Diagram for a cognac 20010412 need to know pin config for pwr-hdd--ect
5 Suggested Answers
SOURCE: Intel D845WN motherboard
www.premioinc.com/pc/manuals/mb/845si/845si.pdf page 95.
Posted on Oct 06, 2007
map9966
  • 2351 Answers
SOURCE: d815 led and etc pins
Looking at page 85 in you're user manual. The 15 pin jumper block. Starting at Pin 1 (Hard drive LED) is positive + & pin 3 is ground -. Next, Power LED, Pin 2 is + & pin 4 is ground - .
Letter C, is for the reset switch, Pin 5 is + & pin 7 is - .
Power on/off switch, pin 6 is + & pin 8 is - .
The letter I is used for the internal speaker. The positive pin number 16 & ground pin number 10, letter G. If you need the manual you can download it from this link.
ftp://download.intel.com/support/motherboards/desktop/D815EEA2/EA2FV_English.pdf
Included below is a small pic.
e8e7d5a.jpg Good Luck!
Have more questions? Please feel free to ask.
Mike
Posted on Jun 02, 2008
  • 56 Answers
SOURCE: Connection Diagram for MSI N1996 motherboard
GOTO MANICATURE WEB SITE TECHN SUPPORT MOTHERBOARD LAYOUT DIAGRAMS
TRY MOTHERBOARD.ORG
IM PRETTY SURE THAT MSI DOES HAVE A WEB SITE ON THE INTERNET
CANDYMANGANDY
Posted on Jan 27, 2009
johncaman
  • 201 Answers
SOURCE: I NEED THE PIN OUT DIAGRAMS FOR K9N6PGM2-V MOTHERBOARD
Hi, here's the link for the manual, with the pinout diagrams:
http://global.msi.com.tw/index.php?func=downloadfile&dno=6801&type=manual
Please rate if you find this helpful :)
Posted on Mar 16, 2009
Dell motherboard diagram of wiring and front pannel connectors
most front panel connectors with a 4 x 5 pin configuration are intel compliant, and are all the same.
The "nine" pin is missing, and is the "KEY" to orientation, no matter which way the pins are situated on the board.
1 3 5 7 X
2 4 6 8 10
1= HDD LED+, usually green
3= HDD-, usually white or black
2= PWR LED+, usually red
4= PWR LED-, white or black
These are polarity specific, and must be connected to the proper + and - terminals to work properly
5= RESET
7= RESET
9 is missing, can be used to determine location of other pins
6= PWR
8= PWR
Thes are momentary contact pins, can't get them backwards
Pins 6 and 10 are jumped together in the Dimension 2400.
Apr 18, 2014 | Dell Dimension 2400 PC Desktop
I need the wiring diagram for emachine model D6405
Usually it is in very small print right on the motherboard next to the pins, use a flashlight and/or a magnifier to see what order the pins go in. The hard drive light will say HDD, power will say PWR, etc.
Nov 26, 2011 | E-Machines eMachines Desktop PC
661m04-mx-6l foxconn motherboard i need a diagram to tell me where the pins go onto the motherboard the ground ones reset power hdd ect ect ect.
All motherboards use the same pin connections for the front panel switches and led's.
There is a nine pin connector. 5 pins on the top row 4 on the bottom.(orient the board to get this view)
Starting with the top row , Pled+, Pled-, PWR SW, Ground. empty pin.
Bottom row. HDLED+, HDLED-, Ground, Reset, dummy pin.
Jan 09, 2011 | Computers & Internet
Unpluged HDD LED PWR S/W and PWR LED for board
it's usually written in fine print beside pins. Failing that get the manual which tells you
Feb 26, 2010 | E-Machines T3958 (827103050974) PC Desktop
I have an 945gzt-m v 1.0 and dont know were the pwr sw wire goes
Yes.
First, let's orient the view of the motherboard, so we are both looking at it the same way.
The processor is at the top middle, and the Front panel header, is to the very bottom right hand corner.
Right next to the motherboard mounting hole.
The Front Panel header goes across the bottom edge of the motherboard, lengthwise.
Looking at the top row of pins on the Front Panel header, No.2 Pin is at the far left. Pins 2, 4, 6, 8 and 10, go across the top.
Looking at the bottom row, No. 1 Pin is at the far left. Pins 1, 3, 5, 7, and 9, go across the bottom.
The power switch wires go to Pins 6 and 8.
The HDD LED wires go to Pins 1 and 3.
The power LED wires go to Pins 2 and 4.
On the power switch wires, the Positive (+) wire goes to Pin 6. Just in case this wire is marked.
(Doesn't really matter which way it goes, because it's a switch!)
On the HDD LED wires, the Positive (+) wires goes to Pin 1.
On the power LED wires, the Positive (+) wire goes to Pin 6.
Apr 15, 2009 | ECS 945GZT-M (V1.0) Motherboard
A power diagram for restoring power for a emachine
Hi there if you look real closley at the wires they are labled such as (pwr)led (reset) (hdd led )
(remote switch this the power for the computer) ect ect now look real closley and you will see the same markings on the edge of the board by each pin that they go to.. or you can also contact e-machines tech support and they will be able to help you out more if needed
best regards mike
Mar 17, 2009 | E-Machines eMachines Desktop PC
Emachines t3830 I need the schematic for MB I umployed the wire for the push bottom without looking at the way they were plug. Now I do not know the correct aligning of the push bottom wires.
If you look at the motherboard there is usually a diagram labeled "FRONT PANEL HDR" that will tell you which pins are for: HDD LED, PWR LED, RESET, PWR ON. etc.
The chart / diagram may be a few inches away from front panel header.
the following example is from my emachine T2893 that I had opened because it won't power up.
the motherboard at the header connector labels pin #2 and with that you can figure out the other
pin numbers
example of diagram on motherboard (Confirm the pin numbers on your motherboard)
J9G1 PINS
| HD LED | 1 - 3 |
| PWR LED | 2 - 4 |
| RESET | 5 - 7 |
| PWR ON | 6 - 8 |
Hope this helps you figure which pins to hook you switch up to.
Jan 18, 2009 | E-Machines eMachines T3830 PC Desktop
Need pin settings
Dear S_Proheartdt,
you can download the complete manual for this motherboard from this site, it will really helpful to you:
http://www.intel.com/support/motherboards/desktop/d845ebg2/sb/CS-008633.htm
Be Happy Always
Regards
Dec 03, 2008 | Intel Desktop Board D845EBG2 Motherboard
Motherboard pin config
All motherboards have a print beside the pins, Speaker= "speak", "pwr s" =powerswitch, "HDDled" red light on front, rst = reset switch [not allways used] "pwr led" Green led, the case wires are usualy marked on the plug ends with the same , "hdd" "reset" and so on. The power switch will work both way's around however the led lights wont. You will not hurt anything if they are the wrong way around, they just wont work so if you dont get lights just reverse the polarity. If by chance the case wires do not have labels the just trace them to the case front panel and plug them into the corresponding board pins. Regards mistyman
Aug 28, 2007 | Systemax Ascent PC Desktop
Computers & Internet Logo
162 people viewed this question
David Payne
David Payne
