Question about RCA D52W136D 52 in. TV/DVD Combo
Tv turns on and runs for a while then shuts its self off
When I plug the HD wire to the TV, the screen is blank it doesn't turn on
most modern tv's turn them selfs off if they don't detect a valid video signal if a short period of time
i first noticed this when my son shut off his video game and the tv then shut it's selfoff
Feb 20, 2015 | Televison & Video
Rca 32in TV Product serial#f483ceok5 RCA 32in
try unplugging the tv from all imputs and power and let set over night then plug everything back in.
Feb 10, 2011 | RCA TruFlat 27F520T 27" TV
Samsung SP50L6HD Tv turns it's self off. Time
sir it may happen if the auto off option is enabled and the timer is enabled........... check for this options if they r and enabled then disable that........... or give your tv to the service shop and check for any problems
Jul 20, 2009 | Samsung Televison & Video
My tv plays about 1-1/2 hours then shuts down
YOU WILL NEED TO REPLACE YOUR PROJECTOR LAMP #BP96-01472A AND THIS SHOULD RESOLVE YOUR ISSUE.
HOPE THIS HELPS
Jul 07, 2009 | Samsung HL-S5087W DLP TV
KDF-46E2000 turns off then back on by its self
* Most common would be a couple of capacitors in the power supply that are not letting the proper voltage to the lamp.
* The lamp itself is not working properly.
Jan 25, 2009 | Sony KDF46E2000 46" Projection HDTV
My emerson tv is turning it self off
my tv shuts off after a few seconds what can i do to fix it
Sep 12, 2008 | Emerson EWL20D6 Television
Tv shutting of after 1 min then its on for 5 min then
Fuse, board-mounted, 4a mini AGC glass, 125v.
4-pack at Radio shack runs $4. USD.
Jul 29, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Lcd tv shuts down by its self
All you need to do is remove the back cover, then remove the metal cover that covered the power supply. Watch tv w/o cover, it won't shut down again. Try it and post here if it works.
Sep 12, 2007 | Televison & Video
Tv shuts off while watching
replace EHT (extra high tension) transformer
Feb 07, 2007 | Philips TS3661C 36" TV
RCA D52W136D 52 in. TV/DVD Combo Logo
85 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
