Question about Belkin Wireless Play Router (F7D4302)
My belkin play router works fine on my xbox, yet when I try to use my computer I get a "this webpage cannot be displayed" error, but when I reboot the play router it stops for a few hours
    Sergeant:
  • 358 Answers
Hi lets we tried to Upgrade your firmware version.
Updating your Routers Firmware
The following steps will show you how to update your routers firmware using its web interface.
You do not need to be connected to the Internet as this interface is built into the router itself.
Setup Steps
Locate and download the firmware file from the Belkin support site. (Type in your part number in the search box in the top right and look for "Firmware" in the title)
Save the file to a location on your computer where you can get to it easily, such as your desktop.
Connect the computer to one of the four gray ports on the back of the router.
Open a web browser on the computer.
In the address bar of the web browser, type http://192.168.2.1 and press Enter on your keyboard.
Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
Click on "Firmware Update" toward the bottom of the left-hand menu.
Click the Browse button toward the middle of the screen to search for the file you saved previously.
Select the firmware file by left-clicking on it and then click the Open button in the lower right corner of the window. This will take you back into the router's interface.
Click the Update button.
A prompt asking, "Are you sure you want to continue with upgrading?" will appear. Click OK.
A second prompt will open telling you the router will not respond during the upgrade and warning you not to remove the power supply to the router. Click OK once more.
Congratulations. The firmware has been updated successfully
Please don't forget to rate techbelkin.
Posted on Oct 31, 2010
Just purchased belkin play n600 and am having trouble with setup. Everything loaded, but I cannot access the Internet from my pc now, my iPhone and xbox can connect but the pc the router is connected to...
ok what you will have to do is go to control panel and unistall all the software for the belkin then you will have to reinstall the software when you install make sure you only hook up the router to the computer and get it to work then you can hook up the xbox and the ipone you will have to set up port forwerding for the xbox to work correctly.
B52computers
Chris Thrash
Jan 22, 2011 | Belkin Play N600 Wireless Dual Band N...
Wireless Connection Problem
try uninstalling reboot then install again
hope this helps
Aug 01, 2010 | 2wire (2701HG-B) Wireless Router
My Xbox 360 Nat is Strict. with my Belkin
again give it then save it then reboot it the router then try it
Jul 29, 2009 | Belkin (F5D7230-4) Router (587009)
Weak connection
Unplug the router for 30 seconds, then plug it back in. Reboot any computers or game consoles as well.
Jan 24, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Opening the NAT connection for Xbox 360 working through 2 routers
  1. How do you connect your Linksys router to Belkin router? Do you connect your Linksys router to the Internet/WAN port of the Belkin?
  2. If so, what is the Internet connection type set in your Belkin router? Is it dynamic?
  3. If the Belkin router is set to dynamic IP and if it is obtaining an IP address from your Linksys router(you may check the status page of your Belkin router and look for IP address), then you may need to forward or set that IP address as the DMZ to your Linksys router. Make sure that XBOX is still configured as the DMZ host in your Belkin
Hope this helps!
Nov 15, 2008 | Computers & Internet
My Belkin N1 and my xbox 360
I just got it and yes latest firmware as of end of mai has been downloaded
Jun 02, 2008 | Belkin (F5D8231-4) Wireless Router...
Belkin F5D9230-4 router with xbox live
the solution is as such, first log into your router by typing the routers IP (192.168.2.1) into your browser.
The first thing you want to do is set UPnP to be enabled.
Forget about the 88 UDP thing, it's bogus.
Just set the TCP and the UDP to 3074 in virtual server.
I swear to god it will work.
Mar 06, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I was having troubles with a belkin router as well. i called belkin tech support and they never helped as they would not accept that the router was the problem. i found i could connect the xbox directly to a modem and it would work fine but when i connected it through the router it would always disconnect from games or not allow me to join a game, only host them, with no one else joining. no matter if i forwarded the appropriate ports, put the specific ip address into the dmz or even turn upnp on (i've tried different combos of each, all on at same time, to even setting up manually) and nothing would change. I found that the router had an option to turn off NAT which belkin told me would render the router useless.  I decided to go against them, turned it off and set the ip and dns to go with the modem. Now everything works fine as the router just acts as an expensive multi plug and wireless system. all the computers in the house can connect to the internet at the same time and access eachothers hard drives and i can access xbox live fine with no problems. there is also no lag when playing gtaIV multiplayer with 15 other players.  i hate belkin tech support and i will not pay for another expensive multi plug connector from belkin... ever.
Mar 06, 2008 | Belkin (F5D7230-4) Router (587009)
Belkin router
The fact that it sometimes works and sometimes not, would indicate that maybe your wireless signal strength is poor. Try moving the router and/or antenna and recheck the signal strength. If you would provide more details about the problem and your setup it may be helpful in diagnosing the problem.
Mar 31, 2007 | Belkin (F5D6230-3) Wireless Router
Belkin Wireless Play Router (F7D4302) Logo
98 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
