Question about Kenmore 24032\24036 Top Load Washer
I have a Kenmore Heavy Duty 70 series top loading washer -spin cycle got out of balance and the top of tub started banging around, tried another small load of clothes and the tub during spin cycle bangs around and has to be shut off. Removed the top, found plastic like a cylinder cup and a nail about 2"long with a hole at the tip end on the floor-noted two other plastic cylinders in place and same nails have fallen into the bottom of these cylinders. Do I just need to put a cotter pin in each of these? Will that solve the problem? Thanks-
catriver
  • 878 Answers
SOURCE: Kenmore washing machine
Sounds to me like you have a worn drive block and possibly a bad spin tube. The drive block can be accessed by removing the agitator first. Next you will need to remove the spanner nut. Now you can remove the basket. Attached you will see the picture of the drive block, I hope if it downloads. The spin tube locks into this drive block with two tabs that fit in respective grooves in the block. If the tabs are worn off the spin tube, that will have to be replaced as well. Good luck,
Posted on May 21, 2006
danromarris
  • 101 Answers
SOURCE: Kenmore Model 80 110-9258311 Spin balance issue
On the bottom of the basket there are springs. These springs keep the basket from slamming all over the place when in spin and agitating. Check that these springs haven't fallen off or come loose. I am guessing that this is all that happened. During moves this just happens sometimes and it's easy to fix. Hopefully you didn't loose any springs along the way, but if you did just call your local appliance repair shop and get some new ones. Kenmore parts are easy to come buy. If the springs look good check and see that they aren't real easy to expand. They should be real stiff. If they are easy to expand replace them. Let me know if you have any other questions and let me know if this was helpful. Good luck.
Posted on Jan 22, 2009
  • 1122 Answers
SOURCE: washer works fine till it gets to the spin cycle,
those are shipping pins pull them back out,check the tub springs,also the triangle the tub sits on has 3 pads it rides on check them also,somebody has bypassed the lid switch,it's ok,let me know what you find-mike
Posted on Apr 30, 2009
MalKontent68
  • 748 Answers
SOURCE: My Maytag goes out of balance and bangs loudly
This is usually due to the floor not being perfectly level, and as a consequence the washing machine not standing firmly on all 4 supports.
There should be at least 2 adjustable feet under the machine, try to make it stand as level as possible, with uniform load on all four.
If you have a bubble level it may help you establish, if there's an obvious slope on your floor and adjust the machine so that it's well levelled.
Posted on Oct 30, 2009
dutchman05
  • 487 Answers
SOURCE: My Kenmore Heavy Duty 70 washer is out of balance
can you please double check the model number as it does not show up in the records
Posted on Jan 12, 2010
Tub support broke
POST THE MODEL NUMBER PLEASE
Apr 16, 2009 | Kenmore 22422 Top Load Washer
Washer will not empyy water or spin or wash on any cycle
something caught in drain pump, clamp hoses and remove pump inspect repair or replace.
Apr 04, 2009 | Kenmore 22422 Top Load Washer
Kenmore 82372110 70 series heavy duty plus won't spin
If it drains and won't spin you have to replace the direct drive coupling.
Feb 25, 2009 | Kenmore Washing Machines
Timer stops at the end of wash cycle, won't began drain cycle
if it fills and agitates but stops at the drain/spin portion, it sounds like you have a problem with the lid switch. if it thinks the lid is opne, it will not drain or spin.
Dec 29, 2008 | Kenmore Washing Machines
Unstable tub
There are springs inside the unit that stablize the tub during spin. If the springs are not attached correctly the tub will be off balance. Sometimes the Balance Ring loses it's fluid due to a crack or leak and the washer will spin off balance. THis requires a service tech to dissemble the machine.
Nov 27, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore washer series 70 shakes wildly during spin during cycle
I have the same kenmore and have experience this before. It is unbalanced. Get a spirit level to check for balance. To rebalance, empty the washer (so it's not heavy), lean over the washer and grab the back, tilt it forward and the auto balancing legs should reposition themselves. Re-check for balance using the spirit level. If still out, adjust the front feet of the washer by screwing the legs up or down (using a wrench). This will cure the problem (unless you have a very unbalanced load of towels for instance). Good luck
Mar 30, 2008 | Washing Machines
Thumping and banging
make sure all shipping pins are out the tub should move all around from side to side if it level still bangs its eather the balance ring top basket are there 3 slides on a plate above the motor just put some silacone oil on tham move around
Feb 09, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
63 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
