Question about Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator
My refrigerator is set to #1 and I am having problems with items freezing in the refrigerator section, most notably the vegie bins as well as the top shelf. We have a stainless trio that is about five years old.
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 11, 2010
FREEZING REFRIGERATOR
Hello Pam, Welcome to FixYa. In actuallity most fridges whether they are side by side, conventional top mount, or bottom mount, the control for the fridge section is nothing more than a damper which allows or prevents air flow through the fridge section. The thermostat which control the "run time" or actual temperature is the freezer control. It is possible to set the fridge control at "1" and yet still have items feeze because the freezer control is set to "3", "5", or higher. Try adjusting the freezer control to a lower number as well and see what that yields. You may also want to vacuum out your condensor coils under the unit...( unplugging the power cord first of course ;) safety first ) this too can cause items to freeze in the fridge section. Without getting too deep into how it all works I'll just say it effects the entire system negatively. Hope you find this an acceptable solution and can take a moment to rate it accordingly. Thank you for visiting FixYa and please let me know if you require further assistance. macmarkus :)
Jul 12, 2010 | GE GSS20IEP Side by Side Refrigerator
There is a puddle of water inside the refrigerator, beneath the vegetable bins.
How many items are in your freezer? I had this problem and there was too much in the freezer, not allowing the air to circulate properly in the freezer, thus resulting in freeze up in the top (freezer) and condensation below in refrigerator section. Additionally, I had the refrigerator setting too cold, which accelerated the problem. I had to thaw the drain hole in the freezer section, below the fan, to allow water to leave freezer during defrosting stage. Hope this helps?
Jan 03, 2010 | Kenmore 18.3 cu. ft. Top Freezer...
Purchased in 2002 and is starting to freeze in the
Check the back of the fruit and vegi drawers. If theres a slot for an intake port try closeing it (if adjustable) Check thermostat setting for fridge and adjust to a lower setting.
Finally make sure door closes and seals closed, clean gasket with mixture of white vinegar and water (1 cup vinegar to 1 gallon warm water). If this fails internal thermostat may need replacing.
Dec 17, 2009 | Amana ARS2464B Side by Side Refrigerator
Bad defrost timer/ thermostat???
It definitely sounds like you have a bad defrost timer, that is the reason the coils are icing up on you. The next issue, which may or may not be related is the freezing of items in the refrigerator. Usually the cold air is transferred, through a vent with a damper, from the freezer and into the refrigerated section. The "thermostat" for this section is actually usually just a lever to adjust the position of the damper. That being said, usually when you have a problem such as you are having, it is either a stuck or broken damper (or damper component). Hope this helps
Nov 16, 2009 | Kenmore 21.9 cu. ft. Bottom Freezer...
Both top sections fridge/freezer of my side by side are not cold
Sounds like a defrost problem. Remove food from freezer section, take the back wall out after removing shelves, and use a hair blower to melt off the ice and frost. Most likely you need to replace the defrost heater.
Oct 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Crisper and veggie bins are freezing the produce
I have dealt with bosch and thermador quit a bit and they usually don't have to much of a recommendation for these settings because they are more of a commercial type appliance producer and all situations are different. Here is a tip for the sliders though. Remember that leafy produce needs more airflow to hold its texture and taste and anything with a skin requires less airflow. As far as the temp settings I believe the most nominal settings are going to be in between 5 & 7 to keep from freezing the produce. You will have to play around with it a little though to get it to keep the ref good and cold but keep from freezing the vegies. Hope this helps. Good luck.
Jun 05, 2009 | Bosch KGU6655
Items in the back of the refrigerator freeze.
is this something that has just started happening? Most kenmore top freezers have a vent that allows cold air from the freezer into the refrig through a vent located on the back wall in the center of the refrig section. if packages are pushed up under this vent they can freeze.
If you have widespread freezing in the refrig setion then a temperature control could be the fault. thanks for using fixya. Peyton..
Feb 17, 2009 | Kenmore 72992 / 72994 / 72999 Top Freezer...
Everything freezing in vegetable and Custom Cool compartment
you have a temp setting above those shelves left side has a porkshop and left side has a carrot i belive set to to the left side to vegies and see if it helps if still all freezes the you have a broken damper on top that letts air in when it does not needed
Sep 26, 2008 | GE Profile PSW26P Stainless Steel Side by...
Food freezing in frig
Go to the link below and the choose line 22 and click it. That link page helps identify most common problems you may have with your refrigerator, Thanks Sea Breeze.
 http://www.applianceaid.com/refrigerator.html
Sep 11, 2007 | GE Profile PSI23NCR Side by Side...
Kenmore 73503 Stainless Steel Bottom Freezer Refrigerator Logo
89 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
