Question about Goodman Heating & Cooling
Replacing a Rheem Heat Pump condensor with a Goodman Heat Pump condensor. We have never installed either brands. Have been advised that Rheem has different wire scheme for reversing valve. Question is... is there any technical information available from Goodman covering how to wire the 24 volt wiring system for a Goodman Condensor with a Reheem AHU, and describes the differences? Thank you!
  • irexc Oct 03, 2010
    I have a Rheem AHU and Thermostat... replacing condensor with a Goodman HP. The Rheem equipment uses "B" for heating. I'm not sure but I think the Goodman uses "O" for heating. Do I use the "B" wire on the "O" terminal? Thank you.
  • 674 Answers
The difference is that the reversing valve is energized it heat mode for one brand and energized in the cooling mode for the other brand. An "O" on the circuit board indicates energized in cooling and a "B" on the circuit board indicates energized in heating.
Posted on Sep 09, 2010
WHERE IS THE Goodman GSZ130301 RESET BUTTON ON CONDENSOR
No reset button. As for low/high pressure switches they reset on their own when the problem is corrected. Usually low refrigerant.
May 03, 2014 | Goodman Manufacturing Goodman GSZ130301...
Goodman heat pump model gph1442h41aa will not turn on
first confirm that the condensing unit outside is getting power or even a command to come on .check function of thermostat your t-stat may command heat in the cooling mode.instead of the heat mode, being a heating system generated by a cooling condensor. also check bateries in t-stat. make sure breker in the panel box is on ,it is a double breaker usualy marked with an amp rating of 20 ,or a 30 on it . also check disconnect switch located next to your outdoor condensor usualy a gray box on wall of building. make sure its on or diconnect tab is pluged in . hope this was helpful. good luck.
Feb 11, 2013 | Goodman GPH1524M41 2 Ton 15 SEER...
Installed heat pump and all is wired and condensor will not turn on help
is the contact pulling in, if not then you will need to check the fuse on the main board. Hope this helps tim
Sep 08, 2010 | Goodman Heating & Cooling
Normal in cool cycle, very high pressure in heat cycle
Expansion valve on the condensor or possibly overcharged with refrigerant?
Nov 01, 2009 | Goodman Heating & Cooling
Reversing valve installed backwards on goodman heat pump have a simple comfort 2000 thermastat the defrost cycle doesn't work . can the reversing valved be wired on the terminal board to accomadate this...
You should be able to move the reversing valve wire from O terminal, (the changeover relay), on the thermostat to B terminal. I deal mostly with York
which O on the t'stat is normally open and B is normally closed.
Oct 01, 2009 | Goodman PHKJ048-1 Air Conditioner
New goodman pkg heat pump i wired up 2 brand new
You may have defective tstat wiring, or a bad control fuse. Check both.
Jul 30, 2009 | Goodman CKL24AR24 Air Conditioner
Replacing an older Rheem Ht/Pump w/a new Goodman Ht/Pump
The installation instructions should explain connecting 4 control wires to a 5 wire thermostat. Absent the instructions, check to see if any of the terminals on the new thermostat have jumper wires run between them -- if this is the case the two terminals w/ jumpers will only require one wire, and it doesn't matter which terminal is connected -- just match colors.
Apr 28, 2009 | Heating & Cooling
Condenser fan wont come on nor will compressor I do have fan op
Thanks for your Question,
First thing to check is the breaker in the panel to see if its tripped, I would suggest turning to off, then back to on, if it trips right after you have a short, if not you will need to check your fuses at the disconnect, first, shut the breaker off to the condensor, then pull the fuses and Ohm check them, if you have no reading then one or both is bad, I would recommend replacing them both if thats the case, if they check good, then you have bigger issues with your heat pump, if these suggestions do not work let me know and I can go into more indepth proceedures with you on what to do, thanks again,
mr.grzz
Jan 25, 2009 | Rheem 81VP15S Point-of-Use Electric Water...
Heating & Cooling Logo
78 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
