Why does not cpu work on more tera hertze? - Computers & Internet
  • 32,281 Answers
A CPU is specifically designed to work as a certain frequency. Some motherboards allow overclocking to speed up the clock frequency and allow the CPU to operate faster. The faster the CPU operates the more heat it will generate.
When a CPU overheats, it will shutdown - this is called thermal shutdown and if this is allowed to continue, the CPU will eventually fail.
Posted on Sep 09, 2010
Won't cut off goes to mute, have to turn up volumn to play
With regard to we're coming in make contact with using the whole body linked to Jesus twenty-four hours?cheap tera power leveling And I think which within our loved kinds we do not need tanks as well as guns, 36LBQ0Hb to eliminate, to take serenity,buy tera gold merely encounter up, relative an additional, take that serenity, that joy, which potency of presence of every other using the home. http://wowgold11.tvheaven.com/cgi-bin/blog/view_post/767444
Feb 05, 2012 | 2006 Nissan Titan
I have a 1996 Cavalier convertible, 4cyl, 2.2 it ran fine when i store it last year but now it won't accelerate. You floor the gas pedal and it takes the car 5 minutes to get to 35mph. At this point...
OLD GAS THE NEW GAS THEY HAVE DOESNT LAST MORE THAN 2MONTHS BEFORE IT SEPARATES. YOU PROBABLY HAVE A BAD FUEL PUMP OR ONE THATS ON ITS WAY OUT
Aug 05, 2011 | 1996 Chevrolet Cavalier
At 1440x1200 resolution the monitor (719Sw) visualizes fine, but a window appears saying "input not supported". Does my cpu not support this monitor. Its a P4, 32.99 ghz 504 mb ram machine
Restart the computer
2 While the computer is loading, press "F8" key on the keyboard right before the
computer reads the hard drive or press the "F8" key multiple times in 1 second
interval until the "Windows Advanced Options Menu" appears on the screen
3 Under "Windows Advanced Options Menu", using the arrow key on the
keyboard, select "Enable VGA Mode" then press Enter. Select "Windows 2000
or Windows XP" for your operating system.
4 Wait while the computer is loading and once the computer finishes loading,
5 Right Click anywhere on the blank area on the desktop then click "Properties"
6 Click on "Settings"
7 Click on "Advanced"
8 Click on "Adapter"
9 Click on "List All Modes..."
10 We recommend that for 15" LCD's select 1024x768, True Color (32 Bit) 60
Hz or 1024x768, High Color (16 Bit), 60 Hertz; For 17" & 18" LCD's select
1280x1024, True Color (32 Bit), 60 hertz, or 1280x1024, High Color (16 Bit)
60 Hertz, or
640x480, 256 colors, 60Hertz or 75Hertz
640x480, High Color (16 bit), 60Hertz or 75Hertz
640x480, True Color (32 bit), 60Hertz or 75Hertz
800x600, 256 Colors, 60Hertz or 75Hertz
800x600, High Color (16 bit), 60Hertz or 75Hertz
800x600, True Color (32 bit), 60Hertz or 75Hertz
1024x768, 256 colors, 60Hertz
1024x768, High Color (16 bit), 60Hertz
1024x768, True Color (32 bit), 60Hertz
11 Additional Valid Modes for use only with 17" & 18" LCD Monitor
1280x1024, 256 colors, 60Hertz
1280x1024, High Color (16 bit), 60Hertz
1280x1024, True Color (32 bit), 60Hertz
May 17, 2011 | AOC 917Sw 19" LCD Monitor
I have a heart freedom20 inv. batt. chger that runs at 120 hertz .It does everything (charges switches etc.just fine bu the ac output is at 120 hertz instead of 60.
First check the voltage, if the voltage is good then check the hertz with a different meter because if the hertz went up to 120 everything onboard should have burnt out. The hertz works on the low voltage side of 120vac. before going to a repair shop first check the hertz meter. Good luck.
Jan 25, 2011 | Xantrex Technology Heart Freedom 20 12...
My Nesspresso machine is a U.S. Version machine and uses 120VAC 60 hertz power input, and it is used on a private aircraft using a 120 VAC 60 hertz power converter. When plugged in an turned on the small...
I don't know if you already solved the problem, but did you check what the maximum output power of your aircraft is? The nespresso machine needs about 1250 Watts, which is a lot of power. A vacuum cleaner or microwave use less power than that (maybe between 800 - 1000 Watts). Maybe that difference is the reason. Also, you mentioned that you converted from 220V 50Hz to 120V 60Hz. I think you only converted the voltage, a frequency converter would cost thousands of dollars.
Jan 18, 2011 | Nespresso Citizmilk C120
I took my truck to the dealer and they diagnosed the problem as a failed heater box actuator door. Can you explain what this is and what i need to do.
the heater box actuator door is a flap that allows air to travel through the heater core. you may be able to get at it from the underside of the dash on the passenger side. you may be able to manually move the door from there. good luck. hope this helps.
Nov 08, 2010 | 2006 Nissan Titan
I just bought a new motherboard; basically new everything, well on my old motherboard there was a CPU and on this newer better motherboard there is not a CPU. Do I need to got one? What is a CPU exactly?
first, make sure that the new mother board support the old Processors, ask the M.Board supplier about it (or google it) , and make sure you know the old processors type.If you wasn't really sure, just remove the old Processor from old M.Board, then check for the ID (such as Pentium 4, Pentium D, etc ) on top of the processor.
If the new M.Board support the Processors, then you can re use the old processors, if don't, then you don't have a choice, buy the new one that match with the new M.Board specifications.
Hope you understand.
Feb 22, 2010 | Office Equipment & Supplies
We have a super holeshooter (cat.#1854-1)120v AC/DC. What hertz will this machine operate on? The brand is Milwaukee.
Hello. American made tools are made to operate on 60 hertz, but they will operate on 50 hertz. Given a choice, such as when operating off of a generator, select 60 hertz.
Dec 02, 2009 | Drills
FILE INTEGRITY VIOLATED
if you have any fast copying software then uninstall it
Dec 23, 2008 | Computers & Internet
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
