Email air Model R40H require compressor size. And package unit capacity. Thank you
3 Suggested Answers
relaga58
  • 158 Answers
SOURCE: p8 eroor code
P8 error is abnormal pipe temperature indoor. If you are running it on heating P8 error will appear because the disc pressure is too high. It could be overcharged.
Posted on Jun 01, 2009
shastalaker7
  • 1515 Answers
SOURCE: Armstrong Heat pump Package Unit, Model#1B36DA-9B,
Hi, the outdoor unit will start to freeze when it is cold outside, but also it should go into a defrost mode to melt this ice either by the defrost board or defrost thermostat. You will know as steam will rise like smoke and some folks think it is on fire. If it never goes into defrost, get back to us and we can go through some things to check. Merry Christmas,
Shastalaker7
Posted on Dec 24, 2009
How to calculate the capacity for the unit using LRA
You don't. Obviously the higher the locked rotor amps the larger the compressor the larger the unit. What's the model number?
Aug 20, 2017 | Heating & Cooling
I have a tempstar 2000 heat pump approx. 6yrs.We have the compressor go bad 3 different times and replaced by the original installer.Now Action Air of Florida says they don,t know why so many compressors...
no compressors don't just go bad first of all is unit a split system or a package unit.if its a split system need to make sure copper from evap.coil to outdoor unit sized properly.next need to make sure your ductwork is sized properly undersized ductwork makes comp. run much harder.sounds like non-condensibles in system
Mar 22, 2012 | Heating & Cooling
I have a model VT 618902aj, its from 1996. What are the pulley sizes supposed to be? Is this unit matched with the present unit mentioned? Thank you
The pulley on the compessor only came in one size ~ about 10 inch. The motor size pulley would depend on the speed of the motor. To get a good volume of air, the pump needs to turn about 800 to 1000 rpm(most pumps have max rpm at that range, good idea to check ). Gas engine turns at 3000 ~ 3600 rpm so use about 3" pully or determine by counting the number of turns of motor/engine to make one revolution of the pump. Electric motors will turn 3450 or 1725. Choose pulley to turn pump at desired speed below max pump rpm and capacity of the motor.
Aug 20, 2011 | Campbell Hausfeld 5HP 20 Gallon Single...
Please advise heating/cooling capacity for carrier quietline air conditioner vertical through wall model 25 years old model number unknown Thanks
Hello rgar919,
It is imposible to tell you the capacity of the unit without some kind of numbers to find out what it is. They made more than one unit 25 years ago. The numbers off the compressor may help to find the size of the unit. Please try and find some sort of model or serial number, compressor number, fan motor number something that can be cross referenced.
Thank you for choosing FixYa.
Mar 06, 2011 | Heating & Cooling
What air compressor you can recommend me for inflating 10x20 truck tires? please give me the right specs. thank you
Noramally a 250 litres capacity with 5 hp motor /three phase would be enough for the job.
You can increase the tank capacity to higher level if the requirement is commercial.
Sep 18, 2010 | Makita MAC5200 Electric Powered Air...
Airtemp rooftop package AC unit M/N- RT-3130-01, what is the capacity of this unit
RT stands for Rooftop
3 stands for 3 Phase, 1 for single compressor and the remaining 30 stands for 30kW nominal cooling.
Aug 25, 2010 | Airtemp B6D30E7A Air Conditioner
Is the Model #25HBA360A300 a 5 ton unit?
36k-car-ms Key Features AC Type: Split System Additional Features: Ductless Cooling Capacity: 36000 BTU/hr Electrical Requirements Voltage: 220It is a 3 ton aprox 550 sq feet per ton is required
May 01, 2009 | Carrier 36KCARMS Air Conditioner
What's the best air compressor for a car paint job?
Painting requires lots of air! I want my compressor to have a MINIMUM 10 gallons or more capacity and provide 6-7 CFM at 90 PSI. The duty rating should be at least 50%. Many compressor have a label on them showing what uses they are well suited for. Start with the gun, the air requirements are usually printed on the packaging, use those as minimums! Good luck!
Feb 28, 2009 | Acme Automotive ACMA680CS Typhoon High...
INSTALL HEAT TO A INTERTHERM
Wiring diagram is normally included and fixed to the inside cover of the electrical end cover of the control compartment. Instructions for wire size required and fused disconnect should be on the unit name plate.
Nov 09, 2008 | Heating & Cooling
Heating & Cooling Logo
173 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
