Question about Kenmore 45981 Washer
Have a foriegn object in the pump and i need to get thefront bottom panel off so i can acess it
    President:
  • 1,554 Answers
Disconnect power and remove the three screws attaching the bottom flange of the lower front access panel to the cabinet. Once the screws are removed, pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Remove the pump filter by turning the knob counterclockwise and pulling the filter out. Make sure to catch residual water from the filter housing by placing a shallow pan or a piece under the filter housing to avoid flooding your floor.
Posted on Sep 09, 2010
Can my Garbage disposal be fixed
Where exactly is it leaking? Is it leaking out of the bottom of the unit?
Jul 18, 2014 | In-Sink-Erator InSinkErator Badger 1, 1/3...
Washer wont drain showin IE
Sonia, you either have a failed drain pump, or something has bypassed the filter ( bobby pins are notorious for this ) and is jamming up the pump impeller. If you can set the washer to drain/spin and can hear the pump running, you most likely have a impeller that has broken off of the pump motor shaft and will need to be replaced. If you cannot hear the pump running, and can hear a slight humming noise, then there is something jammed in the pump. The pump can be removed and cleared of the possible foriegn object. I can provide instructions on pump removal if needed.
Apr 20, 2014 | LG Tromm Front Load Washer And Dryer Set
How to access drain pump on maytag neptune FAV6800 top loader washer
The drain pump can be accessed by removing the rear panel and following the hose down
Jan 26, 2014 | Maytag Neptune FAV6800AW Top Load Washer
How to drain the washing machine?
the best way to drain the unit is use a wet/dry shop vac and attach it to the end of the drain hose.
once all the water is removed then you can take the small acess panel off the front of the machine and take out the the drain pump plug. look for anything that might be stuck or obstructing the drain pump.
there is a small hole in the acess panel that you need to insert a small screw driver into push the locking tab in and rotate counter clockwise to remove.
Feb 26, 2010 | Bosch Axxis WFL 2060 Front Load Washer
Very noisy wash cycle
most times i have found a foriegn object in the pump. sometimes the machine will clear it itself but other times you have to take the pump apart. it is not too difficult but you will need a size T15 and T20 Torx aka (star) bit to get it apart. Just keep taking out screws until the filter flowplate lifts off.
Nov 30, 2009 | Maytag MDB9600A Jetclean II Built-in...
My wnse4200 makes a clunking sound when in the spin cycle and I can stop the drum by hand
you may gave a broken pump. or a bad centrifugal switch. turn the washer on its side(unplug it first of cours) underneath the washer you will see a pump attached to the motor. remove the pump by realeasing the two long clips in there and see if a foriegn object is lodge in there. a problem with the centrifugal switch will require replacing the whole motor.This could also be a problem with the drive gears.
Jul 01, 2009 | GE Profile Prodigy WPSE4200A
Need to clean the pump out. How to acess. AtF 6000.
Remove the front bottom cover to access the pump. Remove the two hoses. Make sure you have a pan to catch the water from the hoses. You will be able to remove the objects after the hoses are removed.
Jun 21, 2009 | Frigidaire ATF6000ES Front Load Washer
Whirlpool deut washer - is the a lint screen on washer like the top loading washing? If yes how do you clean and service the lint screen? Thanks.
there s a"button trap" located on the side of your pump assy, behind the lower acess panel ( youll need to remove 3 torx 20 screws from the from bottom of machine ) after emoving the panel oull see the clean out directly in forn t of you. BE WARNED THERE WILL BE WATER behind that acess point grab a towle!!!!
Jan 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Hotpoint washing machine
f05 is a drainage problem, ther may be something stuck in your pump.
its in the back of the machine in the corner. take the side hose off and unclip the pump from machine and look in to see the propellor may have foriegn object in.
Dec 09, 2008 | Hotpoint Ultima WF860 Front Load Washer
Kenmore 45981 Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
