Kenmore 11092375100 HD Series 70 washer will not drain. Washer fills and agitates OK. When cycle switches to drain, a hum can be heard towards the back of the washer (like a seized motor or pump?). Problem is not the lid switch, as the hum stops when lid opened, and resumes if lid switch is manually pressed with a pencil.
  • dkkramer Sep 09, 2010
    Hmmm. Suspicions confirmed. I'll pull the motor and have it checked out. Any suggestions on what to look for to determine if the motor is bad? Will the drive shaft turn by hand if it is ok, and not if it has issues? Thanks for pointing me in this direction.
    President:
  • 1,554 Answers
This is a direct-drive washer and the pump is directly coupled to the rear spline of the motor making the pump run both during agitation and draining/spinning. Water is being pumped in during agitation then the motor reverses during the drain/spin cycle turning the pump to pump out water. The pump will therefore not work if the motor is seized.
The machine agitates therefore the motor coupler is not the issue and the lid switch is working as stated. These information and symptoms clearly indicates that the motor is seized as characterized by the hums and the pump not working. The rotor is locking up due to a faulty motor or the transmission is malfunctioning and locks up preventing the motor to run.
Replace the motor if the rotor is locking up. The transmission, brake, and clutch assembly need thorough investigation to determine where the restriction is coming from if the motor turns out good.
Posted on Sep 09, 2010
  • Jahn27
    Jahn27 Sep 09, 2010
    The rotor may turn freely when not powered even it is faulty. Locking up of the rotor may be evident only when the motor is powered. Just remove the motor coupler to isolate the motor from the transmission then set and run the machine in the drain/spin cycle. You need to bypass the lid switch for the machine to run with the cabinet removed.
Hello, Have a Kenmore series 70 (capcity plus).
Note after reading a bunch of information. I went home and removed the hose from the Level Switch and "clean it", if you will and re-attached. Started a load, and bingo bango bongo, it work. Thanks for the insight.
Nov 30, 2009 | Kenmore 22422 Top Load Washer
Washer wont agitate or stop filling on any setting
Hello Friend, Just replace the water pressure/level switch. Replacement will make it fill correctly and agitate. Happy to help.
Nov 18, 2009 | Kenmore 24712 Top Load Washer
I have a kenmore heavy duty, series 70,# 82872120.. It makes a humming noise and will not complete the rinse cycle or the spin cycle.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.82872120
If it goes through the agitate cycle, the motor and transmission are probably OK.
If it goes through the initial drain / spin cycles after the first agitate cycle, the Lid Switch is also OK.
The humming could likely be the timer motor. Try to manually move the timer to the rinse cycle. If the washer responds, the problem points to the timer itself.
See the sub component section on the Sears site for the Console.
The "Alt" part numbers are Whirlpool parts that can likely be purchased from a variety of on line or local parts stores.
Sep 26, 2009 | Kenmore Washing Machines
Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Jun 30, 2009 | Kenmore Washing Machines
Kenmore 70 series filled and stopped...
Lid switch problem. Press down on lid and try to start machine. Reply.
Jun 15, 2009 | Kenmore 22422 Top Load Washer
Kenmore 90 series that wont agitate or spin
Could be the door switch, do you hear a clicking sound when you close the lid?
Does the motor hum at all in drain/spin?
Mar 12, 2008 | Kenmore 45981 Washer
Kenmore 70 Series Washer
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Washing Machines Logo
102 people viewed this question
Top Washing Machines Experts
