Question about GE (PSS26MSRSS) Side by Side Refrigerator
I have a side by side GE went out in the garage today and opened it up all the ice was melted , must have just happened. when i plug it in , only the light comes on i hear a short "girggle" sound up top but nothing else at the bottom near the compressor , i have the covers off the back already because i smelled something like dust burning from it. i have tapped on compressor and relays on board but i get nothing
  • 101 Answers
Unplug check mother in rear
Posted on Sep 10, 2010
GE Side by Side Refrig - loud noise behind the ice maker section Model PSS25SGMB BS
it sounds like the evaporator fan blade is hitting some ice that has built up around the blades i have seen this happen a lot on g.e. SxS lately,if you can remove the ice maker and dispenser you can see the fan blade,if you dont want to do this then shut down the refrigerator and leave freezer door open and heat it carefully with a hairdrier to speed the process up to melt this ice then restart it and the noise should be gone
Aug 30, 2012 | GE PSS25SGNBS Side by Side Refrigerator
I have a GE side by side refrigerator, with an icemaker in the door. The refig is slightly less than 6 years old. I have been out of town for a few days, but today opened the door to get something out...
Seriously? Mine just did the same thing today. The electric on the inside is fine. No cooling. there is a code blinking HRS on the inside. the ice and water were working intermittently the past couple of weeks. wtf?
I found a post describing the exact thing I have going on but it was from 3 years ago.
Feb 10, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer not cold
Check Compressor. If its too hot to hold your hand on it then
you may need a new compressor. Check condensor fan, and check
evaporator fan
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 02, 2010 | GE GSL25JFPBS Side by Side Refrigerator
I have GE GSS22WPGT and there is a constant
you have condisation on your condensor fan and it is vibrating. when you defrosted the unit you melted all the ice in the freezer. once the unit got cold again you had the same problem. it happens when you open the freezer door. the only way to fix it is to repalvce the fan and fan motor, as well as the main board. this is a costly repair unless it is under warranty.
Oct 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile Side by side- lines from custom cool covered with ice
I can't give you a solution but I can tell you that we have exactly the same situation. The freezer seems to work but we come back and water has dripped from the ice holder and formed a classic stalagtite (or is it a stalagmite?) Obviously something has melted. We have also found items in the freezer melted - yet the digital readout said it was 3 degrees! Arghhhhh. Glenn in Delaware
Apr 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice melts in the bucket on and off...
1check for frost 2 check light stay on 3 condenser fan 3 check door stay open
Mar 29, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE Refrigerator Stoped making ice
the small pipe in side the freezer the one that supplies water to it, it builds ice in side, you can melt the ice by getting some hot water and a towel and wet the pipe with it intel ice melts , or you can unplug the frige with the door open over night.first solution is better.
Dec 07, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer not freezing, fridge section not cooling
the problem you have sounds like the defrost heater is not being activated causing the evaporator to choke up with ice which will therfore restrict the airflow through the cabinet,
to resolve this problem you are best to defrost the unit and replace the thermal fuse for the heater' and the defrost sensor, both these parts are located behind the evaporator cover inside the freezer.
hope this is of help murdozzz2
Dec 08, 2007 | GE GSS25SGSSS Stainless Steel Side by Side...
Freezer defrost all. RS2556
The most likely is that the door was not closed properly, this is very common on this model, what happens is that the door closes against the freezer contens and therefore appears closed, this allows warm air into the unit which starts to melt the ice, if this should happen again it is a good idea to completely defrost overnight with the doors open and then re start the next morning as ice often builds up behind the rear panel. Regards Advisor
Jul 04, 2007 | Samsung RS2556 Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
55 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
