Device manager says that it can't load device driver code 39
  • 480 Answers
The error code 39 means that the driver is missing or corrupted. You may need to uninstall and reinstall the drivers for the device itself. try looking at the website of your manufacturer. sample. dell.com / hp.com Cheers
Posted on Sep 09, 2010
2 Suggested Answers
hardkiss69
  • 43 Answers
SOURCE: pioneer dvd-rw dvr-k17a
Hi, the error code that you have on the CD/DVD drive is a known issue from Microsoft. The error code means "Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (code 39)".
Since you are using a Toshiba laptop; you can click on this link http://tinyurl.com/toshibadvd and click on the repair tool on the resolution. This is applicable on both Windows Xp and Vista and will delete the upper/lowerfilters on the registry.
In case that the error code still exist you need to manually delete the upper/lowerfilters under the registry by clicking on this link http://support.microsoft.com/kb/929461/en-us . You need to go the "Run" screen then type in "regedit" and click OK or hit the enter key.
This will surely fix the error code that you have on the CD/DVD drive.
Thanks
Posted on Sep 18, 2008
Driver for iphone4 code 28
Important: Device Manager error codes are exclusive to Device Manager. If you see the Code 28 error elsewhere in Windows, chances are it's a system error code which you should not troubleshoot as a Device Manager issue. Cause of the Code 28 Error A Code 28 error is caused by a missing driver for that particular piece of hardware. There are any number of reasons that a driver might not be installed for a device but your troubleshooting of the problem will be the same no matter the root cause.
Error Code 28 Troubleshooting
  1. Restart your computer if you haven't done so already.
    There is always the slim chance that the Code 28 error you're seeing in Device Manager was caused by a fluke with Device Manager or in your BIOS. If that's the case, a reboot might fix the Code 28.
  2. Did you install a device or make a change in Device Manager just before you noticed the Code 28? If so, it's very possible that the change you made caused the Code 28 error.
    Undo the change, restart your PC, and then check again for the Code 28 error.
    Depending on the changes you made, some solutions might include:
  3. Update the drivers for the device. Installing the latest manufacturer supplied drivers for a device with the Code 28 error is the most likely solution to the problem.
    Important: Make sure you install the drivers for the correct operating system. For example, if you're using Windows 7 32-bit, install the drivers designed for that specific version of Windows. Many Code 28 errors are caused by attempting to install the wrong drivers for a device.
  4. Install the latest Windows service pack. Microsoft regularly releases service packs and other patches for their operating systems, one of which may contain a fix for the cause of the Code 28 error.
    Note: I do know that certain service packs for Windows Vista and Windows 2000 have contained specific fixes for some instances of the Code 28 error in Device Manager.
  5. Replace the hardware. As a last resort, you may need to replace the hardware that has the Code 28 error.
    It's also possible that the device is not compatible with this version of Windows. You can check the Windows HCL to be sure.
    Note: If you still think there is still a software/operating system component to this Code 28 error, you could try a repair install of Windows. If that doesn't work, try a clean install of Windows. I don't recommend doing either of those more drastic options before you try replacing the hardware, but you may have to if you're out of other options.
Please let me know if you've fixed a Code 28 error using a method that I don't have above. I'd like to keep this page as updated as possible.
Jan 08, 2012 | Microsoft XP Computers & Internet
Error code 39 cannot load your hardware device
Try this few steps to resolve your issue:
1. update the driver from the Device Manager.
2. right-click My Computer on your Desktop
3. and then on the Hardware tab, select the Device Manager button.
4. In the Device Manager window, identify the CD or DVD drive item (with Yellow exclamation mark)
5. right-click on it and select Update Driver.
note:
Please follow the screen instructions to update the device driver and restart your PC.
Sep 07, 2010 | Intel Computers & Internet
Error 39 canot load the driver
Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
Uninstall and reinstall the driver
Uninstall the driver from Device Manager, and then scan for new hardware to install the driver again.
You may be prompted to provide the path of the driver. Windows may have the driver built-in, or may still have the driver files installed from the last time that you set up the device. However, sometimes, it will open the New Hardware Wizard which may ask for the driver. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor’s Web site.
  1. On the device Properties dialog box, click the Driver tab, and then click Uninstall. Follow the instructions.
  2. Restart your computer.
  3. Open Device Manager, click Action, and then click Scan for hardware changes. Follow the instructions.
Nov 27, 2009 | Lite On (LTN486S) Internal 48x CD-ROM...
Code 39
hi,
error code 39 stand for (Windows cannot load the device driver for this hardware. The driver may be corrupted or missing.)
Reason
There are several causes of Code 39 errors:
  • A required device driver is missing.
  • A required binary file is corrupted.
  • There is a problem with the file I/O process.
  • A driver that is referencing an entry point in another binary file is unable to load.
Recommended resolution
Reinstall the drivers for this device.
Sep 26, 2009 | Computers & Internet
Code 39 on DVD Philips SDVD8821
Download the latest driver from Acer site or phillips site.
Uninstall the device driver.
Reboot
Windows should detect new hardware and start the wizard. Point to your drver installation file and install the driver.
Reboot. this should fix the problem.
Apr 26, 2009 | Acer TravelMate 4220AWLMi Notebook
5315
Code 28
The drivers for this device are not installed. (Code 28)
Install the driver
You may be prompted to provide the path of the driver. Windows may have the driver built-in. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor’s Web site.
In the device Properties dialog box, click the Driver tab, and then click Update Driver to start the Hardware Update Wizard. Follow the instructions to install the driver.
Code 39
Cause
Thanks
Mar 06, 2009 | Acer Aspire 5315 Notebook
DVD-ROM of my laptop is not working
What is the specs of the laptop?
Feb 10, 2009 | Toshiba Televison & Video
My comp says code 39 can you help
Code 39 Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)Cause
I am sending you a copy of this information in the hopes that it will be of some help in your situation.
Cheers!
Ron.
Dec 16, 2008 | Computers & Internet
Pioneer dvd-rw dvr-k17a
Thanks
Nov 13, 2007 | Toshiba Satellite A100-S8111TD Notebook
Computers & Internet Logo
David Payne
David Payne
