Question about Frigidaire Refrigerators
My Frigidaire Refrigerator FRT18TPHw1 freezes everything in both Freezer and Frig. However, some things I put in the veg bins does not freeze. It is 10 years old and wonder if the repair is more than getting another one. I am retired on SS and limited finances. I thought possibly I could fix it myself. Thank you for any help you can give me.
  • Frigidaire Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 11, 2010
Refrigerator thermastat set to 37 degrees but registers at 28. Freezer set at 0 degrees but registers at -2. Frig/freezer do not feel that cold but vegetable bin (produce bin) in refrigerator is...
i have never seen the problem
my idea is the thermostat is bad. but won,t both of them be bad.
you try to check the damper motor swithch and damper motor
good luck
Jan 12, 2011 | Frigidaire FRS26R4A Side by Side...
Refrigerator is freezing everything in door and on middle lower and veg bins.
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 05, 2011 | Kenmore Refrigerators
FROZEN veg./FRUIT
Broken damper not regulating air from freezer
Mar 03, 2010 | GE GSS25SGMBS Side by Side Refrigerator
We put things(meats,water,veg.) anything but
check the cold deflector door for proper operation, then check the cold control itself as it may be defective
Nov 01, 2009 | Freezers
Frigidaire refrigerator does not seem to be cooling or freezing completely. Frigidaire refrigerator does not make any noise and does not seem to be cooling or freezing. I have checked the back of the unit...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
nmnm
Sep 24, 2009 | Frigidaire FRS3R5EMB Side by Side...
Frigidare refrigerator FRS26ZTH FREEZER FREEZING UP/FRIG NOT COOL
also check defrost timer,defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 01, 2009 | Frigidaire FRS26R4A Side by Side...
Freezing in frig.
Check the air dampers at the bottom of the fresh food section.They may have been moved to a open position. If so close them up some.
Otherwise the cold control thermostat may need to be replaced.
Mar 21, 2009 | GE GSS25SGMBS Side by Side Refrigerator
Food freezing in frig
Go to the link below and the choose line 22 and click it. That link page helps identify most common problems you may have with your refrigerator, Thanks Sea Breeze.
 http://www.applianceaid.com/refrigerator.html
Sep 11, 2007 | GE Profile PSI23NCR Side by Side...
Freezer not freezing
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, controls should be in the middle setting, you can try turning freezer to Warmer freezer allowing MORE air to refrigertor side.
Sep 05, 2007 | Frigidaire FRT17G4B Top Freezer...
Refrigerators Logo
102 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
