Question about Kenmore Washing Machines
Water does not drain after first washing clothes
    President:
  • 1,932 Answers
Check whether the the draining pump is working properly.
Thank You
Posted on Sep 09, 2010
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
How do i fix my washing machine,it only drains water instead of washing clothes.
call a service technician as it may be a faulty program board
Nov 20, 2015 | Washing Machines
/Hello How do I wash a cloth and let drain the wahter and again prigramm the washingmashin to wash that cloth again
your nuts
a washing machine performs a cycle
wash rinse and spin
and thats that
you need a woman or man to wash again and again
Feb 07, 2015 | Washing Machines
My washing machine keeps all the water inside and my clothes be wet so when i open the door water falls outr
Keep the water draining hose at lower surface than the washing machine. also check for any blockage in the water draining vent and water draining hose.
Oct 29, 2012 | Washing Machines
Im not getting enough water when washing clothes. sometimes if im washing heavy clothes, like sweatshirts, they come out and I can see dry spots on the clothes where water hasnt saturated them. also, when...
Hello
The problem may be the drain line.Unplug washer and remove drain line.Inspect line for any debri or lint.Check drain line screen for anyhting cloging it.
Be sure to tiighten all clamps when putting drainline back on.
Check incoming water screens.These are on washer where water hoses connect,clean if needed.
Last,try a self clean of machine.This sounds like a high eff washer which should have a cleaning mode.
Sep 23, 2011 | Washing Machines
I have a samsung 13kg diamond drum toploader, my problem is after selecting all relevent options to wash my clothes when the machine start washing the clothes it also drain some water out. My clothes end...
If the drain hose is pushed too far down the drain pipe, it will have a tendency to to siphon out. Only use 1 or 2 table spoons of detergent as the washer uses very little amounts of water. Read your instruction manual as it says the drain hose has to be higher than a certain height before it goes to the drain.
Oct 16, 2010 | Washing Machines
GE Washing Machine (model # GUSR2LOOT) drain problem
Check for a blockage in the water pump. If it does not drain first it does not spin. Check for power to the drain pump motor.If no pump blockage check the lid switch for continuity. No continuity, replace the lid switch.
Jul 03, 2009 | GE Washing Machines
On one wash clothes came out sopping the next there was no water
Check the drain hose for kinks or blockage. The drain hose should be free in the drain pipe so air can get around it. The drain should be good enough to accept a lot of water all of a sudden without overflowing.
Apr 26, 2009 | Frigidaire ATF6000ES Front Load Washer
Suds residue left on clothes just washed
ck drain hose end of drain hose should be at least 36 ins from floor also be sure drain hose fits loosely in drain water may be siphoning out resulting low water level to wash/rinse ..also recommend using liquid detergent dry doesn't dissolve good in cold water and even though it may be recommended for front load the lower water levels used may not be enough to dissolve it properly
Nov 27, 2008 | Washing Machines
Washing Machines Logo
12 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
