Question about Frigidaire Washing Machines
Frigidaire front load washer Model #FTFB4000FS0 Serial #XC60811099. Diagnostic error code E59 --no tachometer signal (step 12 diagnostics points to motor or motor control board)
SOURCE: frigidaire front load washer won't final spin
THERE ARE A COUPLE OF CONDITIONS THAT WILL PREVENT THIS UNIT FROM SPINNING :NOT COMPLETELY DRAIN AND FAULTY DOOR LOCK AS SY.
FIRST REMOVE ELBOW ADAPTER HOSE FROM TUB TO PUMP AND MAKE SURE IS COMPLETELY CLEAN ,HOSE STRAINER THEN CHECK IMPELLER @ DRAIN PUMP NOT TO BE BROOKED , DEFORMED .DIRTY OR LOOSE IF IS LIKE THIS REPLACE PUMP IF NOT PUT EVERYTHING BACK TOGETHER ,MAKING SURE THE STRAINER IS ALL WAY DOWN (IF IT HAS ONE) IF NOT IT WILL GET LOOSE AND DAMAGE YOUR OUTHER TUB ,THEN THIS IS IT .
THEN CHECK PRESSURE SW HOSE FOR LEAKS AND BLOW SLOWLY AND CAREFULLY TO CHECK PRESSURE SW .IF CHECKS OK THEN REPLACE DOOR SW ASSY AND RUN ONE IM VERY SURE THIS WILL TAKE CARE OF YOUR SITUATION ;NOW GET ON YOUR KNEES , GET DIRTY AND HAVE A GREAT DAY!
MAYITOJHONES
Posted on Dec 04, 2008
SOURCE: How do I run a diagnostic on a Fridgidaire
Diagnostic Test: The diagnostic test is performed by using the Program Knob. To START THE TEST: • On non-digital display models, turn the Program Knob to start position, Drain/Spin. • On digital display models, turn the Program Knob to start position, Touch Up. (NOTE: If the model has a timer dial that can be rotated 360°, turn the Program Knob to start position, Drain/Spin. • Press Pause Cancel to turn off LEDs. • Within 5 seconds, press and hold the Option and Pause Cancel buttons until LEDs start sequentially chasing, then release buttons. 1. All the LEDs will sequentially light. Pressing a button below a light cluster will light all the LEDs in that cluster at one time to confirm functionality. 2. Turn the program knob (1) click clockwise from the start position. The hot water solenoid will activate and hot water should enter through the detergent compartment. 3. Turn the program knob (2) clicks from the start position. The bleach water solenoid will activate and cold water should enter through the bleach compartment. 4. Turn the program knob (3) clicks from the start position. The bleach and the wash water solenoids will activate and cold water should enter through the softener compartment. 5. Turn the program knob (4) clicks from the start position. The door lock solenoid will activate. 6. Turn the program knob (5) clicks from the start position. The door lock solenoid will deactivate and the loading door can be opened. 7. Turn the program knob (6) clicks from the start position. The washer will fill and tumble. 8. Turn the program knob (7) clicks from the start position. The washer will fill and spin (leakage test). 9. Turn the program knob (8) clicks from the start position. The drain pump and door lock solenoid will activate and the washer will operate in high spin. SAFETY WARNING: If power is removed during this test, the door can be opened. To prevent injury, DO NOT put your hands inside when the tub is rotating. 10. Turn the program knob (9) clicks from the start position. The control will signal the last error code. Exiting Diagnostic Mode There are two options for exiting the Diagnostic Test mode and returning the washer to normal operation: a) Unplug the power cord, wait 5-8 seconds, then reconnect the power cord OR b) Turn the program knob clockwise 2 or 3 clicks after the Start Position. Press Options and Pause Cancel buttons together for a few seconds until wash cycle LEDs appear. If a situation arises where you cannot exit the Diagnostic mode as described above and the bank of 5 LED’s on the right end remain ON regardless of Program Knob position, a combination of pushed buttons may have caused the control to enter a special factory test mode. Disconnect power to reset the control to return washer to normal operation is this occurs. To clear latest stored error code: Place the control into Diagnostic test Mode. • Turn the program knob clockwise 9 clicks from the Start Position. The control will signal the last error code. • Press and hold the Options and Pause Cancel buttons for 3 seconds. The code will be cleared. • Exit Diagnostic Mode to return th e w a s h e r t o n o r m a l o p e r a t i o n .
Posted on Dec 25, 2008
  • 41 Answers
SOURCE: Kenmore 417. 4405200 Front Load Washer error code E43
It's a bad wax motor inside the door latch. The diagnostics are buggy and do not test it properly. It should measure about 1.5K ohms, and when 120 VAC is applied to it, it should extend in about a minute. Part number 12002535 is $10 to $15.
Posted on May 14, 2009
  • 3 Answers
SOURCE: washer has water but doesnt spin frigidaire gl2940es
WASHER DRAINS BUT WILL NOT SPIN AT ALL
Posted on May 24, 2009
  • 212 Answers
SOURCE: Code F43 on frigidaire front load washer.
motor control possibly bad
Posted on Jun 20, 2009
How do i reset/delete all the data codes for a frigidaire galley model GLTF2940s53
• Exit Diagnostic Mode to return the washer to normal operation
Jul 17, 2014 | Frigidaire GLTF2940ES Front Load Washer
GLTF2940ES3 - Frigidaire Front load washing machine e59 error code
http://www.ehow.com/info_12127418_frigidaire-gltf2940fs1-not-spin-error-e59.html
May 02, 2014 | Frigidaire GLTF2940ES Front Load Washer
FAFW3801LW3 has error e59
Hi Rosie,
I understand that you're receiving an E59 error code on your Frigidaire washer, model# FAFW3801LW3 and are looking how to run the diagnostic test. While there isn't too much information about actually running the diagnosis, I would recommend contacting the manufacturer and seeing if they are able to assist.
-Best Regards-
Jan 23, 2014 | Frigidaire FAFW3801LW Front Load Washer...
What e59 means
Hello Ninemi,
I see that you are receiving an E59 on your Frigidaire Affinity washer. E59 states that "No Tacho" Signal for 3 seconds. I would recommend giving the appliance a hard reset. You will do this by either unplugging it or switching the circuit breaker off that the washer is attached to. When you do this you will want to leave it off for 3-5 minutes. Once the 3-5 minutes has elapsed, bring power back to the washer and try to restart it. If you are still receiving an E59 error code, I would suggest contacting your local authorized technician to diagnose and see why you keep receiving this error code.
-Best Regards-
Jan 22, 2014 | Frigidaire Affinity FAFW3511K Washer
Frigidare errow code e59 display
Hi Emily,
I see that you are receiving an E59 on your Frigidaire washer. E59 states that "No Tacho" Signal for 3 seconds. I would recommend giving the appliance a hard reset. You will do this by either unplugging it or switching the circuit breaker off that the washer is attached to. When you do this you will want to leave it off for 3-5 minutes. Once the 3-5 minutes has elapsed, bring power back to the washer and try to restart it. If you are still receiving an E59 error code, I would suggest contacting your local authorized technician to diagnose and see why you keep receiving this error code.
-Best Regards-
Jan 21, 2014 | Frigidaire Washing Machines
Kenmore Super Capacity 3.5 error code E59
see the error code E59= E59 equals no tachometer signal for 3 seconds.
This means that the motor is not signaling to the washer normally and may be caused by a variety of failures within the motor, basket or the control board. Generally speaking, the E59 error requires the service of a Frigidaire professional for resolution due to the technical nature of the ERROR.
God bless you
Aug 01, 2012 | Kenmore 3.5 cu. ft. Front Load Electric...
E20 error message
replace the control panel or have it repaired,there is no e20 listed as a trouble code,so it needs to be replaced.
  • Exit Diagnostic Mode to return the washer to normal operation.
Error code - Fault condition
E11 Fill time too long.
E13 Water leak in tub or air leak in air bell.
E14 Reed switch.
E21 Water not pumping out fast enough.
E23 Drain pump relay on control board failed.
E24 Drain pump relay on control board failed.
E31 Better models. Pressure sensor not communicating with control board.
E35 Better models. Pressure sensor indicates water overfill.
E41 Control board thinks the door switch is open.
E42 Door remains locked after cycle is completed.
E43 Control board problem.
E44 Control board problem.
E45 Control board problem.
E46 Control board problem.
E47 Board thinks the door PTC circuit is open in spin.
E48 Board thinks the door PTC circuit is closed.
E52 Bad signal from tacho generator.
E55 Motor overheating.
E56 High motor current.
E57 High current on inverter.
E58 High current on motor phase.
E59 No tacho signal for 3 seconds.
E5A High temperature on heat sink.
E5B High temperature on heat sink.
E5C High temperature on heat sink.
E5D Communication problem.
E5E Communication problem.
E5F Communication problem.
E67 Input voltage on microprocessor incorrect.
E75 Better models only. Water temperature sensor circuit.
E76 Better model only. NTC temperature for the cold water valve over the limits.
E95 Communication error.
EB1 Incoming power frequency out of limits.
EB2 Incoming line voltage above 130 VAC.
EB3 Incoming line voltage below 90 VAC.
EF1 Clogged drain pump.
EF2 Too much soap.
Apr 22, 2017 | Frigidaire ATF6000ES Front Load Washer
Motor control board frigidaire
E59 No tacho signal for 3 seconds in other words sounds like a bad motor
Diagnostic Test:
? On non-digital display models, turn the Program Knob to start position, Drain/Spin.
? On digital display models, turn the Program Knob to start position, Touch Up. (NOTE: If the model has a timer dial that can be rotated 360?, turn the Program Knob to start position, Drain/Spin.
? Press Pause Cancel to turn off LEDs.
? Within 5 seconds, press and hold the Option and Pause Cancel buttons until LEDs start sequentially chasing, then release buttons.
b) Turn the program knob clockwise 2 or 3 clicks after the Start Position. Press Options and Pause Cancel buttons together for a few seconds until wash cycle LEDs appear. If a situation arises where you cannot exit the Diagnostic mode as described above and the bank of 5 LED?s on the right end remain ON regardless of Program Knob position, a combination of pushed buttons may have caused the control to enter a special factory test mode. Disconnect power to reset the control to return washer to normal operation is this occurs.
? Turn the program knob clockwise 9 clicks from the Start Position. The control will signal the last error code.
? Press and hold the Options and Pause Cancel buttons for 3 seconds. The code will be cleared.
? Exit Diagnostic Mode to return the washer to normal operation.
Dec 30, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire front load washer displays E20 what does that mean?
E59 code means you need a new circuit board and Frigidaire knows it's a problem, but will only step up to repair if you demand it. we're on our second circuit board in 2 years!
Aug 09, 2007 | Frigidaire GLTF2940E Front Load Washer
Washing Machines Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
