Question about Fujitsu Heating & Cooling
Compressor for fujitsu AOT17RZ SPLIT SYSTEM outdoor unit.Price and availability??
  • 456 Answers
Type the name and model number on Ebay
Posted on Sep 09, 2010
Can a Fujitsu compressor unit be connected to multiple inside evaporator units that have different tonnage ratings. 18,000 BTU compressor and 9,000 & 12,000 BTU evaporator units inside.
call fujitsu engineering division direct and ask them about what is connected and if it works ok
logically as each evaporator has it's own tx valve as long as the compressor is large enough to run all together it should work but get the right information from the fujitsu experts
Oct 11, 2016 | Fujitsu Heating & Cooling
3 split units run from one compressor one is not cooling
If there is 3 indoor units from one condensing unit
(6 pipes at outdoor unit) this is classed as a multi unit
All units will run correctly as long as they all require same mode, cooling or heating, if one unit decides to heat it will shut down until master unit decides to heat then it will start, for each unit to individually heat and cool there would have to be 3 pipes to each indoor,
Dec 19, 2015 | Fujitsu 9RLS 9000 BTU Split System Air...
What is the hourly labor rate 2 install this unit
Trades will be very reluctant to give you an hourly rate on split system install as this would deplete the profitability. It depends on the installation, a simple back to back install would take around 3 hours with electrical connection to switchboard. It also depends on brick or fibro walls. Most installations are around 500 Aus dollars total price with the longest time frame of around 4 hours
Jun 10, 2014 | Fujitsu "AOU30CLX1 30,700 BTU Halcyon...
Ramsond Split system - R55GW - will not cool or heat
That would be the way to go even thought the cost is high. If not you run the risk of compressor failure and the metering device may be clogged. I know the price is what has you over a barrel but, the cost to you in the near future will be 3 times as much.
Sorry I could not cure the problem over the internet
Also check around there may be someone who could do the job slightly cheaper.
Dave
Jan 15, 2010 | GE Quiet-Aire Ductless Split System Air...
Fujitsu split system not working
Hi, I know its a split as you have noted, and I am sure it would be a ductless heat pump system. Unless you are having a problem programming the t-stat, the manual would be of little help on these units.I wish you would have given more on the symptoms, like does it blow cold air or either unit will not work? You say it will not heat. On a H.P., it could be many things.Lets say its blowing cold air. Check the outdoor unit to make sure it comes on in the heat mode also, and the fan is on.Make sure you turn the heat up far enough to bring on the outdoor unit 1st. If it doesn't come on, then find the breaker to see if it is tripped. If yes, turn off hard and on again hard. if it stays on, great. If not, then It gets more complicated as compressor may have shorted out. Please check these things for me, please so we can solve this for you. On a heat pump, if you loose a compressor lets say, you have electric heat strips in the indoor unit that should come on if you have a switch on the T-stat that will say emergency heat. Try and use this setting to see if you can get some heat. I am trying to offer a solution to get you some temp. heat until we locate the main problem. If the indoor or outdoor units are not running at all, check for power at all breakers, and, check program on t-stat to make sure you set on heat, fan to auto, and temp to where you are comfortable.From here after checking all of these solutions, let me know what the status is and if it did not work, to tell me more of the original symptoms so I can go from there. Best of Luck,
Sincerely,
Shastalaker7
Nov 21, 2009 | Heating & Cooling
Fujitsu mini split outdoor unit not running, but indoor unit is running after turnning on
Check the disconnect switch and make sure that both the fuses are good and not shot. If one is shot then the system wont work. There are two fuse. Also be careful due to you will be working around 210 volts
Jun 01, 2009 | Fujitsu Heating & Cooling
Outdoor unit does not start. indoor unit fan does run.
by the sound of it the relay in the outdoor section is bad
May 31, 2009 | Heating & Cooling
Split unit, I get heat but no cold
I have run into this with the LG brand systems. try shutting power off to the outdoor unit to reset all units. If problem persists, it could have to do with a charge level of refrigerant (freon) or possibly a failed control board.
May 16, 2009 | Fujitsu 24R1 Air Conditioner
Will Not Heat
On the outdoor unit the fan should not be running, on the indoor unit the fan should be running. If you then check the outdoor unit with fan not running, you should be able to hear clearly that the compressor is actually working. If this is all correct, it is possible that your fourway reverse valve is seeping and needs to be replaced.
Apr 15, 2009 | Fujitsu 18R1 Air Conditioner
Fujitsu heat pump noise
i would check the blades on the condenser fan motor and make sure they are not hitting anything if they are not, spin the fan see if the fan spin freely, it should, if it doesn't it could be the bearing in the motor are dry and going bad
Jan 22, 2009 | Fujitsu 24C1 Air Conditioner
Heating & Cooling Logo
114 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
