Question about Health & Beauty
Wanted manual for jetstream vibration machine
Spin only on Zanussi Jetstream 1400
no agitation check timer and control board. but more likely culprit is the water pressure switch. Which determines water level and when machine goes into agitation mode?
Sep 26, 2014 | Zanussi Washing Machines
Fan stopped working
possibly the motor failed. this is not a cotton candy machine issue.
Apr 17, 2013 | Bowens Jetstream 250 Wind Machine
Zanussi Jetstream 1200 vibrating madly and making a lot of noise
Pull out your machine and remove lid , inspect the spring you may have a broken one .
Feb 11, 2013 | Washing Machines
Zanussi jetstream zwf14179W lock will not release
it sounds like your pump might have somthing in side it try opening the flap on the bottom right you will see a plastic screw undo it and clean it out that should help ok
Oct 18, 2012 | Washing Machines
Jetstream JTWVUHF Operation Manual
I tried to locate the manual with google, but unfortunately had no success. You could ask some specialized manual search engines, like here . The services are not for free, but most times worthy - saved my live more than once.
Sep 30, 2012 | Washing Machines
Need a contraol manual for a zanussi jetstream
Sorry but this forum does not supply any type of manual or schematic diagram direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Mar 17, 2011 | Washing Machines
How do I clean my jetstream second stage
Why are you trying to clean it? if it leaking air try a good vigorous wash in fresh water. If it smells try using sterilising fluid such as milton.
Aug 28, 2010 | Poseidon Odin/Jetstream Regulator
Instruction manual for poseidon jet stream regulator
Manual:
http://www.frogkick.dk/manuals/poseidon/1999/
Service manual for all poseidon regulators (trained scuba technicians only):
http://www.frogkick.dk/manuals/poseidon/2003/manual.pdf
May 31, 2010 | Poseidon Odin/Jetstream Regulator
Health & Beauty Logo
71 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
