Question about Maytag Refrigerators
I have a Maytag Model # MSB2354GR that is not cooling. There is a humming sound every few minutes followed by a click and then the humming stops. Any idea what the problem could be?
  • Maytag Master
  • 4,654 Answers
Sounds like a simple solution in most cases. The compressor needs a little kick to get it started. That kick come from part=> number 12002783 or here=> Sea Breeze Tip's
Here is a Large view=> MSB2354GR Compressor section and on photo number 6 is the=> 12002783 Run Capacitor
p/n: 65889-4 appliance911 Part 4 in photo is=>
If you like to have how to instructions or assistance Please let me know, Thanks Sea Breeze
Posted on Sep 09, 2010
I have a maytag dryer that sometimes when I hit the start button will start and run for only a few minutes and stop and wont start again for a while and does a humming noise when it does star why?
Sounds like the motor is going into thermal overload (Getting hot) it may be caused by the motor itself, or could be overloaded by bearings or fan etc
Jul 28, 2014 | Maytag Dryers
Whirlpool refrigerator not cooling after storm
Assuming that both freezer and refrigerator temperatures have risen and the humming sound that you heard was followed by a sudden click more than likely the start device on the compressor has gone bad. This is a common problem with all Whirlpool refrigerators (KitchenAid is Whirlpools top of the line product and suffers the same problem).
May 11, 2012 | Refrigerators
Maytag/Mod MSB2354GR SER # JSU18X156A0A compressor kicks on but kicks off again. after 2 or 3 seconds . on again/off again No cooling in either side Cooling fan runs all the time
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 15, 2011 | Maytag MSB2354G Side by Side Refrigerator
My dryer stops running after a few minutes. The fuse has been replaced and the repair man replaced the motor and it stills runs for a few minutes then stops. HELP!
Did you clean it out too? Check the venting for clog behind dryer or at the vent cap? Is the house breaker clicking off? Is the dryer motor humming or just stopping? Does it restart every time you try or do you have to let it cool down for a bit to restart? Need more info to be sure. You may have a bad sensor, but you'll need a repairman to check that.
May 14, 2010 | Maytag Dryers
Kenmore hum click sound
Bad overload relay or bad compressor. You can change your overload relay to test, usually fairly cheap, (55.00 from Sears) however if it is your compressor, it is out of it's five year warrantee and is not worth repair. 900 to 1100.00 to repair in my area.
Jan 18, 2010 | Refrigerators
Water dispenser in my Maytag french door refer has suddenly stopped working. We use it every day and the filter seems to be fine. It almost sounds like it is frozen. Please Help!!!
We have a hd2560 (bot 10/04), french door with inside water dispenser and it had stopped working a year ago, but started working a few months later. I couldn't figure out what happened, but suspected the water line was frozen. I later found out that the water reservoir is located behind the fruit and vegetable bins, so look there to see if the water is frozen.
Two weeks ago, our frig/compressor stopped cooling after making humming/clicking sounds for weeks. Fortunately, Maytag has a 5 yr parts & labor warranty on the compressor, so we were covered. Evidently, there are quite a few faulty compressors out there.
I believe that the compressor had been over-cooling in the past and caused the water lines/tank to freeze. This would also cause frozen produce/fruit. I would immediately contact Maytag/Whirlpool if you suspect a faulty compressor as well.
Oct 24, 2008 | Maytag MFD2560HES Bottom Freezer French...
Freezer not freezing on m,aytag mfd2560hes
hi andy, based on your story, i think the humming sound is coming from the compressor trying to start and the clicking sound is when the overload trips and make that clicking sound to turn off the compressor but it does resets itself so it would humm again after a few minutes and tripps off again..try to unplug the unit for a day to cool off the compressr and then plug it back. if it will happen again, you need to replace the compressor. i hope i was able to help..
Jul 07, 2008 | Maytag MFD2560HES Bottom Freezer French...
Maytag refrigerator clicking noise and stopped working
How long a period of time have you noticed this noise? If it just started and the refrigerator just stopped it could have entered its defrost cycle. When the defrost heaters come on you may hear the heat causing some expansion. After a few minutes(18-22) the defrost cycle ends and the refrigerator will restart.
May 30, 2008 | Jenn-Air JCD2389G Side by Side...
Refrigerator not cooling.
compressor has failed. not a diy job
Apr 25, 2007 | Amana ASD2622HR Side by Side Refrigerator
Refrigerators Logo
110 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
