Question about Frigidaire FRS3HR5JSB Stainless Steel Side by Side Refrigerator
Not getting cold on both sides. - Frigidaire FRS3HR5JSB Stainless Steel Side by Side Refrigerator
  • Frigidaire Master
  • 43,501 Answers
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Dec 27, 2010
Kenmore washer 80 series model 110.22892100 only fills with Hot water. The Hot/Cold hoses are correctly installed. The only way to get warm or cold water to fill in the tub is to hold temp selector knob...
so if you set the knob to cold then the knob would automatically move to hot correct first thing to do is check the water valve which is where your hot and cold hoses connect to inside the machine you get to this from inside the machine by removing the cover one side f the valve is hot and one side is cold take a multi meter and check to assure that when you do set the selection to cold that you are getting power to the top of the valve on the cold side if you are not getting any power to the cold side of the valve replace the valve if you are getting power to the cold side the next thing t check would be that switch that is your selector nob for this you would have to go into the area where your timer is located and check for any burn spots on the small electronic piece that is on the back side of the switch most of the time it is the valve that goes bad and it is a rarity that the switch would go bad but it is possible please remember to rank how this opinion has helped in your appliance situation and if you have anymore questions please message me back have a great day
rickead1
Aug 22, 2010 | Kenmore Washing Machines
Refridgerator side is getting warm
the refrigerator side of most modern day units only gets cold by cold air being blown over from the freezer side so check the fan in the freezer to make sure it is working as well as check the damper that opens and closes to let cold air over to the refrigerator side
Apr 05, 2010 | KitchenAid KSCS25FKSS Side by Side...
Fridge & wont get cold wont get cold, fans is on motor gets hot
check to see if compressor is running if not replace relay also make sure ur condenser motor is running
Jan 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Side by side freezer works fine ice cold.fridge not so good. only at 57 degrees
Listen for the fan motor to run. Open the freezer\ push the door switch with your finger \ listen for the fan that blows the cold air to the fridge. only the freezer side gets cold...fan blows cold to the fridge side. If the defrost timer has broken then ice may be blocking the flow of cold air to the fridge also. Only 2 things to check. Good Luck
Dec 11, 2008 | Kenmore 57029 Side by Side Refrigerator
Side by side won't get cold
not usually - mine is filthy! is compressor running?
Nov 04, 2008 | Maytag MSD2656G Side by Side Refrigerator
REFRIGERATOR SIDE NOT GETTING THAT COLD
they are junk so many problems with mine . when down 4 times
just 2 years old.
Sep 30, 2008 | Samsung RS2534 Side by Side Refrigerator
Amana side by side does not freeze nor does it get cold
first check you freezer back for frost if a lot of frost defrost the whole freezer ,,, then plug back in and see if it will work..
let me know
Jul 05, 2008 | Amana SXD524VW Side by Side Refrigerator
Frigidaire FRS3HR5JSB Stainless Steel Side by Side Refrigerator Logo
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
