The lap chill mat isn't cooling my laptop down enough to make it stop overheating, how can i increase the speed in which the fans give out so that my laptop doesn't over heat?
  • 27,725 Answers
try cleaning your computer of dust using a fine air blower from a compressor making sure that there is no moisture in the air line dust causes static to build up in a computer causing it to overheat and many other problems
hope this helps good luck
Posted on Sep 09, 2010
  • 32,281 Answers
Have you checked if the laptop fan is working? If not then the fan needs replacing.
Has the fan and heatsink assembly been check for clogging dust, if not then cleaned and remove the dust, especially off the heatsink fins.
What are the other ports used for, and can I use them to run the fans?
Do you mean the USB-ports on your laptop? If so, than yes, you will need one free USB-port to connect the Chill Mat to.
Feb 18, 2016 | Targus netbook chill mat dual fan awe39us1
My lap top gets too hot and shuts down
1. blow into the intake vents with canned-air
2. obtain a 'cooling-pad' for a laptop your size
example of a mat-style cooling pad
Xcellon ChillPad Laptop Cooling Mat Gray Black
example of a fan-style cooling pad
Generic Mini Fan USB Cooler Cooling Pad 2 Fans For Laptop Notebook PC...
Oct 28, 2014 | E-Machines Computers & Internet
Laptop chill mat getting lould and fans needs to be cleaned
It will probably be more efficient and easier to replace the cool mat. They are very inexpensive.
Mar 28, 2014 | Targus Computers & Internet
Targus chill mat won't work
it is definatly either a wiring issue or a cpu issue
Mar 18, 2014 | Targus Chill Mat PA248U Laptop Cooler
My laptop is over heating
Hi! first, i would like to ask if you are using cooling fan? if does, then i'll give you some tips on how to keep your laptop from overheating
1. Turn off your computer and allow it cool down.
2. Work with your laptop on a flat surface. The rubber feet on your laptop are designed to allow airflow to the underside of the computer, so if you are working on a bed or other soft surface, you cut off the airflow. If you do want to work away from a desk or table, try keeping your computer on your lap, exposing the underside to air.
3.Shut down your laptop before placing it in your carrying bag.
4 Give your laptop a bit more lift to increase the airflow under the machine. Two simple, flat rulers placed along the front and back edges of your computer is enough to increase the flow of air and keep your laptop cool.
5 .Unplug your charger as soon as the battery is full. A common mistake people make is leaving their computer plugged in at all times. However, the constant source of electricity will heat your battery and in turn overheat your laptop. Only charge your computer as long as necessary.
Hope this would be helpful.
Thanks for usinf FixYa : )
Sep 13, 2011 | Dell Computers & Internet
Targus Chill Mat Fan On Fritz
The fan rotor is stuck due to accumulation of dust. Take out the fan and clean it. Put a few drops of alcohol or lacquer thinner on the rotor/bushing assembly while manually turning its blades to loosen the hardened dirt until the fan freely spins like the good one. If it does not work, replace the defective fan if spare is available.
Aug 19, 2009 | Targus Chill Mat PA248U Laptop Cooler
Acer Aspire 3000 notebook constantly overheating and shutting off
purchase what they call a chill pad... it plugs into a usb port on the laptop and has two fans... you set the laptop on top of it....
Robert
Jan 05, 2009 | Acer Aspire 3000 Notebook
Chill mat
i have 1 as well and it broke too. this is http://computers.pricegrabber.com/laptop-accessories/m/1754767/
right?
if its the cord's thats broken, its most likely the switch, more specifically the soldering where the wire connects to the switch is prolly broken. i just sawed my switch open w/ a knife, and took a look. now if a wire is loose in the switch, u can either solder it back on, or (in my case i always have the fan on anyway cuz of my **** dell computer overheating) rip the wire off the switch completely and just connected it w/ aluminum foil.
Mar 24, 2008 | Targus Chill Mat PA248U Laptop Cooler
Computers & Internet Logo
David Payne
David Payne
