Question about Texas Instruments TI-81 Calculator
I replace all the batteries and have a blank screen, is there a way of resetting the unit or what can I do?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
Posted on Sep 09, 2010
What to do when an 8022c wall thermostat screen goes blank - no numbers, just the lines dividing the three areas? Pushing reset does nothing.
Pop the cover off and check the battery. Replace if necessary. If it still doesn't work trip the main breaker for the ac unit off wait 1 minute and turn back on. If it still does not work then you have a more technical proble. Could be a bad thermostat or control board in the ac unit.
Jul 03, 2016 | Audio Players & Recorders
Reset does not work , screen blank ,responds to nothing.have tried just about everything , where can I send it for repair ,
Most probably the battery causing thr problem. Try to reset to factory settings and or format the unit. Sometimes there are issues with author rights and in that case You have to get the unit to a SONY technical service to clear its internal memory.
Oct 09, 2013 | Sony 8GB Walkman Video MP-3 Player With...
Can not reset calculator. Keep getting + sign when press enter
If the TI-84 does not function even though you are sure that the
batteries are fresh, you can try manually resetting it by following steps:
1. Remove all of the AAA batteries from the graphing handheld
2. Press and hold the ON key for ten seconds
3. Replace the batteries
4. Turn on the unit
When you reset your graphing handheld, the contrast sometimes
changes. If the screen is faded or blank, adjust the contrast by
pressing 2nd and releasing up-arrow or down-arrow keys.
Feb 24, 2013 | Texas Instruments TI-84 Plus Calculator
How do i unlock my f4 polar?
Remove back cover,,,remove battery for 2-3 minutes,replace battery and allow unit to reset.
Jun 07, 2012 | Polar F4
When I power up laptop screen is blank
You may have a burned video adapter.
A trouble shoting setp you can try is attatching an external display and seeing if that works.
Also try the function F5 key combo. I think that is the ASUS mapping to switch display output.
Aug 04, 2009 | ASUS Eee PC 900 Notebook
Automatic Hard Reset
a loose battery can bring such problems. make sure battery is properly tight fit in its cabin. polish the contact points if they are not clean.
good luck
Jan 31, 2008 | O2 Xda IIs Pocket PC
Blank screen
Reset the unit by pushing a bent paperclip or pin into the hole on the bottom marked 'reset' turn it back on, plug it in & charge it via USB overnight or as long as you can in the car, make sure the led on the top is green, tap the bottom right of the screen & check the battery symbol on the unit says charging underneath.
If this doesn't help.
If its NEW take it back!
or
contact tomtom about the problem...
http://www.tomtom.com/support/support.php?ID=2
Dec 16, 2007 | Tomtom ONE GPS Receiver
Digital photo keychain
Have done that, reset the unit, tried all combination of re-installing software, starting program 1st, plugging in unit 1st. pressing power button, resetting unit while USB is plugged in adn not plugged in, holdig doen power button and reset, holding pwr button while plugging in, and about 20 more combination. The screen says "UPDATING", the little light is"GREEN", the battery meter shows "FULL", when you unplug unit screen goes black and "NOTHING"... "0", "NADA", piece of **** !
**** SOLUTION -- RETURN PIECE OF **** TO STORE FOR REFUND !!! *****
Dec 08, 2007 | Alera Technologies Digital Photo Copy...
Tom Tom ONE Version 3
Have you tried resetting the unit? Does it do the same thing after being reset?
Nov 25, 2007 | Tomtom GO 910 GPS Receiver
GPS screen went blank
My problem exactly. Unit would start up, acquire satellites, then the screen would go blank with a single vertical line. Unit would not respond to buttons or even turn off. Unit works fine after I did the reset:
- w/unit OFF, press and hold QUIT+DOWN+MENU
- press and release the power button, release DOWN, keep holding QUIT+MENU for 5 seconds.
- unit prompts something like: "erase all data;" choose yes.
- you will lose waypoints, etc.
Go to the Garmin support area for details.
http://www.garmin.com/garmin/cms/site/us/support/searchsupport
Search for: "How do I reset my gpsmap 76"
Oct 06, 2007 | Garmin GPSMAP 76 GPS Receiver
Texas Instruments TI-81 Calculator Logo
70 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
