Question about Troy Bilt 24b - 060f766 5hp Chipper Shredder Push Vac
Need to find a Bolens 5 HP Chipper/Shredder blade for Model # 47028
SOURCE: 5 HP troy bilt chipper sherdder will not rev up under load
Either or do one of two things if the motor runs pretty well Start the engine and run it full throttle. Once there if it has a high speed jet turn the screw in to start with until the engine stumbles a bit and then turn it back about a half turn. When you turn it in you should here the engine peak out. .If it is blowing black smoke out the exhaust it means the high speed screw is to far out so turn it in until it smooths out.If the engine smooths out then you have cured the problem. Good luck.
Posted on Mar 20, 2009
SOURCE: pulley size on Troybuilt Super Tomahock Chipper Shredder
Yes I solved my problem and it was rather easy, I should have thought of it before I wrote, My son ia a Mechanic for Hertz Rentals, I asked him. Thank You for your assiatance. R. Todd
Posted on Mar 26, 2009
SOURCE: drive belt and a manual for 8 hp tomahawk chipper
did you find a manual? mine is 8hp Super Tomahawk, model 47258. I have manual, but not parts diagram. I need parts, flails and tamper. Got any leads? twinblade88 at hotmail dot com
Posted on Jul 28, 2009
vincob
  • 718 Answers
SOURCE: I have a yard machinne 6.5hp chipper/shredder -
The blade(s) should have usually two bolts on them depending how many blades you have. Mine only has one blade held on with two bolts and that is only on the side that cuts the larger branches up to two inches in diameter and should be sharpened on a grinding wheel because it has a specific angle to it. The other side that chips smaller branches and twigs it a type of flailer, meaning pieces of metal just swinging around to mash up the sticks and do not need sharpening.
Posted on Oct 09, 2009
rwvanlue
  • 486 Answers
SOURCE: Misplaced operation manual for Troy-Bilt Briggs
Straight 30w NOT 10w-30
prefer air-cooled engine oil from mower dealers or some auto supply stores have air cooled engine oil.
Posted on Nov 08, 2009
Cub cadet chipper shredder starter coil is locked - will not pull
REMOVE THE SPARK PLUG. You now can safely take apart the unit to remove the covers over the chipper and shredder blades and remove the material stuck in the blades.
Aug 23, 2013 | Cub Cadet CS2210 - 2" 208cc Tow-Behind...
I need a parts and owners manuel for a Super Tomahak Wood chipper made by Garden Way Mfg. Co. where do I go to get one?
Hi and welcome to FixYa. I am Kelly.
Go to this site:
http://www.brentchalmers.com/
I note your looking for the Super Tomahawk. If you can come up with a model number I think I can find your parts manual for sure. (or at least an on-line parts list.) Also.... If you can come up with an engine number like OH120 or L90 off of the engine I can find you a manual for the engine also.
This is the list of Manuals available there:
  • 1983 W-W Grinder Inc. Manual and Parts List Super Tomahawk 5-8-2G/C and Tomahawk 5-8-2G/M Chipper/Shredder (40 Pages)
  • 1989 Troy-Bilt Owner/Operator Manual Junior Tomahawk Chipper/Shredder (24 Pages)
  • 1989 Troy-Bilt Technical Manual 4HP, 5HP, & 8HP Models Tomahawk Chipper/Shredder (12 Pages)
  • 1991 Troy-Bilt Owner/Operator Manual Junior Tomahawk Chipper/Shredder (24 Pages)
  • 1991 Troy-Bilt Knife Kit number 1772231 (1 Page)
  • 1992 Troy-Bilt 5HP Model Service Kit (Part Nos. 1901153 and 1901804) For Chipper/Vac (1 Page)
  • 1992 Troy-Bilt Owner/Operator Manual 47260, 47261, 47271, 47272 Chipper/Vac (60 Pages)
  • 1993 Troy-Bilt Sales Brochure Chipper/Vac (4 Pages)
  • 1993 Troy-Bilt Owner/Operator Manual 47265, 47266, 47267, 47276 Tomahawk Chipper/Shredder (44 Pages)
  • 1993 Troy-Bilt Parts Catalog 47265, 47266, 47267, 47276 Tomahawk Chipper/Shredder (16 Pages)
  • 1994 Troy-Bilt PTO Chipper/Shredder Owners Dog Clutch Kit 1902404 (1 Page)
  • Hopefully your model is one of the above.
    Here is link to the Parts manuals:
    http://www.partsandservice.com/html/TroyBilt/cs/
    There are 90 parts manuals there.
    Again with a good model and engine number I can probably come up with your exact manuals.
    Thanks for chosing FixYa,
    Kelly
    Oct 20, 2010 | Troy-Bilt Chipper Shredder
    How do you change the cutter blade on the TB Chipper?
    I just did one!
    There are two opposing threaded holes next to the shaft.
    Screw in bolts and use a wheel or gear puller to remove.
    You can use a socket that fits in the center bore for an extention of your gear puller.
    auttozone or ayto supply rents for free w/deposit
    May 22, 2010 | Troy-Bilt Chipper Shredder
    Replacement blades for Troy-Bilt chipper-shredder
    The knife kit for the 47042 and 47044 Tomahawk Pro chipper is part number 1772231MA.
    There are several for sale on Ebay or from a Murray dealer
    Mar 12, 2010 | Troy-Bilt Chipper Shredder
    Replace flails on 5.5 Yard Machine
    Go to www.ordertree.com. The flailblade is p/n 719-0329, The shredder blade is p/n 942-0571, The chipper blade is p/n 981-0490.
    Replace them you have to take casing off the unit to get to them.
    Jan 22, 2010 | Yard Machines 24a 452g729 5.5 Hp Chipper...
    Oct 08, 2009 | Yard Machines 24a 452g729 5.5 Hp Chipper...
    Difficult to start chipper while gears engaged
    The drive belt may be the wrong size if there is no play in the clutch. I have a 10 hp, but there is a common manual for the 10 and 8. My belt is a 4L380.
    Jul 12, 2009 | Troy-Bilt Chipper Shredder
    Ineed to sharpen my wood chipper blades on my
    It takes me about 5 minutes to Remove, Sharpen, and Re-install my chipper blade for my Bolens mc2500. First, If your using a screen or rollers in the discharge, then remove them. Look underneath, and you will see the thick flywheel. Make sure the spark pug wire is disconnected, then slowly turn the flywheel by hand until you see the two hex head bolts that hold the chipper blade to the flywheel. Also remember which way you take it off, so it goes back together the same way. using an open end or combination wrench remove the two hex bolts. Now to sharpen, I use a medium/ coarse honing tool made for lawnmower blades. I clamp the blade to the top edge of my Bolens with a pair of visegrips, then a little oil, and the sharpening tool, and I'm done sharpening in about 2 minutes, and then re-installing, reversing the removel process. I hope this helps.
    Apr 29, 2009 | Garden
    Troy Bilt 24b - 060f766 5hp Chipper Shredder Push Vac Logo
    394 people viewed this question
    Top Troy Heavy Machinery Experts
    Roland W VanLue
    Roland W VanLue
    Matt Olenzek
    Matt Olenzek
    Paul Sikkema
    Paul Sikkema
    Are you a Troy Heavy Machinery Expert? Answer questions, earn points and help others
