6 Tremec T56
MV1 Aisin 85mm
MV5 Aisin D173 AY6
MV6 Aisin 85mm
MZ6 Tremec 85mm
5 Speed Manual Transmissions
M35 Getrag 260
M35 Getrag 260 (2003-2004 Cadillac CTS)
M49 BW 5spd
M50
M59 GEO Tracker
M86 Getrag F23 75mm
M94 Getrag F23
M96 Tremec 109mm
MA5 Aisin AR5 82mm
MG3 Getrag F23
MG5
M50
M51
MH3 Tremec T-5
MK5 C59
ML2 Tremec T-5
ML3 Tremec T-5
MT8
MU3 Saab F25
MW2
MW3 NV4500 109mm
TR-3450
TR-4050
TR-4050
2007 Chevrolet Optra and Spark (Trans code Y4A)
2007 Chevrolet Optra and Spark (Trans code Y4M)
4 Speed Manual Transmissions
M20 HM-117
M73 Isuzu
MC0 Getrag
MC9
MY6 NP260
More GM Manual Transmissions
6 Speed Manual Transaxles
MT2 Opel F40 83mm
MU9 Opel F40 83mm
MTN Toyota C60
5 Speed Manual Transaxles
D-16 (2005-2008 Chevrolet Aveo 1.4 DOHC / 1.5L)
D-16 (2005-2008 Chevrolet Aveo 1.4 SOHC)
Y4A (2007 Pontiac Matiz)
YM4 (2005-2007 Chevrolet Aveo)
D-20 (2005-2007 Chevrolet Epica)
L73 Pontiac LeMans F16
M42 Geo Metro
M43 AF23
M49 BW 5spd
M58 Geo Metro
M79 LeMans F13
M86 Getrag F23 (5T45MI)
M94 Getrag F23
M98 Aisin 55-51E
MB4 Geo Prizm 1.8L
MB5 Geo Prizm
MFB 2008 Chevrolet Epica 5-Speed S/R (D24)
MFN 2008 Chevrolet Epica 5-Speed S/R (D33)
MG1 HM-282
MG2 HM-282
MG3 Getrag F23
MJ1 Isuzu
MK7 Isuzu
MLM Y4M (2008 Chevrolet Aveo 1.6 DOHC)
MR3 Isuzu
MU3 Saab F25
MV2 Chevrolet Sprint
MY7 Early J-car
GM Continuously Variable Transaxles
RPO Trans Name Lowest Highest
M83 V20-E
M75 V25-E
M16 V25-E AWD
on Apr 15, 2015 | GMC Cars & Trucks
99 gmc all the lights on 4 wheel drive control are lit up
GMC What ?
Which one of these does your vehicle have ?
Transfer Case - BW 4401 (Two Speed Manual)
Transfer Case - BW 4470 (Two Speed Manual)
Transfer Case - NVG 241-NP2 (Two Speed Manual)
Transfer Case - NVG 243-NP1 (Two Speed Selectable)
Transfer Case - NVG 246-NP8 (Two Speed Automatic)
Dec 14, 2016 | GMC Cars & Trucks
Are 1996 4x4 jeep an 1994 4x4 jeep transmissions compatible with each other?
well both transmission have a name. as does car.
there are many offered new.
stick shift or auto.
what jeep you never said which one,
the wranger, the cherokee or the grand?
what? (a 96 wranger is 95 , they skipped 96 year)
ill roll the 3 sided dice for you and lands on XJ
amazing huh? that many.! min had #3 and other jeep has #2
4-speed Aisin AX-4 manual
5-speed Aisin AX-5 manual
5-speed Peugeot BA-10/5 manual
5-speed Aisin AX-15 manual
5-speed NVG NV3550 manual
3-speed Chrysler A904 automatic
3-speed 30RH automatic
4-speed Aisin AW-4 automatic
Aug 27, 2015 | Jeep Cars & Trucks
Pagsasanay sa pagwawasto ng sipi
linte!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Aug 09, 2013 | Computers & Internet
Kode pengaman nokia 2730c-1
(Bahasa Indonesia di bawah ini.)
This is from the Nokia 2730c manual:
"Access codes
The security code helps to protect your phone against unauthorised use. The preset code is 12345. You can create and change the code, and set the phone to request the code. Keep the code secret and in a safe place separate from your phone. If you forget the code and your phone is locked, your phone will require service and additional charges may apply. For more information, contact a Nokia Care point or your phone dealer.
The PIN code supplied with the SIM card protects the card against unauthorised use.
The PIN2 code supplied with some SIM cards is required to access certain services. If you enter the PIN or PIN2 code incorrectly three times in succession, you are asked for the PUK or PUK2 code. If you do not have them, contact your service provider.
The module PIN is required to access the information in the security module of your SIM card. The signing PIN may be required for the digital signature. The barring password is required when using the call barring service.
To set how your phone uses the access codes and security settings, select Menu > Settings > Security."
Google translation:
Ini dari Nokia 2730c manual:
"Kode akses
Kode pengaman membantu melindungi telepon Anda dari penggunaan yang tidak sah. Kode awal adalah 12345. Anda dapat membuat dan mengubah kode tersebut dan mengatur telepon agar meminta kode. Jaga kerahasiaan kode dan di tempat yang aman terpisah dari telepon Anda. Jika Anda lupa kode dan ponsel terkunci, ponsel harus diperbaiki dan mungkin dikenakan biaya tambahan. Untuk informasi lebih lanjut, hubungi pusat Nokia Care atau dealer ponsel Anda.
Kode PIN diberikan bersama kartu SIM melindungi kartu dari penyalahgunaan.
Kode PIN2 yang diberikan bersama beberapa kartu SIM diperlukan untuk mengakses layanan tertentu. Jika Anda memasukkan PIN atau PIN2 sebanyak tiga kali berturut-turut, Anda akan diminta untuk PUK atau PUK2. Jika Anda tidak memilikinya, hubungi penyedia layanan Anda.
PIN modul diperlukan untuk mengakses informasi dalam modul keamanan kartu SIM Anda. PIN tanda tangan mungkin diperlukan untuk tanda tangan digital. Sandi pembatasan diperlukan bila menggunakan layanan pembatasan panggilan.
Untuk menetapkan cara ponsel menggunakan kode akses dan pengaturan keamanan, pilih Menu > Pengaturan > Pengamanan."
Aug 12, 2012 | Cell Phones
I wanna to know the mpg on a 93 mecury topez. 4 cyl 2.3 l
Manual and autoTransmission: EPA city/hgwy
City and Highway: 5-speed manual: 23/33
" " " 3-speed automatic: 21/26
Real world Average city and highway combined MPG test by Consumer Reports: 5-speed manual: 21.5
3-speed automatic: 19.4
Mar 21, 2011 | Mercury Topaz Cars & Trucks
Akun keamanan saya hilang
Anda bisa mendapatkan password baru, pengingat Yahoo ID, atau keduanya. Jika Anda lupa Yahoo! ID atau sandi Anda, pergi ke halaman Daftar-in Masalah.
Jika Anda lupa ID Yahoo!, Anda harus memberikan tiga informasi sehingga kita bisa memastikan identitas Anda:
Anda ulang tahun
Anda ZIP atau kode pos (pada saat Anda membuat akun Yahoo! Anda atau ketika Anda terakhir diperbarui)
Anda alternatif alamat-email Catatan: Anda harus memiliki akses ke alamat email ini
Kode negara (pada saat Anda membuat akun Yahoo! Anda atau ketika Anda terakhir diperbarui)
Jan 12, 2011 | Yahoo Mail
Sport & Outdoor - Others Logo
73 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
