Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Freezer is freezing up, heaters and defrosting , refegerator not cooling
  • Frigidaire Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
System has a leak and is low on charge...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 11, 2010
Evaporator coil freezes-up. thermister and heaters ok. wont defrost. dont think it has defrost timer
All units have some type of defrost...
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 12, 2011 | Refrigerators
Refrigerator side not cooling, but feezer is still freezing
DEFROST HEATERS IN THE FREEZER. IF THERE IS FROST ON THE BACK WALL INSIDE THE LOWER AREA OF THE FREEZER SECTION. YOU THEN HAVE A DEFROST PROBLEM. THE HEATER IS THE MOST COMMON. REMOVE THAT PANEL AND DEFROST WITH HAIR DRYER. THIS FROST IS BLOCKING THE AIR FLOW TO THE REF. SIDE. AFTER THIS IT WILL WORK FOR 10-21 DAYS WITH OUT REPLACING THE DEFROST HEATER. 95 PERCENT CHANCE. JUST REPLACE THE HEATER SOON AFTER DEFROSTING SO YOU DONOT HAVE TO DO IT AGAIN.
Apr 25, 2010 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
1999 Frigidaire Refrigerator
Check rear wall of freezer by feel for frost. Heavy, even frost indicates likely problem in the defrost system. Unplug unit. Defrost heater (in freezer behind rear wall panel), defrost thermostat (same area-must be checked at freezer temperature) or Defrost timer-located lower back outside of unit. Near compressor. Do continuity test on heater and defrost thermostat and if they show continuity (good), replace defrost timer. If not, replace the one that tests bad.
Defrost coils fully. Reassemble.
Please let me know if I have helped with comments and rating.
Refrigerator will work about 7-10 days after being defrosted until thick frost builds up again cutting off air flow to both compartments
Sep 07, 2009 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
GE side by side. The freezer will freeze up with
Replace the defrost heater, located at the bottom of the cooling coils, behind the back wall of the freezer.
Aug 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidare refrigerator FRS26ZTH FREEZER FREEZING UP/FRIG NOT COOL
also check defrost timer,defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 01, 2009 | Frigidaire FRS26R4A Side by Side...
Fridge not staying cool, freezer still freezing
The defrost thermostat on the defrost heater is probably bad, it's a good place too start.
Mar 18, 2009 | Maytag MBB1956GES Bottom Freezer...
The fridge part of my fridge freezer appears to have stopped working
Look to the freezer for your problem. Frost free refrigerators are cooled by air from the freezer compartment. If the freezer cooling coil freezes up air flow to the refrigerator is lost. Look for signs of frost on back wall of the freezer section.
Located the defrost timer, turn the clutch head screw clockwise SLOWLY until you hear one audible click. The system will then be in the defrost mode. During the 18-22 minutes of the defrost cycle heaters are energized and defrost should take place. If defrost happens and the timer does not restart into the cooling mode, rotate the screw one more time SLOWLY to the second click and the system will restart in the cooling mode. Replace the timer in this case.
If the timer restarts the cooling after the defrost period and defrost does not happen your problem is in the defrost heaters or defrost thermostat. They are located inside the back wall of the freezer on the cooling coil.
Jul 05, 2008 | Samsung Refrigerators
REFEGERATOR NOT GETTING COLD
Sounds like a defrost problem or dirty coils under the machine. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/control board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 01, 2008 | Maytag MZD2766GES Side by Side...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
53 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
