Question about Wahl 8051 Hair Trimmer
The blades we not cut - Wahl 8051 Hair Trimmer
  • 193 Answers
Probably just the blades require sharpening try www.angliaclipperservices.com specialists internationaly.
Posted on Sep 16, 2010
What is the difference between the angle cut blades and the shear cut blades on my bolt cutter?
angle cut blades have the cutter head angled at 25-35 degrees for easier insertion into tight spots. Shear cut blades are light normal scissor blades
Jan 16, 2013 | Cutter Tools
I have a craftsman jigsaw(scroll) that I got for Christmas last year. The blade comes out in the middle of my cut some time. Is there a problem with this type of jigsaw?? I have sanded the top of the...
Most of the time the cause for this is applying to much pressure on the blade as you are cutting. Remember, the blade does the cutting and you are guiding the jigsaw around the cut. This can strip the blade and wear the top of the mount. Adjust the way you cut and you should not have any problems.
Aug 26, 2011 | Craftsman Saws
Cub cadet not cutting correctly on right side
Try sharpening the blade.Or the blade may be twisted.
Aug 02, 2009 | Garden
What is the difference in a regular blade and a mulching blade?
A regular blade has a straight cutting edge, a mulching blade is bent to have a high and low cutting edge. Even if you have a mulching blade on, if the grass is too high or wet or you're cutting too low, it won't do a good job and may require a second pass.Raising your cutting height can help. Hope this helps. Dwain
May 17, 2009 | Craftsman Garden
Blade misalignment
The 1590, like several Bosch jigsaws, has a selector switch to choose the type of cutting action. You have to choose the appropriate cutting action, either straight or oscillating, to accommodate the material you cut and the blade you cut with. For instance, if using a very slender blade for clean curved cuts in wood, a slight oscillating motion ( setting II or III) reduces friction on the blade.
If you choose the straight cutting action you get maximum accuracy, but drastically increase the friction because the blade is held firmly to the roller bearing.  A slender blade can handle that for brief periods, (say... less than thirty seconds) in soft, thin wood with a straight cut. In hard woods or engineered wood products ( plywood, MDF etc.) the thin blade will heat up and bend.
You can reduce friction by choosing an oscillating cutting motion, or you can use a larger, sturdier blade. The "Aggressor" blades do not cut as smoothly as the "clean" blades, but they cut faster and are stronger. To cut thick wood ( 4x4 ) or a long cut in engineered material, that is the blade I use. Select number III or number II for 'type-of-cut' and use a bigger blade. See if that stops the "bucking."
Mar 24, 2009 | Bosch 1590EVSK 6.4 Amp Top Handle Jigsaw
Blade length problem
Hedge trimmers cut using either a single-action, where only the top blade oscillates, cutting against the stationary lower blade, or a double-action where a pair of double-sided toothed blades that slide back and forth at a high speed so you can sweep across hedges in both directions. The latter are more efficient. Blade length Consider the size of the hedge you will be cutting to get the right length blade. The longer the blade length, the more area it can cover and the quicker it will get the job done. However longer blades also require more power and larger heavier motors so weigh up blade size versus ease of use. Blade lengths range from 14 to 30 inches with long blades of 22 to 30 inches providing extended reach for taller or wider hedges. Blade width The blade width indicates the space between teeth and the maximum thickness the trimmer can cut through, eg. 20mm blade width will be able to cut through a maximum 20mm branch.
Aug 27, 2008 | Bond Manufacturing 6-pieceUltimate Pruning...
Grinder support
They range in blade composition, number of teeth (cutting bits or surfaces), the amount of set (the width of the kerf removed by the blade), and the blade quality. * One of these circular saws will probably have a plain HSS (high speed steel) saw blade in it when it is bought new. * TCT (tungsten carbide tipped) blades are much more durable, especially in tough hardwoods. Also plywood and composite boards are hard on blades so TCT blades are needed on them. o Blades with fewer teeth (say 28) and with less rake to the face of the teeth, are designed for ripping along the length of timber, with the grain. They typically give a quick rough cut. They are cheap to buy and cheap to sharpen, since they have less teeth. o Blades with more teeth (say 40) are designed for crosscut type work. They give a lot neater cut in most circumstances. * Abrasive blades are made from carborundum or other abrasive materials bonded together in a resin or other synthetic binding material, and are used for cutting concrete or metal. They tend to wear away rather quickly, but for small projects, they are inexpensive and make fast cuts. * Diamond rim blades. These blades are made of special alloy metals with industrial diamonds embedded in the rim (around the outside diameter of the blade), and are for cutting hard concrete, cement composite materials, and masonry products like block or brick. * Special tempered allow blades. These blades have tempered carbon steel teeth, which are very fine (small, and closely spaced) for cutting sheet metal like galvanised roofing metal, or aluminum, copper, or brass tubing. * Dado blades. These are blades which can actually be adjusted to cut different width kerfs (the width of the material removed in the blade path). These blades make it much faster and easier for cutting dados and rabbetts, used for joining lumber. * Trim and panelling blades. These blades have fine teeth for making smooth, accurate cuts on finished materials like mouldings and panelling.
Aug 27, 2008 | Speed CGW ABRASIVES 35606 "24 GRIT" HIGH...
Blade Types
remember to match the blade width to the type of cutting you are doing. Also keep in mind: * Narrow Blades can make much tighter radius cuts, but tend to twist and wander when making long straight cuts. * Wide Blades can't make the tight turns that narrow ones can, but they hold a straighter line than their narrow counterparts. * The tpi determines the speed with which the blade cuts through stock. Blades with high tpi cut slower but leave a very smooth edge. They are best for detail work on thin stock. Blades with low tpi cut quickly and leave a slightly rough edge. They are great for resawing or long rip cuts. * Steel Blades are inexpensive and work well for cutting softwood. Steel blades, however, dull quickly in hardwood. * Bimetal Blades are made of high-speed steel and can cut thin metal or wood. * Carbide Blades are for wood cutting only. They are more expensive than other blades but stay sharper longer than steel or high-speed steel.
Aug 27, 2008 | Dewalt Variable Speed Deep Cut Band Saw...
Blade width usage
Blade Width is important when purchasing a band saw. Most saws accept narrow 1/8" blades for cutting detailed designs and tight curves. Better saws also accept wider blades. Wide blades don’t flex as much as narrow ones, but they make accurate straight cuts in thick stock quicker. There are also some wide blades available that can cut metal.
Aug 27, 2008 | Milwaukee Tool Milwaukee 6230 Deep Cut...
Wahl 8051 Hair Trimmer Logo
49 people viewed this question
Top Wahl Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Anglia Clipper...
Falling star
Are you a Wahl Health and Beauty Expert? Answer questions, earn points and help others
