I was wondering if there's a way to change audio out from variable to fixed cause I want the volume out only from my surround sound not from the tv I heard If I switch from variable to fixed the problem will be solved. Please help me out I looked through the manual no info on this and under the audio setting no choice for that option. Please help thanks Westinghouse 32" led. Model # Ld-3255vx
  • Bud Martin
    Bud Martin Sep 09, 2010
    What is the exact model? Not all TV has a choice to select the audio line out to be fixed or variabled, or speakers off function on the on screen audio set up menu.
    Problem Solver:
  • 17 Answers
No variable audio out means that whatever the volume is at on the TV it will output that level from the TV. So if you have your surround sound on and if you change the volume on your TV it will also make your surround sound louder with out having to turn up that volume on your surround sound, but if you have your volume muted then so will the audio out. So if it is a fixed audio out then no matter what level you have the TV set to it will output the same level. If you just want audio to go to your surround sound then just hook the video cables up to your TV and the audio to your surround sound. I would guess that you are using Red and White cables... If you are that only gives you left and right audio. Not surround sound, so you would want to run optical, HDMI, digital coax, or the analog 6 channel audio cables.
Posted on Sep 09, 2010
Why does sound turn off.
Follow these steps to troubleshoot if there is no sound or intermittent sound from the speakers.
IMPORTANT: Not all of these features and/or functions are available on all products. Consult the instruction manual that came supplied with your unit to verify if your particular unit has these features, or if more detailed information is required to perform any of the steps below.
NOTES: Click on the appropriate link below if the issue is occurring with a particular device or connection.
  1. Make sure the MUTE function has not been activated.
  2. Try turning up the volume level.
  3. Check that there are no headphones connected.
  4. Try setting the Audio/Video (A/V) receiver to a different Surround Sound mode.IMPORTANT: Verify that the source you are playing is encoded with Surround Sound audio. If not, the audio will be very difficult to hear using a Surround Sound setting. Set Surround Sound to OFF when playing a source that is not encoded with a Surround Sound signal.
  5. Check each speaker to make sure they are properly connected to the A/V receiver.
  6. Perform a Test Tone function to verify if the speakers are working correctly.
  7. Verify all external audio sources are securely connected to the appropriate inputs on the A/V receiver. NOTE: If the audio is being sent from a television to the A/V receiver, then it may be necessary to disable the internal speakers of the TV or set the audio output of the TV to FIXED or VARIABLE. If the audio output of the TV is set to VARIABLE, then you will need to increase the volume level of the TV.
  8. Make sure the correct audio input is selected on the A/V receiver.
  9. Confirm what type of HDMI® devices are connected to the A/V receiver and then check the following:
    1. Test each one of the HDMI inputs on the A/V receiver to confirm that all of the inputs for the A/V receiver are working.
    2. Try a couple of different HDMI cables to verify there is not a bad set of cables.
    3. Unplug the video source from the A/V receiver and connect the source directly to the television. If there is still a problem with the audio, continue to the next step. If connecting the source to the TV corrects the sound issue, service will be needed on the A/V receiver. NOTE: Additional troubleshooting steps are available to troubleshoot instances when the audio, video, or both goes out when using an HDMI connection.
  10. Verify the DEMO (demonstration) mode is not active.
  11. Change the ATT (attenuate) setting. NOTE: The procedure to change the ATT feature varies by model.
  12. Reset the A/V receiver back to factory specifications.
The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required.
Feb 04, 2016 | Sony BRAVIA Televison & Video
Have no sound on my surround sound sony
Could be a number of things try each and test!
  4. Try setting the Audio/Video (A/V) receiver to a different Surround Sound mode. IMPORTANT: Verify that the source you are playing is encoded with Surround Sound audio. If not, the audio will be very difficult to hear using a Surround Sound setting. Set Surround Sound to OFF when playing a source that is not encoded with a Surround Sound signal.
  9. Confirm what type of HDMI devices are connected to the A/V receiver and then check the following:
Dec 21, 2014 | Sony Audio Players & Recorders
I lost my instructions for hooking my sound bar up to my new tv I ahd it hooked up to the last one and it worked now no sound and when I raise the volume it doesnt do a thing I programmed it to with m
Some sound bars have a seperate power cord, did you plug it in. Also, the source for the sound, are you using the audio outputs and not the audio inputs. They are all the same color (red and white) so you may have plugged in the wrong ones. If the sound bar is getting power, say a green led and the source for it is the tvs audio ouput jacks you might have to see if there is a seperate remote for the sound bar and raise the volume. Lastly the tvs audio output might have a seperate setting, it could be fixed or variable. Fixed will only change volume with the sound bar remote. In variable you will be able to change the volume with the tv remote but first you have to raise the sound bar level. Hope this helps in some way.
Feb 26, 2012 | Televison & Video
Sound changed
I would first go into your audio menu and make sure the correct settings haven't been changed, also the variable or fixed output is on fixed.
Does your set have the external surround sound speakers for the rear or are you using an external surround sound audio system?
Mar 03, 2009 | Hitachi 42 in. Plasma TV
Cannot get the surround to work correctly gpx dvd home theater
Check your setting it may be set to 2.1 or stereo. As for hooking up the tv check for aux or tv audio inputs on the dvd player and attach to the audio outs on the tv. You may need to change the settings on the tv, go to the audio menu on the tv and change from variable to fixed.
Jan 12, 2009 | GPX HTD2204 System
Audio Out Fixed/Variable
Is your subwoofer amplified or passive?
You clearly understand that you need to use a variable line out to control the subwoofer volume via the TV. As the setup seems reasonable, I'm wondering if the subwoofer is getting a signal, but that it is at line-level and not internally amplified by the subwoofer speaker. Generally, if the subwoofer must be plugged into an AC socket in the wall, it has an internal amplifier and can be fed line-level audio. If it is "passive", it has no amplifier, and it must receive an amplified signal (over speaker wire) from an amplifier (or integrated receiver). TV's don't generally have connections to send out an amplified signal.
If the subwoofer is indeed amplified, then this is obviously not the problem, but it's the first thing to verify given the information provided.
Mar 15, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Using 2 Pc speakers on my Tv
1)probable incompatibility issue--for comparison did you try a set of headphones? 2)The RCA audio outputs on the tv can go to an amplifier that has speakers attached,ie surround sound. 3)Caution==never try to alter vol level at spkr!
Oct 02, 2007 | Toshiba 27DF46 27" TV
No Audio Out to Stereo Reciever
First have you went in menu and check audio to see if you are on the variable audio or external output? Check to see if this makes a different with audio jack hookedup correctly of course!
Sep 11, 2007 | Hitachi 51F510 51" Rear Projection...
Volume control doesn't work on the enternal speaker
On some sets that have audio output jacks, the level of the audio output on the RCA jacks is fixed, and it does not change with the TV's volume control. On some sets, such as Sony, you can choose fixed or variable output. I have also seen some sets that have both fixed and variable RCA jacks on the back. With variable audio out, the audio level at the audio output jacks follows the TV's volume control. If you go into the TV's menu and navigate to the audio page, look for fixed or variable output options. If you have the owner's manual, read the section on audio output. If variable output is not an option on your model, then the level is constant and the volume will have to be adjusted with the stereo's volume control.
Aug 25, 2007 | Toshiba 27DF46 27" TV
Televison & Video Logo
259 people viewed this question
Top Televison & Video Experts
