Question about LG WM1814CW Front Load Washer
Lg tromm wm1814cw. Replaced the water pump that went out, now the new one won't shut off? Is there a reset when replacing the pump?
MNTECH
  • 1543 Answers
SOURCE: Can you adjust the water level on the LG Tromm WM1814CW?
No. Water level is not user adjustable. The washer will automatically put in the correct amount (about 3 inches in the bottom of the tub) and adjust for load size and type. This level is all that is needed. The reason the clothes are hardly wet at the end of the cycle is due to the high spin speed (compared to almost all top loading machines). If you want to see how wet the clothes really are, pause the machine mid cycle and the door will unlock and you can see, or select a "no spin" option and see at the end of that cycle. You will use about 12 gallons of water for a large load, vs. about 45 for a top loading machine, so remember to adjust your soap and fabric softener use accordingly. ( one tablespoon detergent and one teaspoon fabric softener maximum per load)
Posted on Apr 07, 2009
SOURCE: Drain pump on LG Washer
Have the same problem , but when it gets to the drain cycle ( about 12 min left ) will chime and show an i con on display ( washer with a hose on bottom left with an X on it ) and it doesnt drain. I un plug and let sit for awhile , turn on and go to no spin and it will manually drain ( sometimes ) Do I need and New drain pump?
Posted on Jun 05, 2009
localwonder
  • 6784 Answers
SOURCE: LG TROMM WM1814CW won't stop filling. Says
Over flow error
Water is overflowing , (water level frequency is over 213). When FE is displayed, the drain will pump out automatically.
Replace the Overfill pressure switch(AKA-Switch assembly sensor swi)
Posted on Jul 12, 2009
  • 161 Answers
SOURCE: My LG Tromm WM1814CW is not draining. I cleaned
Check inside the filter housing with a flashlite for debris that got around the filter. If it is clean, you have a bad pump and it needs to be replaced.
Posted on Jan 27, 2010
CMV9
  • 594 Answers
SOURCE: LG Tromm wm1814cw LE flashing on digital display,
Here are few troubleshooting tips that i have found. If you acquire further assistance please let me know...
Is this a new installation?
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Are there soap suds visible in the drum?
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
Has a large load size been used with a gentle wash setting?
Gentle wash cycles such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because the cycles are more gentle while tumbling and spinning, too many items in the drum can register as an issue with the motor. In this instance reset the unit and run a test rinse and spin cycle.
Has the washer been overloaded?
Single bulky items or large loads can add extra weight to the drum and place stress on the motor. Remove some of the clothing and restart. If the issue is still present after a few items have been removed, unplug the washer for 30 minutes to allow the motor to cool and then restart the cycle.
Posted on Apr 13, 2010
I need to force my lg tromm to drain
My LG Tromm washer has a small door on the bottom left hand side on the front of the washer. Open the door and you will find the drain filter and a stoppered, small rubber tube. Position something to capture the washer water under the small rubber tube and pull the plug.. This will drain all the water from the washer.
Aug 01, 2014 | LG WM1814CW Front Load Washer
I have a tromm wm1814cw washer .i am trying to replace gasket.not having any luck.can you inform me as to the secret. thank you
There are 2 special tools you will need to change the door gasket. Call LG and order the door spring removal tool. There are 2 of them.
Jun 15, 2011 | LG WM1814CW Front Load Washer
I have an lg wm1814cw front loader with a ue code
Probably the pump filter is blocked.Make sure the machine is empty...Access filter via small door at floor level. Unscrew the filter cap, and clean filter. check that there isn't a coin stopping the impeller vanes. ...When you take the cap off, any water left in machine will flow out!! Leaning the machine back can help.....Good luck...Nomess
May 16, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My LG Tromm WM1814CW is not draining. I cleaned out the drain filter and checked to make sure the drain hose is not kinked and still - there is no water draining from the machine except when I pull out the...
Jan 26, 2010 | LG WM1814CW Front Load Washer
Over flow error
Jul 12, 2009 | LG Washing Machines
Tromm does no stop filling
you got water in the pressure valve hose ,,,,, keep running in on drain till it clears or the best it to remove the top of washer, pull off the little hose and blow thru it to clear it
Oct 19, 2008 | LG WM1814CW Front Load Washer
Tromm LG Washer
On my LG TROMM model # WM1814CW, the door pops open a bit so that water leaks out onto the floor. Is it a simple repair or is it time to get soaked by a repairman. I'm fairly handy, but I don't know if it is an electrical issue or it is a mechanical issue. If you have a suggestion, send it to repihl@yahoo.com.
Thank you,
Bob
Dec 24, 2007 | LG WM2688HWM TROMM SteamWasher
LG TROMM WM 2077CW LE Error
An LE error is a locked rotor. The hall sensor on the stator part of the motor is not sensing the rotor part of the motor is turning. So the short version is you need a new stator(which has the sensor on it or just the sensor) replaced which should have a 5 year warranty on it so call LG for your nearest authorized service center
Nov 17, 2007 | LG WM1814CW Front Load Washer
LG WM1814CW Front Load Washer Logo
199 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
