Question about GE Ovens
Part of the bottom of an aluminum foil tray is stuck to the bottom of our self-cleaning GE oven -How do we remove it safely & effectively?
'The Works' toilet boil cleaner bought from Walmart...$1.50.
It WORKS !! Squirt it on ... see it fizz...wipe it up...foil gone!
Smells a bit like rotten eggs when working.
Did NOT harm oven surface.
Use GLOVES
Later,
Mike
Posted on Jan 25, 2014
  • 101 Answers
It most likely cant it fuse to the liner.y
Posted on Sep 10, 2010
Does a GE Profile double oven have a removable bottom pan
It says right in the owner's manual not to use aluminum foil on the bottom of the oven. Try to remove it with steel wool...
Aug 29, 2016 | GE Ovens
1How do I remove small pieces of aluminum foil which are stuck to the bottom of my oven? 2 If I can't remove the small amounts of alum. foil, Will still be able to use the self-cleaning feature?
Hello Wendy;
My name is Peter. I am a retired field service appliance technician.
You can try to use a putty knife.
When your oven goes into the self cleaning model, you are burning off grease. The burning off of aluminum foil is nothing compared to burning off the grease.
You may see some small flame. But, this will soon pass. Your cleaning cycle can handle this without causing any damage.
Mar 24, 2015 | Kenmore Ovens
My new oven has melted the tin foil onto the bottom of the oven that I put to catch cake drips. I don't know how to get it off as it has adhered. The smell right from the start of the oven and during my...
With the older models of self-cleaning ovens one could put aluminum foil on the bottom tray of the oven, but with the newer models there is a warning (hidden in the last line) of your booklet for models of stoves where aluminum foil should 'not' be used! Even though print in small and many consumers are complaining regarding their stoves and melted aluminum stuck to the bottom tray of their oven (nothing will get it off) all manufacturer do 'not' cover this problem under warranty and thus, it will cost you $44 to buy a new tray. You unscrew the two screws to the bottom of the damaged tray of your oven and then install the new one and put back the screws. Letters of complaint should be written to the manufacturers to have them put this warning in clear bold print right on the front cover of the instruction brochure.
Jan 20, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Tin foil stuck to bottom of oven how to remove it
See this link: http://askruth.blogspot.com/2006/07/cleaning-baked-on-foil-in-oven-help.html
"I called Sears and this is what they said to do:
BE CAREFUL, remove as much of the foil as possible Turn oven on to 200 lay an old wet bath towel on top. Use a plastic spatular to remove the foil.
They said it will take some time to remove the foil, in some cases days, and that you can still use the oven but DO NOT use the self cleaning untill all the foil is removed."
If you can remove the bottom drip tray/pan from your oven which the tinfoil is stuck to, than remove it. Ovens with "hidden element" usually have the removable bottom tray/pan. Don't scrape yet!!
Lay the tinfoil laden tray on a flat service where it wont be disturbed for a couple of days.
Now remove any tinfoil you can with a plastic scraper/spatula/pancake flipper.
Once thats done, pour bleach directly onto the drip tray/pan until it covers all the stuck tinfoil.(assuming your oven pan is like mine and has a lip all the way around and is somewhat countersunk).
Leave the bleach in for about 2 days. Now get your plastic scraper again and scrape away. The stuck tinfoil should all be dissolved by the bleach and the scraper should get rid of any residue. Then rinse!
Now this method will probably leave some darkened stains on the oven tray, but not near as ugly or noticeable as that melted tinfoil!!
Good luck!!
May 14, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
I don't have a Kenmore I have a Fridgidare and I have burned on foil on the bottom and cannot remove it. It is a self cleaning overn and I am afraid to turn it on??? I have tried scrapping, soaking, but...
With the older models of self-cleaning ovens one could put aluminum foil on the bottom tray of the oven, but with the newer models there is a warning (hidden in the last line) of your booklet for models of stoves where aluminum foil should 'not' be used! Even though print in small and many consumers are complaining regarding their stoves and melted aluminum stuck to the bottom tray of their oven (nothing will get it off) all manufacturer do 'not' cover this problem under warranty and thus, it will cost you money to buy a new tray. You unscrew the two screws to the bottom of the damaged tray of your oven and then install the new one and put back the screws. Letters of complaint should be written to the manufacturers to have them put this warning in clear bold print right on the front cover of the instruction brochure.
Apr 26, 2010 | Kenmore 33169 Gas Single Oven
How do i get an aluminum foil pan stuck from the
You may be able to get it opff with the oven hot. Whatever is holding it was liquid when hot before, so should at least loosen enough for you to remove it.
Nov 04, 2009 | Kenmore 47783 Electric Single Oven
I have baked on aluminun foil on the bottom of my self clean oven did the cycle to self clean and the aluminum foil is still stuck on the bottom what can I do to remove it without ruining the surface
If the bottom of the oven is enamelled or has a pyrolytic self cleaning surface then you can use caustic soda to remove aluminium foil.
Many oven and hob cleaners contain caustic soda and those which do always advise that it's kept away from aluminium parts precisely because of it's effectiveness in turning aluminium into grey foamy goo!
If you're in doubt as to whether your oven floor is caustic soda resistant then try a small test patch first.
Please note that caustic soda is extremely corrosive so you'll need to keep your hands and arms covered and preferably use eye protection as well.
Sep 20, 2009 | Electrolux ICON Designer E30SO75ESS Oven
Aluminum foil stuck to new oven bottom - how to remove
(Wear a professional n95 mask and rubber gloves). Use a straight razor and scrape off as much foil as possible. Get a hold of Mercuric or sulfuric acid. BE CAREFUL not to spill anywhere, work close to a stainless steal sink. Poor a little in a small glass container and bring over stove porcelain surface. Pour the acid onto the foil and wait 3-4 minutes, use paper towel to wipe off the acid, and then a soapy wet rag. Repeat process until all foil is dissolved. Then wash surface thoroughly and repeatedly with a soapy dish towel. Once complete run water in the sink for 5 minutes till any possible remaining accid is flushed from the sink. The foil is gone and the porcelain is preserved. Works great! (Don't breathe the fumes and ventelate the area or move the stove outside)
Jan 20, 2009 | Kenmore 47783 Electric Single Oven
if not a lot of foil get that easy off thats made for self cleaning ovens soak it let it sit then wipe make sure you get the one that says safe for silf cleaning dont scrape soak then after wipping off run self clean
Dec 27, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
279 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
