Question about Texas Instruments TI-83 Plus Calculator
How to i multiply to the 6 power - Texas Instruments TI-83 Plus Calculator
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Use the ^ key just above the divide.
For example, to calculate 2 to the 6th, enter 2 ^ 6 ENTER and see 64.
Posted on Sep 09, 2010
How many gallons in an 88" x 15" x 9" trough?
try this :
Instructions
  1. Measure the rectangle length, width and height. For example, 8 inches long, 6 inches wide, 10 inches high.
  2. Multiply the length by the height, then double the product. With this example, 8 inches multiplied by 10 inches results in 80 square inches, which multiplied by 2 equals 160 square inches.
  3. Multiply the width by the length, then double the product. With this example, 6 inches multiplied by 8 inches equals 48 square inches, which multiplied by 2 equals 96 square inches.
  4. Multiply the height by the width, then double the product. With this example, 10 inches multiplied by 6 inches results in 60 square inches, which multiplied by 2 equals 120 square inches.
  5. Sum the amounts from Steps 1 through 3 to find the rectangle surface area. So adding 160, 96 and 120 square inches results in 376 square inches.
1 Us gallon is 231 cubic inches
Sep 05, 2015 | Garden
Need to know how to write three ratios that are equal to the given ratio 6/7
Multiply both 6 and 7 by the same non-zero number.
For example, if you multiply by 2 you get 12/14, which is a ratio equal to 6/7. I'll let you pick two other numbers and multiply.
Nov 25, 2013 | Computers & Internet
Eight multiplied by ten to the power of six divided by four multiplied by 10 to the third power
Press 8 [*10^x] 6 / 4 [*10^x] 3 =
[*10^x] is the key just below the 3 key.
Sep 08, 2011 | Casio fx-300ES Calculator
I am trying to multiply in scientific notation but I don't how to do it when the power of 10 is a negative i.e 1.67 time 10 to the 21st power multiplied by 9.11 times 10 to the -31 power. thank you
Make sure you use the +/- key just to the right of the decimal point key when entering negative values, including exponents.
1 . 6 7 EE 2 1 * 9 . 1 1 EE +/- 3 1 =
Aug 30, 2011 | Texas Instruments TI-30XA Calculator
What is 9 to the 2nd power plus -7 to the 3rd power plus -6 to the 2nd power x 5
I never know if these questions are serious, but I'll play along.
Remember the definition of a power: it's a number multiplied by itself that many times. For example, 4 to the 3rd power (4^3) is 4 X 4 X 4, or 64. So the problem you list can be written
9^2 + (-7^3) + (-6^2) + 5, or
9 X 9 + (-7 X -7 X -7) + (-6 X -6) + 5
Don't forget that negative X negative = positive when multiplying.
81 + (-343) + 36 + 5 = -221
Mar 16, 2011 | Computers & Internet
I want to multiply 1.66 X 10 to the minus 27 Using a TI-30XA
What do you want to multiply it by? As an example, to multiply it by three, press
1 . 6 6 EE 1 0 +/- 2 7 * 3 =
EE is the key just above the 7 key, +/- is the key just to the right of the decimal point key.
Mar 08, 2011 | Texas Instruments TI-30XA Calculator
Anytime I try to multiply .001X.001, any decimal beginning with a zero, I get an error. For example, .001X.001=1 E-6...My mode is set in normal, and I reset it to default, what am I missing?
This is not an error. .001 multiplied by .001 is 1E-6.
If the absolute value of a number is less than .001, the calculator will always display it in scientific notation. 1E-6 is interpreted as 1 times 10 to the minus sixth power.
Oct 11, 2010 | Texas Instruments TI-84 Plus Calculator
What is the question for... (2×10) + (3×1000) + (7×100) + (6×0.1) + (5×1) + (4×0.01) is it a b c or d A) 3725.64 B) 2376.54 C) 3271.61 D) 3725.46 what is the answer and how...
OK the answer is 3725.64.
Multiply 2x10 = 20 Multiply 3x1000= 3000 Multiply 7x100 = 700 Multiply 6x0,1 = 0.6 Multiply 5x1 = 5 multiply 4.0.01 = 0.04
Add them all up 7 it come to 3725.64
Mar 22, 2010 | Kenmore 63942 Dryer
How do you convert the following: 6x10^3 MPa =......... Pa?
6x10^3 Mpa = 6 multiplied by 10 to the power of three, or 6x10x10x10 10x10x10 = 1000 therefore that = 6x1000 Mpa therefore that = 6000Mpa therefore that is now to be expressed as pa, so we must multiply by 1,000,000, to convert FROM Mpa to pa we multiply 6 by that so that equals, 6000,000,000 pa Pa = Pascals. 1 Mpa = 1,000,000pa.
Feb 16, 2010 | Calculated Industries Construction Master...
NOt exactly a problem as my Casio SL-1100TV calculator works fine. What I am trying to find out more about is the 'K' function, when you can press the + button twice and it carries over the number that...
If you have say to multiply 100 numbers by one single multiplier ( you have 100 multiplications to perfom) you use the Constant function abbreviated to K.
This is how you go about it
in a*b , a is called multilpicand, b is the multiplier.
You enter the multiplier (6) then you press twice on the multiplication key. You are ready to repeated the some operation but with a different multiplicand
You enter the first mutiplicand then you press = (or enter) the result is displayed.
Every number you are going to enter will be multiplied by 6
[6][*][*] -------constant multiplication with 6 as multiplier, Then
[5][=/ENTER/EXE] yields 30
[6][=] yields 36
[0.5][=] yields 3.
Be careful!! If you do not enter a new multiplier and just press [=] the calculator uses the last calculated result as the multiplicand. (On certain calculators, the last result is stored in a register called Ans (short for answer.)
What I described for the multiplication is valid for any arithmetic operation. Thus
[6][+][+] is constant addition with 6
[18][/][/] is constant division with 18 as divisor.
Hope it helps
Sep 02, 2009 | Casio Office Equipment & Supplies
Texas Instruments TI-83 Plus Calculator Logo
53 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
