Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
How to pull the logic board? - Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
    President:
  • 3,197 Answers
The logic board is connected to one end of the motor unit and there is a quick disconnect that unplugs all the wires. It is much simpler than it may at first seem.
Posted on Sep 09, 2010
How do i fix it
The logic board is faulty. That chip can't be replaced by normal soldering techniques. Replace the board. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 11, 2015 | LG Televison & Video
IPod won't turn on
If this is a new iPod, then take it back to the retailer. Your battery is no good. If it is used, there probably is not any kind of warranty. However if you want to replace the battery it is really easy. I have a web page that you can purchase a battery replacement kit as well as full detailed instructions. There is a video on the second web site listed. However i do suggest following the written instructions as leaving everything else connected can make it a hassle. :) If you have any other questions about this or difficulties with the resolution please do let me know.
iPodbatterydepot.com
www.fixyouripod.weebly.com
Top Case Removal Begin by using a flat tool to separate the white plastic front case from the silver backcase. You will need to stick your flat tool into the crevice, work it down into the crevice,and then pry up so that the casing separates. Apply enough pressure so that your flat tooldoes not slip and scratch your iPod!Continue separating the casing by gently prying up all the way around the unit. It shouldbe much easier to pry the casing apart after you get the initial corner started.
With the casing separated, grasp the top half (the part with the front bezel) and flip it over. Note that there is an orange cable in the top left corner that connects the iPodlogic board to the headphone ports. If you gently grasp the cable and pull, it will slide out of its connector on the headphone port module board.
Headphone Jack Board Removal Before proceeding, you must remove the top case.There are two t6 screws holding the headphone port in place. Remove both of these screws. You can now remove the headphone module.
Hard Drive Removal Before proceeding, you must remove the top case.Hold the hard drive up, and remove the black tape on the hard drive connector. This will reveal the hard drive cable’s connector to the logic board.To remove the hard drive, grasp the cable (thumb on top index finger onbottom) and gently pull the cable out (away from you and the connector)The hard drive will now be free of the iPod logic board.
Hard Drive Cable Removal Before proceeding, remove the hard drive.To remove the hard drive cable, hold the drive, and gently pull up on the cable.It should come out easily.
Headphone Connector Cable Removal Before proceeding, remove the hard drive.To remove the headphone connector cable, Grasp the cable, and gently pull up. It should come out easily.
Logic Board Removal Before proceeding, remove the hard drive and headphone connector cable First, disconnect the battery connector by grasping the cable and gently pulling up to disconnect the cable from the logic board connector. Remove the 6 black T6 Screws.
With the screws removed slightly move the logic board to the left to give more access to the clickwheel cable. Gently pull this cable to free it from the logic boardconnector.The logic board will now easily come free from the case. The LCD will still be attachedto the logic board.
LCD Removal Before proceeding, first remove:Hard DriveHeadphone Connector CableLogic BoardTo remove the LCD, grasp the green connector cable, and gently pull to free it from the logic board connector. It should come out easily.
Battery Removal Before proceeding, first remove:Hard DriveHeadphone Connector Cable Logic Board To remove the battery, use a flat tool to pry the battery up. It is held on with a lightadhesive, and should come up by using just a little force. Lift the battery out of the unit.
Simply do every thing in reverse to put the iPod back together. Make sure to remember that it only takes gentle pressure to remove and replace the parts.
May 10, 2009 | Apple iPod nano
When my i-pod is attached to my computer it works and when it is
You need a new battery then. You can order one online for a reasonable price and installation is fairly easy. I have posted two web sites that sell batteries for iPods as well as step by step instructions for the click wheel iPod models. www.ifixit.com
Everything goes back in with gentle pressure and of course replacing screws and what not. All in all though, it is allot cheaper then buying a new iPod or other MP3 player :) I hope this is helpful to you
May 09, 2009 | Philips GoGear SA5285/37 Digital Media...
Dead battery?
Battery is bad. If you use a dock most of the time, it is overcharging or never gets the chance to relearn its capacity. If it just shows low battery but will still work, just run it with a low battery until it shuts off. Then recharge it completely. Do this three times. If no improvement, you need to replace the battery.
Mar 29, 2009 | Apple iPod MA446LL/A MP3 Player
Apple ipod click wheel not working.
You will need to replace your iPods battery. It's not as hard as apple would have you think either. :) To order a battery replacement kit you can go to:
www.ifixit.com
and to view a free video guide you can go to:
http://fixyouripod.weebly.com/
Also below I have posted a step by step on opening the case and removing each part. Once your inside the unit you will see that putting it all back together will be simple enough. It looks allot like a mini computer. :) Let me know if you need any further assistance with this issue. Also I do hope that it's not too late for a resolution to it. Cheers
Mar 23, 2009 | BoxWave Corporation Apple iPod mini (4GB)...
DEAD IPOD 8GB
You can disasemble the iPod to see if there is any visable water damage. If there is and you want to replace it, you can go to www.ifixit.com and order the appropriate parts there. Also at the bottom of this entry you will see another web address. This is where you can watch free iPod repair video's. :)
Mar 21, 2009 | Apple iPod touch
Ipod won't turn on
You may need a new hard drive for your iPod. Its allot easier to replace then you would think to :) If you go to the following web page there are a few video's on trouble shooting this kind of issue as well as instructions on taking apart the ipod and replacing a few of the items. Also below I have posted a step by step guide on completely disasembeling an iPod.
http://www.ifixit.com/
Mar 10, 2009 | Apple iPod nano
Ipod doest not work
Do you mean there is no power to the iPod when it is not connected? Or that you are not able to manually manage the music within the iPod using iTunes? If it will not power on without power behind it, you just need a new battery. you can view a free video on batter replacement at the following web address. also the second web page will take you to an iPod parts online store. And just in case you need the written directions I have posted them below :) Let me know if this is not the issue you are having, or if this does not resolve it.
http://www.ifixit.com/ ----------------------------------------------------------------------------------------------- Top Case Removal Begin by using a flat tool to separate the white plastic front case from the silver backcase. You will need to stick your flat tool into the crevice, work it down into the crevice,and then pry up so that the casing separates. Apply enough pressure so that your flat tooldoes not slip and scratch your iPod!Continue separating the casing by gently prying up all the way around the unit. It shouldbe much easier to pry the casing apart after you get the initial corner started.
Mar 03, 2009 | Apple iPod nano
Water damage
It sounds to me like you need a new battery for your iPod. To order a replacement battery kit, you can go to (www.ifixit.com) There is also a free video at (http://fixyouripod.weebly.com) Below is also a step by step instruction (guide) to taking apart the iPod piece by piece so that the replacement can be done in an easy safe manner. If for any reason you have difficulties please do let me know :)
Feb 27, 2009 | Apple iPod nano MP3 Player
IPOD 20GB CLASSIC
Jul 13, 2008 | Apple 20gb Ipod Mp3 Player With Click...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
63 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
