Question about Health & Beauty
Why would one of the shaving heads on Shaver spin around??
  • Health & Beauty Master
  • 1,610 Answers
Most likely, one of the shaver heads is damaged and the cutter is embedded in the comb causing the whole thing to spin. It could also be that the retainer that holds the blades in blace is worn or broken and can not properly hold it in place.
If you require new heads or retainer, you should find what you need at shaveroutlet.com
Posted on Sep 10, 2010
Norelco 8140xl new blades doesnt shave
Did you use part HQ9 for your replacements? Norelco makes many different replacement heads and only one type is correct. The correct type for model 8140XL can be found at shaveroutlet.com below
http://shaveroutlet.com/norelco-philips-hq9-replacement-heads-p-252.html
Feb 02, 2014 | Norelco 8140XL Electric Shaver
Flashing head message
This signal reminds you to replace the shaving heads of your shaver. New shaving heads guarantee continued optimal shaving performance.
What reminder signal your shaver gives depends on the model. Some shavers beep, while others show a flashing shaving head symbol on the display. Some with red half circle arrows, around the 3 shaving heads, or a flash of the 3 shaving heads. There are also models that beep and show a reminder signal on the display at the same time.
How to reset the reminder signal:
The replacement reminder is repeated at 7 to 10 successive shaves, depending on the model.
In some models, you can reset the razor. Press and hold the On/Off button for approximately 10 seconds.
If the shaving head symbol is shown in combination with an exclamation mark ("!") and a faucet symbol, it means that the shaving heads are blocked. When this happens, you have to clean the shaving heads or replace them. (Note: Only certain models have this feature)
Hope this helps, as mine is doing the same thing now.
Jun 22, 2013 | Philips Norelco 1250x Sensotouch 3d...
I just purchased a Panasonic Arc IV nanotech wet/dry shaver. I've been using it in the shower, and it's very effective. However, I'm wondering if I'm using it correctly. The shaver's manual says it should...
You did not include the specific model number written on your shaver but I will try to address your questions the best I can without it.
Most likely, your shaver came with a cleaning station and charging station. The cleaning light would tell you it is time to use the cleaning station. After each shave, you should dump out the shavings and rinse under the tap. You should let the shaver dry without the cap on.
ShaverOutlet com ShaverOutlet com Shaver Replacement Parts Manufacturer...
Mar 27, 2017 | Panasonic Es8243a Arc Iv Nano Electric...
My Phillips arcitec has a red light blinking at the very bottom of my shaver. I've had the shaver for 3 years.
It's means that you change new replacement heads. That philips arcitec 1060 electric shaver replacement heads is Norelco RQ10 shaving heads.
Aug 05, 2010 | Philips arcitec 1060 Electric Shaver
After using the shave a digital red symbol of the head shows up at the bottom of the shaver. What does this mean? Thanks.
Digital red symbol of the head shows up. It's menas that you should change new replacement heads, that Norelco Arcitec electric shaver replacement heads is Norelco RQ10 shaving heads.
May 21, 2010 | Norelco Arcitec Electric Shaver -...
Red light at bottom flashes even when razor ids fully charged. What can causrethis?
When the battery is almost empty (when there are only 5 or fewer shaving minutes left), the battery symbol lights up red.
Make sure that the battery does not have a memory effect. What I suggest is taking the shaving head unit off and running the shaver till empty, then recharging. Check if the red light is still flashing.
There's also a head indicator at the bottom of some shavers.
To remind you to replace the shaving unit, the shaving unit symbol flashes (all types) and you hear a beep when you switch off the shaver (RQ1090 only). This happens at the end of 7 successive shaves to remind you to replace the shaving unit.
Without knowing what model you have it's difficult to diagnose further.
May 23, 2010 | Norelco Arcitec Electric Shaver -...
What is the red blinking light showing the head mean?
Hello. That is a reminder that it is time to change the head, to maintain optimum shaving. It will blink the next 7 times you turn on the shaver. Here is the manual if you want to read more about it. http://download.p4c.philips.com/files/1/1050x_22/1050x_22_dfu_aen.pdf
ps kindly rate my answer as very helpful. thank you. Joe
Mar 29, 2010 | Norelco Arcitec Electric Shaver -...
Shaved hairs fall out of shaver head
IT'S A GOOD THING THAT THE HAIR COMES OUT ITS STOPS THE CLIPPERS FROM JAMING. USE A GARBAGE BAG AND POKE A HOLE BIG ENOUGH FOR YOUR HEAD. PUT THE GARBAGE BAG OVER YOUR SHOULDERS AND TRIM AWAY. THAT WILL HELP IT FROM GETTING OVER YOUR CLOTHES. IF YOU HAVE A GARAGE PUT A MIRROR IN THERE AND YOU CAN SWEEP UP THE HAIR OFF THE FLOOR EASIER THAN IN THE HOUSE.
Dec 26, 2008 | Braun 360° Complete 8985 Electric Shaver
Red L.E.D light won't stop flashing
Shaving head check indication After two years of use the red shaving unit symbol î will flash for 30 seconds during 7 shaves to indicate that you should check the condition of the shaving heads. This indication is based on an average shaving time of 3 minutes per shave. When the shaving head symbol flashes, all other symbols and lights are out. When the shaver is switched off, the shaving unit symbol disappears. When the red shaving unit symbol starts flashing, you should check the shaving heads for possible damage. If the shaving heads are damaged in any way, they must be replaced in order to obtain optimal shaving results
Nov 20, 2007 | Health & Beauty
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
